Help - exhaust off-road damage
Discussion in '2.5 Gen Tundras (2014-2021)' started by An701904, Oct 26, 2021.
  1. Oct 26, 2021 at 6:30 PM
    An701904
    An701904 [OP] New Member
    2021 black TRD Pro
    hi all! I took my new TRD pro offroading this weekend, it as awesome! I had a blast!
    While it was my first time, I had some help from friends to guide me through the experience.
    I did make a mistake one that led to my bed step ripping off (which isn't a big deal) but more importantly I noticed my left exhaust is a little closer to the bumper now. You can see the movement on the hanger here, about an inch.
    Anything I should be worried about with this movement? Anything "upstream" that could be impacted by the movement?
    247753729_878396456208806_44424374328031_23281e3bb98d5c51e54134eaf2c24d59f3af430a.jpg
  2. Oct 26, 2021 at 6:47 PM
    Kanobi13
    Kanobi13 New Member
    Have you tried realign it? It just hangs on by the rubber mounts. Pic of the rear showing the difference?
  3. Oct 26, 2021 at 6:55 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I nailed my passenger side tip on a rock a while back and ended up bending the bed panel a bit, along with tweaking the exhaust pipe quite a bit like yours. You can probably get it to bend back, but I wouldn’t worry about it too much. You can always just dump the pipes after the axle too…
  4. Oct 26, 2021 at 7:32 PM
    An701904
    2021 black TRD Pro
    Just moving this with my hands doesn't seem to budge it. You can see the difference here.
    BmUMVjknVhbrUJHawly1WaRVZzBA88_liCyRYeiw_b7f83890f9bda352b16cd42b16019bff99454eb3.jpg
    RwTWEmG6FgRnav_laG8lfCj1mtlKTTMRBcTdTJvh_063dfb80fd119d820400ab8e59bb559d43b2dd9a.jpg
  5. Oct 26, 2021 at 7:34 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    It’ll need some force to bend it back. I’d use blocks or a jack, or take it to a muffler shop. Shouldn’t be expensive to have them bend it.
  6. Oct 26, 2021 at 7:36 PM
    eick
    eick New Member
    2020 CrewMax TRD Off Road
  7. Oct 26, 2021 at 7:36 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    This is the correct answer.
    Sumo91 and AZBoatHauler like this.
  8. Oct 26, 2021 at 8:13 PM
    An701904
    2021 black TRD Pro
    wonder since I am still under warranty if I could get the dealer to do it too.
    Thanks for the advice.
    FWIW it rides great, sounds just as amazing as always!
    TRDFerguson[QUOTED] likes this.
  9. Oct 26, 2021 at 8:15 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    It doesn’t hurt to ask, but I don’t think they’ll do the repair for you. Definitely don’t tell them you were off road when it happened lol.
    GODZILLA likes this.
  10. Oct 26, 2021 at 8:20 PM
    18" TRD Off Road Wheels
    You can ask, but they'll say no. Warranties are to cover manufacturing defects and such. This was damage caused use, and won't be covered under warranty. If your dealership can figure a way to wrangle it into being covered then you've got a dealership that loves you! lol
  11. Oct 26, 2021 at 8:24 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    I had this happen to me a few months back. Nothing upstream was affected. The exhaust pipe started to vibrate against one of my shackles. I stuck a piece of pipe inside the exhaust and was able to pry it back down (with a little force) and away from the shackle.
