Help replacing top bracket ignition assembly!
Discussion in '1st Gen Tundras (2000-2006)' started by Wallie Renfro, Jan 17, 2025.
  1. Jan 17, 2025 at 12:25 PM
    Wallie Renfro
    Wallie Renfro [OP] New Member
    2003 Tundra Access Cab
    Hello all...My 2003 Access Cab was stolen on Christmas Day and was recovered with a destroyed ignition assembly...any advice on how remove the assembly from the steering column? The bolt heads appear to be smooth cones...please tell me I don't have to remove the steering column to fix my ignition! See attached pics!
  2. Jan 17, 2025 at 1:47 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    I'm not sure but I believe your speaking of what Toyota calls "Column Upper Bracket" and those smooth cones are tapered-head bolts....good luck with that. As removal pic below shows, their using a bench with steeing column in vise....face palm.
    Mind taking picture of actual damage and is there any chance the ignition switch is all you need to get out....pic would help to know. Instead of being able to turn key to ACC, pushing button on bottom of key cylinder, you may have to drill it out.
  3. Jan 17, 2025 at 2:38 PM
    The Black Mamba
    The Black Mamba He must increase, but I must decrease - John 3:30
    Ryan
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    I sure hope this is the case. This is super easy. The other part (I have no Toyota experience, but Subaru is very similar) it sucks. We have a special tool that is almost identical as described by @BubbaW . We only have to use it when the keys are completely lost because on the Subaru the BIU is integrated into it.
    For removing the barrel, this video is helpful Bing Videos
  4. Jan 17, 2025 at 4:44 PM
    Wallie Renfro
    Hey thanks guys...They totally destroyed the receiver part of the assembly unfortunately...
  5. Jan 17, 2025 at 5:16 PM
    shifty` I'm having daydreams about night things
    Just taking a moment to say: I fucking hate thieves.
    Thats some bullshit right there, and I’m sorry you’re dealing with it.
  6. Jan 17, 2025 at 5:22 PM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    Why are you dealing with that and not the insurance company?
    The Black Mamba and ATBAV8 like this.
  7. Jan 17, 2025 at 8:19 PM
    Wallie Renfro
    Yeah...if this was insured (Liability only...I'm broke) it would have been totaled because tweekers lived in it for 2 weeks...Meth, Fentanyl etc. I paid 1300 buck for the super pro drug remediation. Everything about this pisses me off...I'm the original owner, it's my baby...
  8. Jan 17, 2025 at 8:27 PM
    The Black Mamba
    Ryan
    DFW
    Imma keep it stock
    This is the kind of thing that pisses me off. You work so hard to get so little and then someone still takes it away
    shifty` likes this.
  9. Jan 18, 2025 at 3:46 PM
    gizardlizard
    gizardlizard New Member
    Madison,WI
    2017 TRD pro Tundra
    6” lift, 35 inch tires, chrome delete, ridiculous stereo
    If they’re anything like the trucks from the 90’s, they are snap bolts. I changed an entire ignition switch in my 91 Toyota PU. The bolts are designed to snap off, when the proper torque is reached. They use these to make removal of the switch difficult. To remove mine, I used a center punch and hammer to crack them loose and remove them.
    Dracko likes this.
  10. Jan 20, 2025 at 11:43 AM
    Wallie Renfro
    This is my first crack at a forum and it has not disappointed. Thanks for the solid advice to you all, making progress and will have her back on the road for way less than I originally thought...You guys rock and you will see me here again I'm sure...
    BubbaW and The Black Mamba like this.
