Help!!! My Dog chewed wires under my driver's power seat!!!
Discussion in '2.5 Gen Tundras (2014-2021)' started by Jayofryer, May 28, 2019.
  1. May 28, 2019 at 9:12 AM
    Jayofryer
    Jayofryer [OP] Tundra
    Josh
    MASSACHUSETTS
    2018 Tundra Trd Off Road CrewMax
    Ask I'll tell... more to do and more questions need answered
    Dog chewed wires and seat wont move what do I do where do I get a new wiring harness
    2018 tundra crewmax sr5 4x4trd offroad
    Help!!!!!
  2. May 28, 2019 at 9:13 AM
    Marty McFly, Roman and Black Wolf like this.
  3. May 28, 2019 at 4:27 PM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    Take out the seat and splice/fix...you can buy any plugs and associated electrical connectors/pins as needed.
    Jayofryer[OP] and G10dra like this.
  4. May 28, 2019 at 4:46 PM
    P-Factor
    P-Factor New Member
    G10dra likes this.
  5. May 29, 2019 at 6:09 AM
    Stig
    Stig New Member
    Check your fuses they likely blew
    NewImprovedRon likes this.
  6. May 29, 2019 at 7:47 AM
    speckmon
    speckmon Must. Have. Pow.
    Thornton, CO
    '07 mountain road bomber
    Buy a doggy hammock.
  7. May 29, 2019 at 8:55 AM
    BigdaddyII
    BigdaddyII New Member
    South Louisiana
    2019 Ram 1500
    Remove the seat and solder/ shrink wrap the wires that are chewed through. Replace the seat and check fuses. It should work once this process is completed. Going forward, when pup is riding in the truck, he should be restrained in a kennel or leash locked to a seat belt, not only for damage control but also for his safety.
  8. May 29, 2019 at 1:49 PM
    Jayofryer
    Josh
    MASSACHUSETTS
    I just need the wiring diagrams There are multiple wires with the same colors
  9. May 29, 2019 at 4:54 PM
    Stig
    Stig New Member
    Can't help you there but kind of hard to follow a wiring diagram if the colors are the same as you say. Maybe someone can take some pictures what it should look like.
