Help, is this factory or aftermarket spray in bed liner.
Discussion in '2nd Gen Tundras (2007-2013)' started by LennyFL, Mar 19, 2020.
  1. Mar 19, 2020 at 11:17 AM
    LennyFL
    LennyFL [OP] New Member
    New to me 2007 with 59,600 miles
    Is this Factory or Aftermarket spray in bed liner? This is a new to me 2007 SR5.
    It is really black but in central Florida it's pollen season so it looks green. Anyway did Toyota do Spray in bed liners?
    Sorry I wasn't clear. It's not the color, it's worn in some spots and I want to make sure it is sealed at the front to keep water from seeping through and rusting. Water pools in the front of the bed.
    Where can I go to get it touched up?
    Any suggestions?
    Thanks,
    Lenny
    IMG_2474.jpgI
  2. Mar 19, 2020 at 11:19 AM
    Vince
    Vince New Member
    Vincent
    Terre du lac, Missouri
    2011 White DBL cab 5.7
    K&N intake, Air bags
    Power wash it that might help...
  3. Mar 19, 2020 at 11:26 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Not sure if Toyota did any of them. Dealer applied Linex or similar. Previous owner could have had done elsewhere.
    Touch up? Color or bad spots? For color there are products to enhance like tire shines. Repair or spot issues, take to a installer and see what they recommend.
    P-Factor likes this.
  4. Mar 19, 2020 at 11:38 AM
    LennyFL
    Sorry I wasn't clear. It's not the color it's worn in some spots and I want to make sure it is sealed at the front to keep water from seeping through and rusting. Water pools in the front of the bed.
  5. Mar 19, 2020 at 11:55 AM
    Trooper2
    JR
    Hard to say. I would find someone who does Linex or similar and show/tell of your concerns.
    BravoDeltaRomeo likes this.
  6. Mar 19, 2020 at 11:59 AM
    Hoff
    Hoff New Member
    2021 TRD OFF ROAD CREWMAX
    My 2020 came from factory with Spray in Bedliner
  7. Mar 19, 2020 at 1:04 PM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    Possibly factory depending on where the truck came from.
    my 2010 came with factory product sprayed at the SET port in Jacksonville and also had the warranty card for proof.
    Does anyone know if SET or GST had spray in back in 2007?
  8. Mar 19, 2020 at 1:16 PM
    tye
    tye New Member
    tye
    2016 TRD Pro DC
    Diamondback cover, flowmaster exhaust, n-fab sliders
    I think it was done by the owner. Toyota, I think, Was labeling the front of the box with "tundra" in the liner itself. Linex puts a badge on it with the warranty info
  9. Mar 19, 2020 at 2:29 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    For 2020 Tundras, there are currently 15 accessories shown on Toyota.com, and one of those is a spray-on bedliner for $529. Accessories are typically installed either at the Distributor (port), or, for bolt-on accessories, by the dealer. The dealer orders requested accessories through the Toyota parts network, and installs them as part of the PDI.
    It's unlikely, imo, that any accessory spray-on bedliners have ever been installed at a Toyota assembly plant. If that messy, low-tech process can be farmed out to the distributors, that would be the logical choice. In your case, Southeast Toyota likely installed the bedliner, but that doesn't really matter at this point.
    As suggested earlier, take it a local bedliner shop for inspection and recommendation.
    Trooper2 likes this.
  10. Mar 19, 2020 at 2:46 PM
    PNW_Husky
    PNW_Husky New Member
    Great Pacific Northwest
    2018 MGM CM Platinum
    It looks much more like Rhino Liner to me than it does Line-x. In my experience Rhino tends to look less gritty and more rubbery.
  11. Mar 19, 2020 at 3:10 PM
    YsoSeRiouS!
    YsoSeRiouS! A good day...for a good day
    NorCaL
    2019 White Platinum CM
    Doesn’t factory come with the tundra logo on the bed..unless the dealership got the spray on after they received it at the dealership it from what I remember if it came from factory they get the raised tundra stamp on the bed
  12. Mar 19, 2020 at 3:12 PM
    YsoSeRiouS!
    NorCaL
    Does yours have tundra inside the bed under the rear window?
  13. Mar 19, 2020 at 3:14 PM
    YsoSeRiouS!
    NorCaL
    this is what I mean
  14. Mar 19, 2020 at 3:17 PM
    Hoff
    Hoff New Member
    Yes it dose
  15. Mar 19, 2020 at 3:26 PM
    JohnLakeman
    I believe that is an applique cemented in place before application of the bedliner. Not installed on Gulf States Toyota Region, and maybe also Southeast Toyota Region (Both are Private Distributorships).
  16. Mar 19, 2020 at 3:32 PM
    NCSkeeter
    NCSkeeter New Member
    2019 Silver Tundra Crewmax 4x4 1794
    TRD Rear Sway Bar, Truxedo X15 Tonneau Cover, Toyota OEM Bed Mat
    FWIW my dealer had their sister RAM dealership down the road spray mine as part of the deal. None of the Platinums or 1794s I saw had the port installed spray liner. I assume because the payload is already so low.
    I don’t have the Tundra badge in the bed like the ones done at Southeast Toyota port.
  17. Mar 19, 2020 at 5:50 PM
    Buildn
    Buildn 2022 Tundra Limited CM 6.5 Bed TRD Off Road
    Medina, Ohio
    TRD Air Filters, Front door windows tinted to match the rears. Wheel locks, Talons Garage cat shield, Tyger Automotive soft tonneau cover, WeatherTech floor mats with Tuff Skinz Custom Emblem kit, Toyota OEM Emblem Black Out kit. AVS vent covers on all four doors, Red Tundra letters on front bumper & TRD highlighted in Red on front grille. Tailgate Tundra Letters in Black.
    I have the factory sprayed liner with the Tundra badge in my 2017 up here.
