Help! Rear Seats were removed!
Discussion in '1st Gen Tundras (2000-2006)' started by Ticadoo, Nov 17, 2017.
  1. Nov 17, 2017 at 12:56 PM
    Ticadoo
    Ticadoo [OP] New Member
    I purchased a 2005 Tundra and the previous owner had removed the rear seats. I have the seats, I just don't know how to install them!! Any manuals, etc??????
    PennSilverTaco likes this.
  2. Nov 18, 2017 at 10:58 AM
    Outbound
    Aaron
    Northern Alberta
    See if you can get your hands on a Haynes or Chilton repair manual. Should be available on Amazon and it will likely cover how to do it. I can check mine later today.
    It should be a fairly straight forward bolt in procedure from what I can tell with the seats in my 05 double cab.
    Law323 and Jsena like this.
  3. Nov 19, 2017 at 11:30 PM
    Rkcruza
    Rkcruza New Member
    Bob
    2002 Tundra AC 4WD TRD OR SR5
    De Badged / Decaled, Firestone Ride Rite Air Bags w/ Daystar Cups, 17" Rims, Big Brake kit w/ slotted & drilled rotors, plus lots of work related stuff.
    Pretty basic bolt in job. Not sure which model you have, but simply Google Removing the rear seats from a 1st Gen Tundra and lots of hits come up....
    Law323 likes this.
  4. Dec 18, 2017 at 8:39 AM
    AntiArrhythmic
    AntiArrhythmic New Member
    Just put it in place. You will be able to see how it goes together. I pulled mine out this weekend. Took about 5 minutes.
  5. Dec 18, 2017 at 9:06 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    It's really simple. Once you have 'em in the truck just stick the bolts in the holes. Don't forget to fish your seat belts through before you bolt 'em in.
    NewImprovedRon likes this.
  6. Dec 19, 2017 at 7:04 AM
    scruffy
    scruffy New Member
    Dmitriy
    2014 Toyota Tundra Double Cab Limited TRD 5.7 4X4
    Opposite order of below...
