Help, Does This Tundra Have a Tow Package?
Discussion in 'Towing & Hauling' started by GulfCoastFoiler, Nov 27, 2021.
  1. Nov 27, 2021 at 11:44 AM
    GulfCoastFoiler
    GulfCoastFoiler [OP] New Member
    Greetings,
    I am looking at a 2008 4.7L 2wd Tundra for sale online. The attached window sticker says 8100lb towing capacity, which if correct, means it has the two package. Dealer's ad also says tow package. BUT, looking in front of the shifter as shown in the picture, there is no tow/haul switch, just a square hole. Isn't the lack of this switch a dead give away there is no tow package? Or would that switch be in another location? Any help appreciated, thanks.
  2. Nov 27, 2021 at 12:08 PM
    Buckaroo
    Buckaroo New Member
    Central Ohio
    2017 Tundra 5.7L 4WD DC TRD
    2020 GD 2670MK Travel Trailer
    I think you are right - no tow/haul switch, no towing package. Just to clarify, it is located on the dash down low just to the left of the shifter. But, you can key the VIN into this website and it will tell you all the factory optional equipment on this truck....
    https://www.toyota.com/owners/my-vehicle/vehicle-specification
  3. Nov 27, 2021 at 12:28 PM
    GulfCoastFoiler
    Thanks for the replies. Below is a copy and paste from the vin check. No mention of a tow package. Does have A/T cooler though, which apparently is put on vehicles without tow packages.
    • Mechanical & Performance
      GVWR = 6700 lbs. Payload = 1520 lbs. Tow Capacity = 8100 lbs. 271HP/313 Lb-Ft 4.7L DOHC 32V V8 w/VVT-i 5-Spd Automatic Trans w/Sequential Shift Engine Immobilizer, Cruise Control Tow Equip: Hitch Receiver, Supplemental A/T Cooler, 4.10 Rear Diff w/9.5" Ring Gear, 130A Alternator, A/T Temp Gauge, 7 Pin Connector, Trailer Brake Controller Prewire Automatic Limited Slip Diff (Auto LSD) TripleTech Frame: Fully-boxed Fr Section Reinforced C Under Cab, Open C Under Bed Coil Over Shock Double A-Arm Front Susp Multi-Leaf Trapezoidal Rear Suspension 18" Alloy Wheels w/P275/65R18 Tires
  4. Nov 27, 2021 at 12:40 PM
    Buckaroo
    Buckaroo New Member
    Central Ohio
    Hard to read the window sticker but I don't think they ever say it has the tow package....just towing equipment, like the VIN description says.....
  5. Nov 27, 2021 at 12:40 PM
    cat3
    cat3 New Member
    2010 Tundra SR5
    Just FYI, my 2010 Tundra has factory tow package and 4.10 diff:
    2010 Tundra TUNDRA GRD
    DOWNLOAD FULL SPECS
    • Model2010 Tundra
    • GradeTUNDRA GRD
    • ExteriorSlate Metallic(1f9)
    • InteriorBlack
    • Engine8-CYL
    • Body TypeExtended
    • Drive Type2WD
    • Transmission6AT
    • Selling DealerAutoNation Toyota Weston
    • Servicing DealerNone Selected
    • Date of First UseJanuary 11, 2010
    ADDITIONAL VEHICLE DETAILS
    Order Date:
    09/2009
    Plant of Manufacture:
    Body Style:
    DBL CAB 5.7L V8
    Tire Make/Brand:
    Tire Size:
    18R255
    Spare Tire Brand:
    PORT OR FACTORY INSTALLED EQUIPMENT
    DZ AM/FM/MP3 CD, 6 Speakers and Aux Input , Satellite Radio Capability (Requires XM or Sirius Compatible Receiver and Monthly Subscription) Factory
    FE 50 State Emissions Factory
    MG Front and Rear Mudguards Factory
    ST 18" Styled Steel Wheel with P255/70R18 Tires Factory
    TO Tow Package Factory
    STANDARD INSTALLATION EQUIPMENT
    • Safety
      STAR Safety System: 4 Wheel ABS w/ Electronic Brake-force Distribution (EBD), Brake Assist, and Vehicle Stability Control with Traction Control (VSC+TRAC) Dr & Fr Pass Advanced Airbag System Dr & Fr Pass Seat Side Airbags Dr & Fr Pass Knee Airbags Roll-Sensing Curtain Airbags (RSCA) Dr & Fr Pass 3pt Seatbelts w/Pretensioners & Force Limiters Tire Pressure Monitoring System
    • Interior
      40/20/40 Front Bench Seat w/8-way Dr & 4-Way Fr Pass Adj, Center 3pt Seatbelts Dual Zone Climate Control w/Sync Mode AM/FM/MP3/CD w/6 Speakers & Aux Input Tilt Steering Wheel Power Windows/Door Locks/Mirrors Cloth Trimmed Seats Remote Keyless Entry System Variable Intermittent Windshield Wipers Manual Headlamp Adjust
      5.7L iFORCE V8 DOHC 32V Dual Independent VVT-i 381HP/401 lb-ft and ACIS 6-Spd Automatic Trans w/Sequential Shift GVWR = 6900 lbs. Payload = 1745 lbs. Max Tow Cap = 8600 lbs. Engine Immobilizer, Cruise Control TripleTech Frame: Fully-boxed Fr Section Reinforced C Under Cab, Open C Under Bed 4.10 Rear Differential w/10.5" Ring Gear Automatic Limited Slip Diff (Auto LSD) Coil Over Shock Double A-Arm Front Suspension w/Stabilizer Bar Multi-Leaf Trapezoidal Rear Suspension Pwr 4 Wheel Disc Brakes, 13.9" Fr Rotors 18" Steel w/P255/70R18
    • Exterior
      6.5' Double-Walled Bed w/Tailgate Assist
    Tundra2n3 likes this.
  6. Nov 27, 2021 at 1:07 PM
    GulfCoastFoiler
    Had a look again at the vin check. All it says in the section called, "Port or Factory Installed Equipment" is "FE 50 State Emissions". So I think pretty much confirms that this Tundra for sale does not have the tow package. Thanks for all the replies.
  7. Nov 27, 2021 at 1:52 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Here is my 2014 sticker.
    Clearly states what is in the tow package, but doesn't really call it a 'tow package'. :rolleyes:
  8. Apr 27, 2022 at 8:30 AM
    Chilly_Winston
    Chilly_Winston New Member
    '04 Tundra Access Cab V6
    Don't mean to hijack or resurrect an old(ish) thread, but just a hat tip, fist bump, [insert 'whatever form of manly expression you wish' here] for this golden nugget of information. Brand new to Tundra's and was wondering what spec my new to me '04 Tundra AC was, however it didn't come with much in the way of information, so thank you.
    Bammer and texasrho83 like this.
  9. Aug 8, 2024 at 10:19 AM
    KingKong
    KingKong New Member
    Asher
    2008 Super White Double Cab Long Bed 4x4
    Another resurrections of this thread, but to correct some misinformation. The truck in question does have the factory tow package. Because it has the 4.7 2UZ, the rear axle is a 9.5" instead of the 10.5" that comes with the 5.7 3UR. The 9.5" axle has two factory ratios. 3.90:1, which was for trucks without the tow package, and 4.10:1, which was for trucks with the tow package. Since this truck has a 4.10:1 ratio and a 4.7, it does have the tow package. The transmission cooler is another indicator.
    The "Tow/Haul" mode button was a feature available only with the AB60E/F transmissions behind the 5.7s. Tundras with the 4.7 have the A750E/F transmission and do not get this feature.
    This info is specifically for early 2nd gen Tundras with the 4.7 2UZ engine.
    Retired...finally likes this.
