Help: No heat but the AC is fine
Discussion in '2.5 Gen Tundras (2014-2021)' started by jeff0707, Jan 1, 2019.
  1. Jan 1, 2019 at 2:52 PM
    jeff0707
    jeff0707 [OP] New Member
    2015 Toyota Tundra Crewmax
    Hey guys, I'm on a road trip in my 2015 Tundra and we have lost all heat. The blower works fine, and so does the AC. Just no heat. Ambient air only when the heat is on. Thankfully we're heading to Texas, but it's not too warm there, either. No heat at the rear vents. It's an SR5 so manual dial controls, no fancy temperature control. Anyone have any issues like this? Of course it's just out of warranty:mad:
    250 miles to go and running out of sunshine, getting a bit chilly!
  2. Jan 1, 2019 at 2:54 PM
    Blueknights75
    Ron
    Clayton, NC
    Welcome from NC! Wish I could help but I can only think of checking fuses...
  3. Jan 1, 2019 at 2:59 PM
    jeff0707
    Thanks! A bit more info...it seemed to be very sensitive earlier today when it was working and one "click" of the temperature dial would cause a rather large change in temperature. I'm guessing I'll be digging after the temp control unit-we heard a clunk earlier when messing with the temp control so I image there's a loose mechanical connection in the unit.
  4. Jan 1, 2019 at 3:01 PM
    Rsnake69
    Rsnake69 New Member
    Larry
    Randleman, NC
    2007 tundra sr5 trd
    Keep an eye on you truck water temperature and check the water in the radiator. Sounds like the thermostat gone bad or water pump went out.
  5. Jan 1, 2019 at 3:03 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    This ^^^. Check and report back.
  6. Jan 1, 2019 at 3:26 PM
    jeff0707
    Truck temps are good. Temp gauge is in the normal spot.
    Just stopped for gas and checked the fuse. All looked good. No change after shutting the truck off and restarting. Looks like we'll just get home and I'll look at it in the morning. Thankfully the cold front hasn't hit yet:)
  7. Jan 1, 2019 at 3:30 PM
    I’m thinking something is not communicating with the temp dial correctly.
  8. Jan 1, 2019 at 3:30 PM
    How many miles are on it?
  9. Jan 1, 2019 at 3:36 PM
    jeff0707
    45K miles.
  10. Jan 1, 2019 at 4:33 PM
    Adriver71x
    Adriver71x New Member
    Gerald
    2015 Tundra SR5
    Tow Mirrors
    Welcome from Northeast Connecticut. Check your anti freeze
  11. Jan 1, 2019 at 5:06 PM
    Sounds like a blend door actuator. Not so common on Toyota vehicles.
    Check HVAC filter just for shitzngiggles.
  12. Jan 2, 2019 at 7:20 AM
    jeff0707
    HVAC filter is good. No shortage of air blowing, just cold. Anti freeze is good, too.
    Got home late last night after driving over 1100 miles from Ohio to Texas. The last 300 had no heat whatsoever. It was 34 degrees when we got home...we were popsicles:eek2:
    I'm going to pull the blend door actuator later today and see what I find.
    Black Wolf and ColoradoTJ like this.
  13. Jan 3, 2019 at 10:34 AM
    jeff0707
    Update: I checked the actuators and both seem to be working normally, the gears seem fine as well. I checked the coolant hoses coming into the cab behind the dash and the are nice and hot with truck warmed up. So now I'm trying to remove the blend door actuator assembly. Has anyone actually removed it? I dont see how I can do this even if I pull the entire dash apart. I can get to 3 of the 4 screws holding the assembly down, but the last one is directly behind a welded metal support. Of course whith three of the four screws removed there is enough play for various gears and parts to fall out...behind the carpet and shift console until they hit metal. Getting frustrated over this thing...I'm getting dejavue of my old Dodge:mad:
  14. Jan 3, 2019 at 10:46 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Don't start blaming Toyota just yet. I had a pen fall down the duct work in a Ford and the same thing happened. It was an older model and the HVAC door and heater core were very accessible without dash removal. Dodges and Jeeps are well known for blend door problems and it is not a cheap fix.
    15whtrd likes this.
  15. Jan 3, 2019 at 11:14 AM
    jeff0707
    On my old Dodge, the dashboard disintegrated so it was easy access:)
    I read on another forum about just drilling a hole through the metal support for the 4th screw, so I'll try that and and least get the assembly out where I can work on it.
  16. Jan 3, 2019 at 12:02 PM
    zebian2
    zebian2 New Member
    Jamy
    I take that the truck is still under warranty?
  17. Jan 3, 2019 at 12:04 PM
    jeff0707
    So I drilled an access hole and got to the temp control box. I can manually manipulate the arm for the temp control and no change. Feels like something let loose in there, no resistance.
    I normally do all my own work, but about out of options on this one.
  18. Jan 3, 2019 at 12:08 PM
    jeff0707
    And of course the truck is 6 months out of warranty. I've had 6 Toyotas in a row and they seem to be steadily growing down in quality. How they deal with this will determine if I have a 7th Toyota when I replace my wife's Camry later this year.
  19. Jan 3, 2019 at 2:01 PM
    I know your pain on the blend door access, especially on a Dodge. Pretty much have to tear the dash apart, and replace in pieces.
    If the blend door is moving when changing temp setting in cab, that should be working properly.
  20. Jan 4, 2019 at 7:07 AM
    jeff0707
    Just got a call from the dealer. They said there is a failure in the HVAC box, which I had confirmed as well. Not a serviceable item. $3000 for them to replace. Basically have to strip it down to the firewall and evacuate the coolant and AC.
    A $42k truck 6 months and 8000 miles out of warranty...they told me to call Toyota customer care. Ugh, not a good start to 2019. And we specifically stuck with the lower trim package so there would be less electronics to fail.
  21. Jan 4, 2019 at 7:47 AM
    Oh total bummer. Sorry you got bad news.
    To be honest with you, I’m glad I had a super low mileage CPO CM Tundra with the warranty. By 89k miles, I would have been 3400.00 lighter in my wallet. Now days, it almost always pays for an extended warranty. I will probably do an extended one on my GMC as well. Those repairs get expensive....and it’s a GM, so I know it’s coming.
