Help me with a build
Discussion in '2.5 Gen Tundras (2014-2021)' started by cwmoneymaker, Oct 24, 2024.
  1. Oct 24, 2024 at 8:31 AM
    cwmoneymaker
    cwmoneymaker [OP] New Member
    I could use some help with build ideas before I start. I have these parts so far.
    Trd off road double cab
    Front- fox 2.5 res w/dsc 2”
    Rear- Fox 2.0 remote res
    Coach builder 1” shackle
    Eaton rear e locker
    Rear leafs ?
    also, I like the look of the stock trd wheels, can I run 295 70 18 with chains with this setup? I don’t mind trimming if needed. Or a similar size bigger is ok. Must be able to run chains.
    Thanks! I will start a thread with the build once I start.
  2. Oct 24, 2024 at 8:59 AM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    Are you intending on running chains both front and rear? You should have no issues with the rears, but I have fought to get chains to clear with 295s on my personal truck in the past. Very little room between the UCA and sidewall.
  3. Oct 24, 2024 at 9:51 AM
    cwmoneymaker
    Yes if I have to, all 4.
  4. Oct 26, 2024 at 8:42 AM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
