Help ICON lug recommendation, 6 Speed
Discussion in 'Wheels & Tires' started by PhillyPro, Nov 11, 2019.
  1. Nov 11, 2019 at 1:47 PM
    PhillyPro
    PhillyPro [OP] New Member
    2017 TRD Pro Cement
    TBD
    I have looked at other post and still have not found a definitively clear answer... Can someone please let me know what is the recommend lugs (black) for Icon Six speeds. Links would be great. I really appreciate the help.
    I'm gathering all material to install in the same window. I will post pictures and details to help others moving forward.
  2. Nov 11, 2019 at 2:21 PM
    TheBeast The Beach
  3. Nov 12, 2019 at 12:45 PM
    PhillyPro
    2017 TRD Pro Cement
    TBD
  4. Nov 12, 2019 at 2:00 PM
    TheBeast The Beach
    seems a bit pricey.
  5. Nov 12, 2019 at 2:49 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
  6. Nov 13, 2019 at 6:44 AM
    PhillyPro
    2017 TRD Pro Cement
    TBD
    Scuba... Thank you very much. These are to be hand tight opposite each lug prior to torquing completely to ensure wheels is centered correct? Someone brought up a concerning about the wheel being centered correctly and having a vibration at high speeds because these are not lug-centric. Make sense?
  7. Nov 13, 2019 at 9:37 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    The icon wheels are lug centric not hub centric. They will be centered by the lugs.
    OE Tundra wheels are centered on the hub to provide vibration free ride. It is okay to use lug centric wheels on a vehicle that originally comes with hub centric wheels provided the correct lugs are used.
    Lug tightening should be done in a star pattern on any wheel regardless if it is hub centric or lug centric.
    Extended thread lugs are recommended for any Tundra running aftermarket wheels because the front wheel studs are shorter compared to most vehicles. Not having enough thread engagement is a safety hazard and can cause vibrations within itself.
    The ET lugs would not center the wheel any better than non ET lugs. They simply provide more thread engagement.
    TheBeast likes this.
  8. Nov 13, 2019 at 9:44 AM
    Fourknights
    Fourknights Goin Coastal
    Georgia/Florida
    2019 sr double cab 4x4 5.7
    Coverking ballistic seat covers, dipped 4x4 emblem, intermittent wiper mod, Toyota bed mat, Toyota rear under seat storage, dirty deeds budget, icon rebound 17”, bfg ko2s 285/70/17, matte black uws low profile toolbox, grill surround painted matte black
    I emailed icon I have rebounds they are hub centric and require 60 degree acorn
    equin likes this.
  9. Nov 13, 2019 at 9:52 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
  10. Nov 13, 2019 at 10:16 AM
    Fourknights
    Georgia/Florida
    Rebounds are 110
  11. Nov 13, 2019 at 10:56 AM
    TheBeast The Beach
    the rebounds are 110mm. The six speed are 116mm
  12. Nov 13, 2019 at 10:57 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    Noted and changed my post to reflect that.
    TheBeast[QUOTED] likes this.
  13. Nov 13, 2019 at 11:16 AM
    Shaggie13
    Shaggie13 New Member
    Mitch
    Central CA
    2017 TRD Pro Tundra Superwhite
    Fifteen52 wheels, rolling on tires.
    So, can we get extended lugs at the tire place, or do we purchase separate, like the link you provided? I got a 17" by 8.5 0 offset wheel with a 110.3 hub bore, so it should be hub centric since Tundra is 110.1. Correct?
  14. Nov 13, 2019 at 11:50 AM
    Vizsla
    Vizsla pretend2send
    Do not use ET lugs on six speeds, they are not made for them, and will cause problems.
  15. Nov 13, 2019 at 12:37 PM
    PhillyPro
    2017 TRD Pro Cement
    TBD
    Vizsla.... The link Scuba provided are not the correct lugs then? All the research I have done has contradicting opinions. This the reply I received from ICON.... I don't know why I cant get a link for the correct lugs. Can someone tag ICON and see if we can please put this to bed.
    Thank you for your purchase. Unfortunately I don’t have a link I can send you. the lug’s we recommend are 60° taper acorn style lug nuts. Any local auto parts store or wheel shop should be able to source some for you. I know some of our local customers here have had good luck purchasing them thru America’s Tire. And a normal socket should work fine for you. I know some splined style lug nuts will come with a specific socket/key to be used with them as well. if you have anymore questions please let us know.
  16. Nov 13, 2019 at 12:43 PM
    Sephon
    Sephon Don't be an American't
    Northwest PA
    2020 Black Tundra TRD Pro
    Icon Rebounds w/285/75 BFG KO2’s, Coachbuilder +2
    These are what I used on my Rebounds.
    Sounds like what you need.
    equin and TheBeast like this.
  17. Nov 13, 2019 at 1:56 PM
    Cuban11182
    Cuban11182 New Member
    Hope Mills, NC
    2018 Tundra Limited
    Kings w/ adjusters, Icon Rebound with Discover AT3 LT 285/75/R17, Airlift bags, ARB dual compressor, OV Tuning,
    So we have one person suggesting ET and another suggesting non-ET...lol. I love it!
  18. Nov 13, 2019 at 2:38 PM
    Vizsla
    Vizsla pretend2send
    These are what I use with six speeds. https://sdhqoffroad.com/products/splined-lug-nut-kit?variant=15364858970147
    I wasn’t suggesting to not use them, don’t use them. They are made for regular lug nuts, not ET.
  19. Nov 13, 2019 at 2:40 PM
    Cuban11182
    Hope Mills, NC
    2018 Tundra Limited
    Well I guess I order the ones you're saying to use since the I have the Rebounds in bronze and will be getting tires in January or so. Thanks for the info and link!
  20. Nov 13, 2019 at 2:43 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    I sent them an email too. Lol
    I’ve never heard of 1 specific wheel from a certain manufacturer not needing ET lugs and I’ve sold/ installed thousands of aftermarket wheels.
    Admittedly I’ve never sold or installed a set of Six Speeds.
    I’ve reached out to Icon via email and will see what they say. I will be happy to eat crow if it is true the six speeds are incompatible with ET lugs.
    There are literally stickers on the tundra 5x150 wheels I have in stock that say “STOP. Tundra’s need ET lugs.”
    Cuban11182[QUOTED] likes this.
  21. Nov 13, 2019 at 2:45 PM
    Cuban11182
    Hope Mills, NC
    2018 Tundra Limited
    Please let me know what they say.
  22. Nov 13, 2019 at 2:46 PM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Those are the same ones I used for my Rebounds as well. A regular lug wrench won’t fit in the Rebound’s tighter wheel lug bore, but a regular long socket will. Not sure if the Six Speeds have the same narrow lug bores, though.
    I also read on here about a few who’ve broken ETs leaving just a ring around the lug, making it very difficult to remove. I had been running ETs on my Rebounds til I heard about that. I quickly switched to the acorn style sold by Wheelers. Not sure if the Rebounds or Six Speeds may have the same propensity to shear ETs, but I changed out the ETs as soon as I read about those experiences, albeit few in number.
    Vizsla likes this.
  23. Nov 13, 2019 at 2:46 PM
    TheBeast The Beach
    Icon is a bit different as far as lug nuts iirc vs other big names brands like Method etc..
    equin and Vizsla like this.
  24. Nov 13, 2019 at 9:10 PM
    Vizsla
    Vizsla pretend2send
    Haha, thousands of wheels, but never the ones we talking about? They made them for regular lugs, and not the only wheels that do. https://www.tundras.com/threads/ext...uts-for-aftermarket-wheels.29521/#post-832112
    I have 2 sets of Icon wheels.:notsure:
  25. Nov 13, 2019 at 9:55 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    Correct, thousands of wheels.
    Not sure what’s funny. I work for the 2nd busiest Discount Tire store in the country.
    People like us who buy Icons geared towards off-roading a Tundra are the 1%. Aside from that we’re not a stocking vendor for Icons. A majority of my customers come in asking for Fuels, Rockstars, or Black Rhinos. Icons simply aren’t as popular and haven’t been around as long.
    Good to know that those Enkei wheels mentioned in that thread also don’t take ET Lugs. Sucks that that guy found out the hard way. Even the wheel manufacturer in that thread said “if you can use ET lugs then use them.” and then goes on to say “they have never seen a lug nut break” like the horror story mentioned in that thread. Any competent installer should have found that out before letting the vehicle off of the lift.
    I’ve seen it once and it wasn’t on a Toyota.
    Also I still haven’t seen one thing written by Icon saying their wheels are not compatible with ET lugs.
    Not all lugs are the same. The OP in that thread said his Gorilla ET lugs work just fine with his six speed wheels and do not bottom out against the rotor.
    What brand lugs did you use that were too long for the six speeds?
    Maybe that will be better info for everyone instead of just saying “Six speeds don’t take ET lugs!!”
  26. Nov 13, 2019 at 10:15 PM
    Vizsla
    Vizsla pretend2send
    Ha, no the Gorilla ET lugs mentioned by op don’t work either, he was just lucky enough not to learn the hard way. It is what it is..., have and tested same ET lugs. Hahahaha at your discount tire comment, you the second busiest, but that’s it. Icon will not recommend any lug nut, but they tell you exactly what to buy, wait for the reply. You told everyone to buy ET lug nuts for every wheel in this thread. You are so very wrong.
  27. Nov 13, 2019 at 10:35 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    No need to get worked up or take it personal. You’re the one contradicting yourself. You said ET lugs don’t work with Six Speed wheels and then you provided a link to a thread where someone concluded the exact opposite by safely installing ET lugs with six speed wheels. And yes, if you read the email response someone else received from Icon, they do recommend a specific lug nut (refer to post 15).
    Anyway. Don’t run ET lugs. That’s fine with me. But, unless you have concrete evidence stating that all ET lugs are incompatible with Six Speed wheels, then I don’t think you can say I was wrong for recommending them.
  28. Nov 14, 2019 at 12:19 PM
    Cuban11182
    Hope Mills, NC
    2018 Tundra Limited
    Regular 60 degree lug nuts.
    equin and Shaggie13 like this.
  29. Nov 20, 2019 at 7:11 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    Here is the detailed explanation from Icon about why their wheels do not need ET lugs. “The pad thickness of the wheels is thin enough to provide adequate thread engagement between the nuts and their studs.”
    To my knowledge this is the only wheel manufacturer who takes the tundra/ Toyota stud length in to account and modifies their wheels accordingly.
  30. Feb 23, 2020 at 2:25 PM
    11CMGray
    11CMGray New Member
    So these would work correct
