Help diagnosing Rubbing Sound coming from Engine (1st Gen)
Discussion in '1st Gen Tundras (2000-2006)' started by SunMountain505, Jul 24, 2024.
  1. Jul 24, 2024 at 9:18 AM
    SunMountain505
    SunMountain505 [OP] New Member
    Hey All,
    I have a 2004 Tundra 4.7 DC and noticed a rubbing sound coming from my engine today. Seems to be coming from the front of the engine. It increases with engine speed. Was thinking maybe a maybe a pulley or bearing for the fan? Any ideas where it's coming from?
    Here is a video of the sound
    https://www.youtube.com/shorts/Gzxk9IRTIks
  2. Jul 24, 2024 at 10:53 AM
    Sounds like a bad (dry) bearing.
    Pop off serpentine belt. Spin each bearing to figure out which it is.
  3. Jul 24, 2024 at 4:04 PM
    SunMountain505
    Thanks @shifty` I did that and the Tension Pulley bearing sounds dry for sure. After I put the belt back on the sound seems to have gone away, but I also noticed that there is a bit of play in the Fan Pulley (it has a 1/4 in hop up and down) and I'm wondering if maybe the fan pulley bracket is going. Is a wobble on the fan pulley indicative of an issue with the bracket? The clutch seems to be fine. Here's another photo to the movement I'm seeing.
    https://www.youtube.com/shorts/uddumjjRooE
  4. Jul 24, 2024 at 5:02 PM
    It does look a little askew, doesn't it? With regard to the fan clutch, if the truck is off and cold, grabbing a fan blade like you're going to give it a good spin for a couple of rotations, does it actually spin a couple rotations or spin for less than a full rotation? If you grab the fan itself, any play in it?
  5. Jul 25, 2024 at 7:05 AM
    SunMountain505
    @shifty` it spins about a blade or two.
  6. Jul 25, 2024 at 8:17 AM
    Well, sounds like the fan clutch is good at least.
  7. Jul 25, 2024 at 1:30 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Yeah, when my fan clutch went out it made more of a woo woo WOO WOO woo sound. That thing sounds like a diesel tundra.
    Bmktw2 likes this.
  8. Aug 1, 2024 at 11:03 AM
    SunMountain505
    It was the Fan Pulley Bracket. Bearing had gone, and warped the post.
    w666 and shifty` like this.
