Help! Possible Snapped Rod
Discussion in '2nd Gen Tundras (2007-2013)' started by Columbiansnow, Oct 23, 2018.
  1. Oct 23, 2018 at 9:24 AM
    Columbiansnow
    Columbiansnow [OP] New Member
    Eddie
    2011 Tundra 4.6
    Hey Guys, this is my first post:
    So I was towing a 2005 tundra with my 2011 from Georgia to Virginia, about 200 miles into the trip (going 55mph and no sudden acceleration). I heard a loud pop, followed by awful clanking coming from the engine. Check engine light came on and I pulled over immediately.
    I suspect a snapped rod, but there aren’t any metal shavings in my oil (checked from dipstick), no smoke from the exhaust or engine, no oil leaking anywhere. The truck still fires up right away but idle surges from 500-1000 rpm. The clanking doesn’t start up until 2500 rpm, and calms down around 3500 rpm. I was able to pull codes off of it which were:
    P0300, P0301, P0303, P0305, P0351, P0365, and P2438
    Multiple misfires on cylinders 1,3, and 5.
    Ignition coil 1,
    Cam position sensor
    And air injection system.
    I still suspect a snapped rod just because of the loud pop. But I’m praying it’s not that severe. I was wondering if anyone has run into something similar or can offer advice on how to proceed?
    I should add I can’t continue diagnosing it as the truck is stuck somewhere in South Carolina at a towing yard (thankfully the owner was kind enough to let me store it there for free until I set up transportation), and I’m in currently in virginia and can’t go back until the weekend at the earliest.
    Any advice helps. Thank You
  2. Oct 23, 2018 at 9:28 AM
    Welcome to the site Eddie.
    Well, that kinda sucks man. Maybe the timing chain snapped. Either way, it’s a costly repair.
    Sorry this happened to you bud.
    I checked your IP address, we have some members where you're at, and these people are “salt of the earth” kinds.
  3. Oct 23, 2018 at 9:32 AM
    Columbiansnow
    Eddie
    2011 Tundra 4.6
    Thanks for the reply, and yeah any bit helps. once I figure out how to get it up here I am prepared for the worst. It definitely sounds expensive so far. If I snapped a rod then I’m looking into an engine swap but you definitely don’t find many Toyota engines at the pick n pulls here and it’s looking like a few grand for a decent 5.7 liter
  4. Oct 23, 2018 at 9:33 AM
    n2deep
    n2deep Pavement Princess
    TJ --->Stalker status Haha
  5. Oct 23, 2018 at 9:39 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Welcome Eddie. I hope it's not as bad as suspected.
    ColoradoTJ likes this.
  6. Oct 23, 2018 at 9:45 AM
    Sefferston
    Sefferston #37sandlongtravel
    Seth
    Commufornia (not by choice)
    ERMERGERD TOYOTA
    Wouldn't call it stalker status, more of trying to be helpful.
    Inquiringone and ColoradoTJ like this.
  7. Oct 23, 2018 at 10:06 AM
    So do you have the 4.6 or 5.7L?
    @driverdog is in Virginia Beach. He might have some local contacts.
  8. Oct 23, 2018 at 10:06 AM
    Not everyone runs on a VPN.....
    KevinK and Sefferston like this.
  9. Oct 23, 2018 at 10:07 AM
    n2deep
    haha
    KevinK and ColoradoTJ[QUOTED] like this.
  10. Oct 23, 2018 at 10:08 AM
    STALKER ALERT!!!
    n2deep[QUOTED] likes this.
  11. Oct 23, 2018 at 10:33 AM
    Sefferston
    Seth
    ERMERGERD TOYOTA
    As I remember to turn mine on....
  12. Oct 23, 2018 at 10:34 AM
    Now that I have put a few more cups of coffee in my system, I really think you have a timing chain issue, or something like that.
    How many miles on your engine?
    15whtrd likes this.
  13. Oct 23, 2018 at 10:35 AM
    It's working. Now it shows a different state and city.
    Sefferston[QUOTED] likes this.
  14. Oct 23, 2018 at 10:39 AM
    15whtrd
    15whtrd Mr. Blonde
    I’m gonna take a stab at a guess here. Timing chain tensioner. Engine runs but makes noise at certain rpm’s. I would stop driving it and check that out. Hopefully it didn’t skip a tooth yet.
    Inquiringone, Randy Morton and n2deep like this.
  15. Oct 23, 2018 at 10:41 AM
    n2deep
    That sucks but hopefully its not a total engine failure. I am in the process of replacing an engine on my sons Dodge(sometimes they have to learn the hard way) Think he might buy Toyota next- haha
    NewImprovedRon and 15whtrd like this.
  16. Oct 23, 2018 at 10:46 AM
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    My SIL is a mechanic. If you're in the Tidewater area he would probably be willing to look at it.
  17. Oct 23, 2018 at 10:46 AM
    Columbiansnow
    Eddie
    2011 Tundra 4.6
    I have a 4.6 if I need to do a swap I’m going to try and find a good 5.7
    TheBeast likes this.
  18. Oct 23, 2018 at 10:47 AM
    Columbiansnow
    Eddie
    2011 Tundra 4.6
    It just hit 196k before it busted
  19. Oct 23, 2018 at 10:49 AM
    Columbiansnow
    Eddie
    2011 Tundra 4.6
    I really hope you’re right, I pulled over and had it towed to the shop as soon as I heard the snap, and It’s currently 400 miles away from me so it’s not being driven
    15whtrd[QUOTED] likes this.
  20. Oct 23, 2018 at 10:50 AM
    Columbiansnow
    Eddie
    2011 Tundra 4.6
    Could you message me his info please? Will probably be hitting him up as soon as I get the truck up here
  21. Oct 23, 2018 at 10:50 AM
    15whtrd
    15whtrd Mr. Blonde
    Please post when you figure out what’s going on. I always like to see conclusions here. Good luck sir!
  22. Oct 23, 2018 at 1:19 PM
    Columbiansnow
    Eddie
    2011 Tundra 4.6
    Alright quick update, I spoke to a mechanic who took a look at it down in SC, he confirmed the timing is way off but also says the loud knocking is something mechanical. No word on whether or not it’s the timing chain tensioner but he’ll continue looking at it tomorrow.
    15whtrd and ColoradoTJ like this.
  23. Oct 23, 2018 at 1:45 PM
    15whtrd
    15whtrd Mr. Blonde
    I would think the only reason the timing would be way off is because of the tensioner and/or it skipped a tooth. If the chain broke it wouldn’t run it all. Hopefully all your valves are good and it will just be new chain and tensioner. Might as well do the water pump while you’re in there. And any other disposable items that you have to take off to get to it.
  24. Oct 23, 2018 at 1:56 PM
    Columbiansnow
    Eddie
    2011 Tundra 4.6
    I’m hoping it’s just that and not a spun or snapped rod, my fingers are crossed hoping for the best.
    Also anyone else experience or have heard of the truck putting itself in 4lo, and traction light coming on with the check engine light? It did that last week only to find the air injection system was missing a fuse altogether and ran like a top after I put in a new fuse. And it did it again with this current issue. Is that a “limp mode” or is the ecu just wonky? (I don’t think my current problems and air injection fuse problems are interconnected).
  25. Oct 24, 2018 at 2:25 PM
    Dr_Al
    Dr_Al New Member
    Al
    if your timing is "way off" then there's a chance that you've hit a valve with a piston. On my 1st gen a mouse chewed a hole through one of the plastic covers for the timing belt and then made a nice home for his family. Well until I started the engine. At least one body got crushed between the belt and a cam gear causing it to jump two teeth. The engine would run but barely. I suspect that your chain also jumped. How did the mechanic verify that the timing was way off? Did he pull a valve cover? I would do a compression check on the driver's side cylinders.
  26. Oct 24, 2018 at 7:40 PM
    Columbiansnow
    Eddie
    2011 Tundra 4.6
    I don’t have the details on all the tests done, the only information I have so far is that the timing is off and there’s a mechanical knocking noise, but as of yesterday he hadn’t physically checked the timing chain tensioner and can’t confirm where the sound is coming from. He said he’ll continue diagnosing today but I haven’t received a phone call from him so I’m going to wait until tomorrow afternoon before I give him a call. I’m hoping the piston didn’t hit the valve but my hopes and dreams are all I have until I have more information to go off of. Will update this thread as soon as I know.
    Using a screwdriver on the block “ghetto mechanics stethoscope”, while stuck on the side of the road, The knocking is definitely louder on the driver’s side. So you might be on to something with the driver side compression. All I can do now is wait and see
  27. Oct 24, 2018 at 9:33 PM
    The 4.6L motor is an interference motor. If timing is off, good chance a valve tattooed a piston.
    Watt maker likes this.
  28. Oct 25, 2018 at 3:08 AM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
  29. Oct 25, 2018 at 1:20 PM
    Columbiansnow
    Eddie
    2011 Tundra 4.6
    Alright latest update is bad news. Rod definitely spun or snapped, and timing chain skipped some teeth. So if anyone has a low mileage 5.7 or part out truck please dm me.
  30. Oct 25, 2018 at 1:36 PM
    Well that sucks Eddie. Sorry that happened.
    So when you look for a 5.7L, make sure you get the complete harness. If not, you will be hating life with doing a transplant. You might still have difficulty even if you do get the complete harness.
    15whtrd likes this.
