Help COLLISION SENSOR
Discussion in '2.5 Gen Tundras (2014-2021)' started by alvi4az, Jan 1, 2020.
  1. Jan 1, 2020 at 8:34 AM
    alvi4az
    alvi4az [OP] New Member
    Hi I’m new to this but I’m hoping I can get some answers here. I lifted my 2019 Tundra, it’s a BDS 7 inch lift. Well now my collision sensor, ABS, traction are off and has the dash lit up. Also my speedometer, odometer, and gas gauge are not working! I went to Toyota and they said they can’t help me cause it’s an aftermarket lift kit. Idk what to do at this point.
  2. Jan 1, 2020 at 9:01 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    If you’re having an issue it really should only be the pre-collision sensor turning off because it’s not aligned properly. Maybe the guys broke the ABS sensors or something doing the lift. Did they put any extension cables on the brakes or anything?
  3. Jan 1, 2020 at 9:45 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Where are you located?
  4. Jan 1, 2020 at 9:54 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    A sensor is broke or unplugged somewhere related to the abs or speed sensor. Those have nothing to do with the PCS which would only be one light on the dash indicating a malfunction. At 7” of lift, you may not be able to get the PCS recalibrated since it’s only enough adjustment for up to 3” of lift.
  5. Jan 1, 2020 at 10:20 AM
    NOLA Tundra
    NOLA Tundra Sandbagging
    Jesse
    2019 Quicksand CM
    3” level leds all around Morimoto headlight and fog light bulbs Flowmaster American Thunder
    Check to see if the wire clips are in fully on the back of the wheels. upload_2020-1-1_12-17-48.jpg After I did my lift my dash was lite up to it was one of this clips not in all the way, but with 7” I’m sure those lines would have to be extended.
  6. Jan 1, 2020 at 10:22 AM
    Blueknights75
    Ron
    Clayton, NC
    Welcome from NC!
  7. Jan 1, 2020 at 10:29 AM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    Go back to the people that lifted your truck and tell them to do it the correct way.
    If you did it then as others said. Check all the connections.
    Pics under it etc would help as well.
    Most are more visual when trying to troubleshoot
    GODZILLA likes this.
  8. Jan 1, 2020 at 10:34 AM
    Welcome from NY.
    The TSS has to be recalibrated, like others have said bring it back to who did the lift to correct the other issues.
  9. Jan 1, 2020 at 10:49 AM
    silverhack
    silverhack New Member
    Sacramento, CA
    2018 CrewMax Inferno
    The collision sensor would definitely be affected by a 7" lift, but that would just show the 'Radar unavailable' message on the screen and/or the PCS warning light on the dash. It would not affect the odometer, speedometer, gas gauge. Most likely one of the cables in the rear is unplugged/disconnected.
  10. Jan 1, 2020 at 11:35 AM
    alvi4az
    I’m in Arizona, just right outside of Phoenix
  11. Jan 1, 2020 at 11:37 AM
    alvi4az
    i thank you all for the information and quick responses. When I get out of work I will surely check those clips and wires. I’ve been so stressed out the last week.
  12. Jan 1, 2020 at 11:39 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    Hit up Ben at AZ Toy Pros, he can help.you get this squared away 100%!
    5205288100
  13. Jan 1, 2020 at 12:47 PM
    alvi4az
    Thank you so much! I will call right now
  14. Jan 1, 2020 at 12:50 PM
    Danman34
    Danman34 New Member
    Danny
    pretty positive they won’t answer lol.
  15. Jan 1, 2020 at 1:20 PM
    alvi4az
    Really? Why is that? Are they closed or they just never answer?
  16. Jan 1, 2020 at 1:21 PM
    18" TRD Off Road Wheels
    Today is a holiday. Probably gonna be closed.
  17. Jan 1, 2020 at 1:29 PM
    Danman34
    Danman34 New Member
    Danny
    its a national holiday lol
    alvi4az[QUOTED][OP] likes this.
  18. Jan 1, 2020 at 1:42 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    And Welcome as well!
    I'm located in Chandler myself, if you have FB check out Arizona tundras group there. Lots of locals, events and wheeling trips to be had!
  19. Jan 1, 2020 at 1:51 PM
    alvi4az
    Hahahaha I forgot it’s a holiday since the company I work doesn’t recognize anything but Christmas
  20. Jan 1, 2020 at 1:54 PM
    Danman34
    Danman34 New Member
    Danny
    I feel ya. I use to work in Oil & Gas where no holidays existed. Lol.
  21. Jan 1, 2020 at 5:26 PM
    alvi4az
    I checked out the line and clips, everything looked good and secure
  22. Jan 2, 2020 at 4:58 PM
    NOLA Tundra
    Jesse
    2019 Quicksand CM
    Any update on the situation?
  23. Jan 2, 2020 at 5:03 PM
    alvi4az
    No I have not had any luck. I tried calling that business today but no lunch there, all the wires and clips look good. Idk what to do.
  24. Jan 2, 2020 at 5:39 PM
    NOLA Tundra
    Jesse
    2019 Quicksand CM
    Did you do the lift or a shop? Because if it’s any reputable shop they should take the responsibility. But if you did it best thing you could do is unfortunately take everything off and if you still have the problem take it to another dealership if possible and play stupid, you don’t know what happened all of a sudden the dash lite up. Just a suggestion.
  25. Jan 2, 2020 at 6:07 PM
    alvi4az
    A shop did it but they said they don’t offer warranties. We’ve always taken our vehicles to them and never had a problem until now.
  26. Jan 2, 2020 at 6:59 PM
    NOLA Tundra
    Jesse
    2019 Quicksand CM
    So everything was fine out of the shop, it’s something that happened after riding around? If so then it’s got to be a lose, disconnected, or broke cable I’m not 100% sure but going 7” would probably stretch most of the cables/hoses to the max. I know for sure on mine with 3” the front brake lines don’t look like they can go much more. Maybe someone on here can confirm if you need extensions on cables/hoses with a larger lift.
  27. Jan 3, 2020 at 3:20 AM
    alvi4az
    no when I picked it up was lit up like a Christmas tree.
  28. Jan 3, 2020 at 3:28 AM
    timsp8
    NY
    Other people have the same lift and no issues, so it’s something specific they messed up on your truck. It should be fixable, just have to find the issue. I’d go back and complain some more to that shop. I wouldn’t even want to pay them. Did you show them before you left when you picked it up? Try to call another 4x4 shop to see if someone else will look at it.
  29. Jan 3, 2020 at 4:53 AM
    NOLA Tundra
    Jesse
    2019 Quicksand CM
    Bro I would blast them on social media call the better business Bureau that’s totally on them.
  30. Jan 3, 2020 at 5:05 AM
    CourtJester
    CourtJester New Member
    Alabama
    2019 Tundra TRD Pro, 2015 Tacoma
    That's messed up. If they broke it, they should be responsible for fixing it. That's not warranty work. If it was fine when you dropped it off and jacked up when you picked it up, I'd talk to an attorney. Not that it's worth a court and such, but most places will make it right after a phone call or a letter from an attorney. At least push for a refund.
