HELP! Dash lights flash with turn signals / hazards....
Discussion in 'Electrical' started by DanielPaul, Sep 5, 2021.
  1. Sep 5, 2021 at 7:57 PM
    DanielPaul
    DanielPaul [OP] (0\(53)/0)
    Daniel
    Prescott, AZ
    2016 Toyota Tundra CrewMax 4X4 TRD SR5
    Method NV Wheels, 33" Duratrac Tires, Bilstein 5100's, Amp Steps, Rough Country Bed Cover, Auto Headlight Switch, White Front Bumper Caps, TRD Grille, TRD Skid Plate, Fortin Remote Start, Toyota QI Charger Pop & Lock Tailgate Lock, LED Bed Lighting, VooDoo Bed Rack, Pendaliner Bed Liner
    I recently noticed that when I use my turn signals (while the headlights/running lights are off) some of my dash lights blink with the turn signals. When I use my hazards, my license plate lights will blink along with the dash lights too. My truck does have a few aftermarket electrical accessories, but they've all been installed for some time before I noticed this issue.
    Pertinent electrical accessories are...
    -OEM "auto" headlight switch
    -Fortin remote start
    -LED running and brake lights (turn signals are OEM incandescent)
    -OEM LED headlights
    I've tried swapping out led bulbs for incandescent, no change.
    I've tried unplugging the auto headlight switch and using the hazards, no change.
    I've unplugged the hot lead for the DRL, no change
    I've also contacted Fortin who stated it's not possible for their unit to do this.
    I was told that it could be an issue with the trailer plug or trailer plug module, but I don't even know where to start with that. I've included a link to a YouTube video of the issue for further clarification. If anybody has run into this issue or can offer some advice I'd greatly appreciate it. Thanks!
  2. Sep 15, 2021 at 2:03 PM
    DanielPaul
    Daniel
    Prescott, AZ
    Anybody?
  3. Sep 15, 2021 at 4:22 PM
    That's crazy...and it does it all the time?
    Aellis likes this.
  4. Sep 15, 2021 at 4:33 PM
    oems1794
    oems1794 New Member
    Dustin
    Belleville, IL
    2017 Tundra TRD Off-Road
    DV8 Front and Rear Bumpers DV8 12,000 LB Winch 20" LED light bar 6x Round LED lights 3" Rough Country lift 20" Fuel Vector wheels 33" Nitto Ridge Grappler tires
    I had this happen when I installed the 2020 OEM PRO headlights some time ago. It is because there is a wire in the factory harness that isn't in the right place when it is connected to the headlight harness. When I got done installing mine it was 4:55 in the afternoon and the store in which I bought them closed at 5pm and even though I called them right at 5, they were still very helpful. I don't know who you purchased your OEM LEDs from but call their service department and explain exactly what wires are connected to factory harness and they will tell you exactly which ones to switch.
    I hope this helps.
    DanielPaul[OP] likes this.
  5. Aug 3, 2022 at 11:24 AM
    Aellis
    Aellis New Member
    Alex
    2014 tundra
    Oem headlights and tail lights
    Hi I am having that same problem can you help me on what wires are wrong thank you
  6. Aug 17, 2022 at 7:42 AM
    Aellis
    Aellis New Member
    Alex
    2014 tundra
    anyone know why my lights on my plates flash with turn signals
  7. Aug 22, 2022 at 5:57 PM
    TrainerRobot
    TrainerRobot New Member
    New York
    2016 Inferno TRD Off Road
    I had this issue when installing led lights in the taillights. It ended up being the wiring in one of the led lights that had bad ground. Had to take each one out one by one to determine the source.
  8. Nov 24, 2022 at 1:54 PM
    DanielPaul
    Daniel
    Prescott, AZ
    Thanks for the reply, I'll check for continuity this weekend.
  9. Apr 12, 2023 at 2:55 PM
    Trbulntser
    Trbulntser New Member
    Saw how old this post is but has no resolution just wondering if anyone has figured out the problem I have the same issue with a 2015 tundra SR5 4x4 have been trying to figure it out the last two days
  10. Apr 12, 2023 at 7:26 PM
    DanielPaul
    Daniel
    Prescott, AZ
    I never did figure it out. Thanks to the insane gas prices I ended up parking the Tundra for a while, so it's been out of sight, out of mind.
  11. Apr 16, 2023 at 9:25 AM
    Trbulntser
    Just an fyi I've been trying to figure it out and using a friends Tundra that works normal I looked at and switched bulb sockets, flasher relay, body control module, hazard switch and turn signal switch assemblies, checked ground connections and junction blocks to no avail.
  12. Apr 25, 2023 at 3:31 PM
    tyr0981
    tyr0981 New Member
    07 TRD Tundra 5.7
    Head unit, sub's , components, front / back camera's, too many lights to mention, dual battery, winch / bumper, TRS projector headlights, roof nest hard-shell, integrated backup spot lights, vault, all aluminum radiator / water pump, tailgate storage, plenty of dents and scratches
    I noticed this EXACT problem a ~week after i had purchased my 2007 SR5, some clown LITERALLY crossed the wires on my left headlight of the blinker & marker (parking) lights :crazy:. they wires are color coded so just have a look and it'll be obvious, my dash lights slightly blinked with my left blinker.... :rant:
  13. Nov 6, 2023 at 1:21 PM
    Noclue
    Noclue New Member
    2016 white tundra sr5
    Has anyone figure this out? Im having the same issue on my 16. But once I turn my lights on the interior lights stop blinking.
  14. Feb 4, 2025 at 5:03 PM
    mfelton18
    mfelton18 I'M THE PROBLEM
    South Central Texas
    2014 Magnetic grey SR5 4x4 crewmax
    Eibach Stage 2, RCI armor, Method 705
    Well, This seems to be common issue. I am currently experiencing the same thing with a 2014 tundra with the OEM LED headlights installed. Have had them installed for 2 years and this just started a few days ago. Not quite sure how to go about figuring out a bad ground with these. Might look into the wiring plug converters and try new ones. Anyone figure this out?
