HELP ME PLEASE! 2012 Tundra needs Transmission service
Discussion in '2nd Gen Tundras (2007-2013)' started by dpedreira, Mar 25, 2024.
  1. Mar 25, 2024 at 9:51 PM
    dpedreira
    dpedreira [OP] New Member
    Dave
    2012 Tundra TRD 4x
    I have a 2012 Tundra 5.7L 165,000 miles. THE TRANSMISSION is fantastic BUT it has NEVER been serviced! I spoke with the dealership, the service manager said that they transfer the fluid the correct way; by putting it on a lift and letting the tires rotate in gear to push the fluid through. I'm afraid that I will have transmission problems after the transfer because of the high mileage and lack of service. Again, it shifts wonderfully, no slippage, very responsive. Can someone give me some EXPERT advice?
  2. Mar 25, 2024 at 10:02 PM
    Radarninja
    Radarninja New Member
    Ryan
    Ca
    Just get it serviced don’t worry about it.
    if your transmission is operating properly now you should not have any issues.
  3. Mar 26, 2024 at 8:35 AM
    4x4WarriorOfRocks
    4x4WarriorOfRocks New Member
    2010 Tundra 4x4 Rock Warrior
    I just got a drain and fill done at almost 200k miles. Only had to replace 4 qts of clean new fluid. There's still plenty of "dirty" ATF in there (maybe 5 or 6 qts) to shift properly. From what I've seen on high mileage 2nd gens, drain and fill is the way to go.
    koditten and 2mchfun like this.
  4. Mar 26, 2024 at 8:37 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    We did a full flush service on our 2015 at 120k miles. Zero issues before and after.
    4x4WarriorOfRocks likes this.
  5. Mar 26, 2024 at 8:42 AM
    2mchfun
    Drain and fill only. Maybe twice 1 oil change apart. Then leave it alone.
  6. Mar 26, 2024 at 8:48 AM
    Good luck with your transmission service, drain and fill is the least invasive and least likely to create issues. Your thread title with all caps and distressful language is a bit of the boy who cried wolf. You can ask anything in these forums without the dramatics, good folks that are willing to help usually.
    Tridom and OldGuy03 like this.
