Help........Normal? Or leaking?
Discussion in 'General Tundra Discussion' started by Rica25, Aug 11, 2019.
  1. Aug 11, 2019 at 12:49 PM
    Rica25
    Rica25 [OP] Got Bam? IG ......@TNDRA08
    Ricardo
    Tulare
    15655529090092983862607070064239.jpgare these ok too put back on or need replacement are they leaking?
    Raxman80 likes this.
  2. Aug 11, 2019 at 1:09 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    They look fine. Just dirty. Does it feel seized? If not, rock n roll
    Rica25[OP] likes this.
  3. Aug 11, 2019 at 1:11 PM
    Rica25
    Ricardo
    Tulare
    So that leakage is normal
  4. Aug 11, 2019 at 1:24 PM
    Raxman80
    Raxman80 New Member
    Ray
    Downey
    2018 red tundra double cab trd off road 4x4
    Custom bed rack. Roof top tent Baja designs fog lights
    As long as the boot is not ripper you are good.
  5. Aug 11, 2019 at 1:28 PM
    Darren509
    Darren509 New Member
    Darren
    Dayton NV
    2016 White Tundra TRD
    If you already have it off and that boot is not sealed then now would be a good time to replace. I dont see a zerk fitting either so any grease that’s coming out will shorten its life.
  6. Aug 11, 2019 at 1:32 PM
    timsp8
    NY
    Look for a moog. OEM are about $100, moog’s are $30.
    OR18TRD and Rica25[OP] like this.
  7. Aug 11, 2019 at 1:46 PM
    Rica25
    Ricardo
    Tulare
    15655564283273353308955996897421.jpg 15655564658492266693164767164745.jpg 1565556504696159197628107008210.jpg ordered these will be here in 2 days so for the first time I will be driving with out front sway bar ......see how it drives
    Black Wolf and T-Rex266 like this.
  8. Aug 11, 2019 at 1:54 PM
    Rica25
    Ricardo
    Tulare
    These here
    Black Wolf and NewImprovedRon like this.
  9. Aug 11, 2019 at 4:10 PM
    timsp8
    NY
  10. Aug 11, 2019 at 4:42 PM
    DM 2018 Tundra
    DM 2018 Tundra New Member
    South Carolina
    2018 Limted Tundra
    6inch RC with upgrade struts. 295/65/20 Nitto Ridge grappers 20x9 fuel vapor with 0 off set
  11. Aug 11, 2019 at 5:30 PM
    timsp8
    NY
    It’s a cheap enough part that might as well replace it while it’s off.
  12. Aug 11, 2019 at 5:31 PM
    Rica25
    Ricardo
    Tulare
    what sucks is that no one has them in stock had to ordered every place i called
  13. Aug 13, 2019 at 10:16 PM
    Rica25
    Ricardo
    Tulare
    So I installed the new Ac delco professional model front sway bar links tonight but I can not find the way to install the grease little nipple can anyone chime in?
  14. Aug 14, 2019 at 3:37 AM
    timsp8
    NY
    I thought it was just screwed in then something small like an 8mm to tighten.
  15. Aug 14, 2019 at 5:49 AM
    Darren509
    Darren
    Dayton NV
    You just start it in the hole and with a socket you self tap it in. It will cut its own threads. Just make sure to stop when it is sitting flush
    Black Wolf and Rica25[OP] like this.
  16. Aug 14, 2019 at 5:56 AM
    Rica25
    Ricardo
    Tulare
    Ok I will try that today......thanks
