HELP! Is this a problem?
Discussion in 'General Tundra Discussion' started by monaco730, Jun 5, 2019.
  1. Jun 5, 2019 at 5:42 PM
    monaco730
    monaco730 [OP] New Member
    16 Inferno Tundra
    Fox shocks, TRD Exhaust, TRD grill, TRD shift knob, weathertech floor/bed liners, ARE topper, FrontRunnerOutfitters cargo rack, Relentless cargo bars, color matched front bumper/side mirrors, fuel wheels, nitto RGs, K&N intake
    My coilovers are hitting my sway bar "part" (I don't know the part name). One side actually rests on it. The other side is barely off the sway bar part. Is this a problem? Any suggestions to fix besides removing the front sway bar?
  2. Jun 5, 2019 at 5:44 PM
    AZTundra
    Paul
    Phoenix, AZ
    what brand coilovers are those?
  3. Jun 5, 2019 at 5:44 PM
    monaco730
    16 Inferno Tundra
    Fox
  4. Jun 5, 2019 at 5:53 PM
    AZTundra
    Paul
    Phoenix, AZ
    Did you just install the coilovers? If so, has the alignment been done? I don't think they should be that close to the point of rubbing. I believe @V-TRAIN had this issue too, but not sure what type of coilovers he was running. I think he ground a little off the sway bar link to clear if I remember correctly.
  5. Jun 5, 2019 at 5:55 PM
    AZTundra
    Paul
    Phoenix, AZ
    @TheBeast - You had a similar issue also right?....any thoughts for OP?
    TheBeast likes this.
  6. Jun 5, 2019 at 6:01 PM
    monaco730
    16 Inferno Tundra
    I installed them a couple months ago. Had the alignment done at toytec which resulted in phenomenal numbers.
  7. Jun 5, 2019 at 6:03 PM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    Definitely a problem, Start grinding or throw those bad boys in the trash !
  8. Jun 5, 2019 at 7:36 PM
    monaco730
    16 Inferno Tundra
    I believe I have these already...
  9. Jun 5, 2019 at 7:39 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Get rid of it.
    Are the misalignment spacers installed correctly at the lca shock mount?
  10. Jun 5, 2019 at 7:49 PM
    monaco730
    16 Inferno Tundra
    Yes. Large washer in front. Skinny washer in back.
  11. Jun 5, 2019 at 7:53 PM
    cmiller219
    cmiller219 New Member
    Nashville, TN
    2018 Cement CM Tundra
    Seems odd to me that fox would design something that can’t work with stock components. Shitty if you ask me. I don’t want something that makes me lose something else. I understand sometimes you have to upgrade other stuff as well but upgrading the sway in this situation will still create the same problem
  12. Jun 5, 2019 at 7:55 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Ive seen this with fox in the past. The crappy thing is that if your alignment guy tries to shift the lca back to clear sway bar, that puts the tire closer to the body mount.
    Most people run without the sway bar i would guess.
    I just went to go look at my bar with icons. I have inches of clearance. How high are your coilovers
  13. Jun 5, 2019 at 7:56 PM
    monaco730
    16 Inferno Tundra
  14. Jun 5, 2019 at 8:03 PM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    How Much lift? I’ve only seen issues with them hitting tie rods.
  15. Jun 5, 2019 at 8:07 PM
    monaco730
    16 Inferno Tundra
    Hub to fender is roughly 25 inches
  16. Jun 5, 2019 at 8:10 PM
    xtyfighterx
    Ty
    North Idaho
    Same as mine. I didn’t install those sway bar spacers.
  17. Jun 5, 2019 at 8:10 PM
    xtyfighterx
    Ty
    North Idaho
    I have about a finger worth of space between my end link and bottom of the shock. Could be an alignment thing. How much room do you have when you turn your wheels from the cab mount?
  18. Jun 5, 2019 at 8:16 PM
    monaco730
    16 Inferno Tundra
    The spacers must've been installed with the readylift kit by Toyota. Maybe I should take em off. When I watched the BDS install, they did not put away spacers on.
  19. Jun 5, 2019 at 8:20 PM
    Amnesiac
    Amnesiac When I am king, you will be first against the wall
    PDX
    2019 Superwhite TRD Sport
    Interesting. Putting Fox coilovers on next month at some point. Wonder if I will have any issue with the TRD sway bar.
  20. Jun 5, 2019 at 8:24 PM
    xtyfighterx
    Ty
    North Idaho
    Probably isn’t a huge issue. But ya maybe take them off see what happens. And if not I’m gonna say it’s an alignment thing. If nothing else is broken or damaged. Check the ball joints and cv all that stuff to cancel them out. Do you have your alignment numbers handy?
  21. Jun 5, 2019 at 8:30 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    If you take that swaybar spacer out it looks like it should shift the end links away from the coilovers.
    @Toytec Lifts you guys do alignment? o_O
    xtyfighterx likes this.
  22. Jun 5, 2019 at 8:30 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Just yank it
    Tacotundra likes this.
  23. Jun 5, 2019 at 8:35 PM
    xtyfighterx
    Ty
    North Idaho
    Yep what I’m thinking to. I don’t think those are needed till you go up to like 6” I could be wrong.
    Darkness[QUOTED] likes this.
  24. Jun 5, 2019 at 8:42 PM
    monaco730
    16 Inferno Tundra
  25. Jun 5, 2019 at 8:51 PM
    xtyfighterx
    Ty
    North Idaho
    Take those sway bar spacers off
  26. Jun 5, 2019 at 8:52 PM
    monaco730
    16 Inferno Tundra
    I would just make sure you do not install any sway bar spacer and you should be good. These spacers do not come with the coilovers.
  27. Jun 5, 2019 at 8:54 PM
    monaco730
    16 Inferno Tundra
    Yep i'm gonna do it tomorrow probably. Thank you everyone for your input. I really appreciate it. I'll report back.
    AZTundra and xtyfighterx[QUOTED] like this.
  28. Jun 5, 2019 at 8:57 PM
    They do
  29. Jun 5, 2019 at 9:21 PM
    TheBeast The Beach
    take the spacers out.
    my issue was the sway bar itself. the square part was touching the coilover. I grinded it down like the TRD sport sway bar and no issues since then.
  30. Jun 6, 2019 at 7:43 PM
    monaco730
    16 Inferno Tundra
    I got the spacers out (which are kinda heavy. Probs gonna get back 1.5 mpg and ten horsepower :burnrubber:). I now have a full finger width on the passenger side and probably half finger width on driver side. Thanks again for all the help.
    Tundyfundy and xtyfighterx like this.
