Help swapping stock rims and tires 2018 to 2013
Discussion in 'New Member Introductions' started by Trek, Feb 14, 2021.
  1. Feb 14, 2021 at 8:05 PM
    Trek
    Trek [OP] New Member
    Nc
    2013 Tundra
    None
    I picked up a set of 2018 alloy stock rims to replace my 2013 stock rims. Are they going to fit and what lug nuts do I need
    Prostar 190 and YardBird like this.
  2. Feb 14, 2021 at 8:21 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Same, direct swap.
  3. Feb 14, 2021 at 8:21 PM
    blackdemon_tt
    Unless you have steel wheels... then you will need the other nicer lugs..
  4. Feb 14, 2021 at 9:45 PM
    Trek
    Nc
    2013 Tundra
    None
    Thanks ——I do have the steel rims. I will see if I can get the lugs to go with the alloy rims.
  5. Feb 14, 2021 at 9:52 PM
    blackdemon_tt
    Your stock wheels were slightly misleading... as most come with alloy wheels,... maybe on me but I forgot for a moment that some do come with steelies... also your TPMS will not swap over from your steel wheels, so be advised on that as well..
  6. Feb 14, 2021 at 10:04 PM
    Trek
    Nc
    2013 Tundra
    None
    I appreciate your help, thankfully the TPMS came with the rims I picked up. I didn’t think much about it until I went to the tire shop to have them mounted and my lug nuts would not work and then I saw on this site that the center hole was slightly larger on the gen 3.
  7. Feb 14, 2021 at 11:00 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    Trek[OP] likes this.
  8. Feb 15, 2021 at 5:14 AM
    Welcome from Ohio
  9. Feb 20, 2021 at 9:07 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Welcome from the wet side of WA.
  10. Feb 20, 2021 at 10:10 AM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada
  11. Feb 22, 2021 at 12:48 PM
    Welcome from
