Help - LED parking light/turn signal issues
Discussion in '2nd Gen Tundras (2007-2013)' started by FloridaTundra, Oct 13, 2019.
  1. Oct 13, 2019 at 3:00 PM
    FloridaTundra
    FloridaTundra [OP] New Member
    Vero Beach, FL
    2011 Toyota Tundra CrewMax
    7" lift
    Need some advice on what parts I need next to complete my led turn signal project on the front and rear of my 2011 Tundra. I installed some 3157 led bulbs in the front turn signal locations and turned the parking lights on and they looked great. Then I hit the blinker and popped the 15a fuse under the hood. I've done a ton of searching online and from what I've gathered I need some 3157 CK bulbs in the front. So after reading all the post I put my old bulbs in and moved the 3157 led lights to the rear turn signals. The info stated that the regular 3157 leds will work in the rear. Well I made the swap and they blinked one time and never came back on. This time I got the hyper flash when the blinkers were tried.
    Question is do I need resistors at all four corners or something else?
    My truck has the 02c02 flasher relay already to delete the DRL's.
    I'm at a loss here.
    Thanks
  2. Oct 15, 2019 at 5:05 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    Most of the videos show the use of resistors. and hyperflash = resistor needed
  3. Oct 15, 2019 at 6:16 AM
    FloridaTundra
    Vero Beach, FL
    7" lift
    I contacted Super Bright Led and they recommended putting a resistor on each led. So I ordered 4 and they should arrive this week Thanks
