Help fellows- bolt location for dash
Discussion in 'General Tundra Discussion' started by R W Mercer, Sep 21, 2022.
  1. Sep 21, 2022 at 11:08 PM
    R W Mercer
    R W Mercer [OP] New Member
    Tundra
    None
    INLD someone tell me we’re the bolts are that holds the dash in I’ve got to pull it out completely an don’t want to unwire everything I watched Toyota factory an they put it in on one piece so it should come out one piece please anyone know what to do or what book to buy
    R W thanks
  2. Sep 22, 2022 at 12:23 AM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    as far as i know the dash board is one piece but requires all the dash components to be removed first.
  3. Sep 22, 2022 at 4:10 AM
    Your question is very vague but its not going to come out in one piece. Questions like that usually lead to a "maybe I shouldn't be working on cars" scenario. What year? The 2nd and 2.5 gens have differences in how they are assembled.
  4. Sep 22, 2022 at 7:20 AM
    R W Mercer
    Tundra
    None
    It’s a 2015 dash limited I got in a wreck an I can save the interior for another cab
    The factory assembly line shows it going in one piece after being built an tested but I dant see we’re it’s bolted in
    Thanks ,RW
  5. Sep 22, 2022 at 8:15 AM
    Zolander
    Zolander New Member
    Zorro
    OffRoad
    It is bolted inside but to gain access to the bolts you have to remove the panels undearneath it. Just watch some youtube instructions on how to.
  6. Sep 22, 2022 at 8:36 AM
    R W Mercer
    Tundra
    None
    Thanks I’ve watched those but they’re only removing the panels for painting or ones I saw was I want to take dash completely out of truck
  7. Sep 22, 2022 at 9:15 AM
    Tundyfundy
    Bay Area, CA
    You have to take out most of those panels to access the dash bolts. I think mainly the ones on the sides of the dash that are covered by the door when its closed. Long and short of it is, no, it definitely doesn't just come out in one piece without disassembly of a large portion of the panels off the front of the dash. When you figure it out send us some pictures/video so we can get a better idea of how its done!
  8. Sep 22, 2022 at 10:09 AM
    Tundyfundy
    Bay Area, CA
  9. Sep 22, 2022 at 10:10 AM
    Tundyfundy
    Bay Area, CA
    Look here, you can see tha the dash is one solid piece of plastic, but there are many things in the way. you will have to remove all the pieces connected to it.
  10. Sep 26, 2022 at 9:20 PM
    R W Mercer
    Tundra
    None
    Thanks fovthe help if I had a schematic It would help
    RW
  11. Sep 27, 2022 at 3:24 PM
    Tundyfundy
    Bay Area, CA
  12. Sep 27, 2022 at 3:25 PM
    Tundyfundy
    Bay Area, CA
  13. Sep 27, 2022 at 9:10 PM
    R W Mercer
    Tundra
    None
    Yes same thing I just can’t find anything showing what I gotta do to take out but the Toyota factory shows it going in almost complete I don’t understand it
