Help! Steering wheel shakes
Discussion in '2nd Gen Tundras (2007-2013)' started by Sfisher1974, Feb 18, 2015.
  1. Feb 18, 2015 at 6:14 PM
    Sfisher1974
    Sfisher1974 [OP] New Member
    2010 white tundra
    7" bds lift, 22/12 fuel wheels, 35/12.50/22 Arturo mud tires
    I've got a 2010 Trd 4x4
    I had some fuel 22" rims and new 35's put on. The steering wheel shakes at 30-45 mph, then you drive out of it at higher speeds. They balanced them several times, took to alignment shop, rotated .. Still there. Spent 7 hrs there today. They're supposed to change all 4 tires again tomorrow . Any ideas ???
  2. Feb 18, 2015 at 11:13 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Since it is at a certain speed range the best guess is the tires aren't getting balanced. I would say bad tire or tires or wheel or wheels. Did they road force balance? All in spec with alignment? No shake before?
    firebladews6 likes this.
  3. Feb 19, 2015 at 6:43 PM
    Sfisher1974
    2010 white tundra
    They ended up swapping out the tires for other new ones( same brand, style,etc) and the new tires called for far less weight to be added, vibration is virtually gone , they also had it aligned, and it drives much better now , took two full days, but it's finally right.
    MotoTundra likes this.
  4. Feb 20, 2015 at 12:13 PM
    csuviper
    Broomfield, CO
    Nice. Glad it's fixed and ready to roll
  5. Feb 20, 2015 at 1:50 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Agreed!
    OP What do you mean by far less weight to be added? Less air in the tires or lower weight rated tire? Something else? Thanks
  6. Feb 20, 2015 at 4:33 PM
    Sfisher1974
    2010 white tundra
    The first set they put on front, called for a lot of weight to be added to backside of rims in order to balance They swapped them out, and the 2nd set didn't require near as much
  7. Feb 20, 2015 at 5:14 PM
    Mike Tread lightly.
    south carolina
    in other words new bad tires.. this happens more than you think.... If my memory is correct it would have come out of the mold wrong of the vulcanization process too much heat or not enough ( i bet is the case here) making one side of the tire heavier than the other..
    Sfisher1974[OP] likes this.
  8. Feb 20, 2015 at 5:21 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Ahh now I got ya's!
  9. Feb 21, 2015 at 4:06 PM
    Sfisher1974
    2010 white tundra
    Ridin good now, thinking about getting a pre runners light bar on front, then adding a 3 " body lift when I can
