Help build my 03 access cab
Discussion in '1st Gen Tundras (2000-2006)' started by 302 Tundra, Apr 23, 2023.
  1. Apr 23, 2023 at 9:42 AM
    302 Tundra
    302 Tundra [OP] New Member
    2003 Access Cab TRD 4x4 4.7
    So I have a 2003 tundra ac 4.7 stock everything and am looking to fit 315/75/16 or 315/70/17 I am planning on getting JBA uca and bilstein 5100s with 2887 OME springs as well as a 1.5 in aal in rear will this fit the tires I know I will need spacers I just want to know how bad it will rub.
  2. Apr 23, 2023 at 11:26 AM
    Casper421
    In the woods
    06 DC
    35’s won’t fit, look into running 285’s.
    bmf4069 and 302 Tundra[OP] like this.
  3. Apr 23, 2023 at 11:28 AM
    Elevatorguy
    Elevatorguy Yotas and JD Green!
    James
    05 DC, 4.7, 4wd, LSD.
    You’ll need gears too in addition to the not fitting.
    bmf4069 likes this.
  4. Apr 23, 2023 at 12:47 PM
    302 Tundra
    Okay I ended up going 2885s 285/75r16 no aal JBA UCA on some mr315s thanks man
    Schcoman likes this.
  5. Apr 23, 2023 at 6:44 PM
    shifty` All my rowdy friends have settled down
    You may find you sit high in the front w/2885 on access cab, even with the added weight of 4WD. 2887 would've been laughably so, good thing you didn't go there.
    Throw a couple hundo miles on the new suspension, give it time to settle out before making changes. Measure center up hub to edge of wheel well before/after on all four wheels before lifting so you have a baseline.
    You can always AAL later if you find things aren't sitting how you want.
  6. Apr 24, 2023 at 3:24 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Post up pics when it's done!
  7. Apr 24, 2023 at 6:33 PM
    Mr Badwrench
    Mr Badwrench New Member
    You'll need new CV shafts too. Even if you are planning on a small diff drop, your stock CV's will not last.
  8. Apr 24, 2023 at 6:42 PM
    Casper421
    In the woods
    06 DC
    I would love to see your evidence on this statement!
  9. Apr 24, 2023 at 6:54 PM
    Beat me to it :rofl:
    Mr Badwrench likes this.
  10. Apr 24, 2023 at 7:03 PM
    302 Tundra
    lol that’s funny the stock CVs will last
    Mr Badwrench[QUOTED] likes this.
  11. Apr 24, 2023 at 7:56 PM
    Mr Badwrench
    I put a leveler (2.5 front, 1.5 rear) on mine after 22 years and 170,000 miles. The inner CV boots ended up tearing and puking the grease everywhere. Both sides. It ended up being the same price/headache to just replace them both with longer CV's.
    lol I am not trolling you guys. It happened to me, and it made me really really unhappy. :rain:
    I went with the NAPA heavy duties. I hope OP has slightly better luck than me, because I was exceedingly displeased.
  12. Apr 24, 2023 at 8:23 PM
    Casper421
    In the woods
    06 DC
    So the boots failed, not the cv “shaft”? There’s a big difference. Boots are rubber and do have a lifespan. A cv axle will last longer than the vehicle. Boots don’t normally tear, they slide off their perch due to old clamps and eject grease. Your boots were most likely compromised before you added the spacers.
    Hold on, you put “longer” cvs in? How is that possible? Total chaos LT axles?
  13. Apr 24, 2023 at 8:29 PM
    The Napa HD are supposed to have more “reach” or extension to them, but they are the same length as factory. When lifting the front end, the factory boots need better clamps or they will pull away and sling grease. No one needs a diff drop, they do more harm than good.
    Mr Badwrench and Casper421 like this.
  14. Apr 24, 2023 at 8:37 PM
    Casper421
    In the woods
    06 DC
    So not only are they from Crapa but they’re weaker due to a slip yoke? I’ll stick with oem, hasn’t let me down in 5 years.
  15. Apr 24, 2023 at 8:39 PM
    Mr Badwrench
    NAPA HD's are what I used. The site said they would be a little better for mildly lifted trucks, so I picked them up. After 22 years, my CV boots were just weathered... I figured OP may be in the same situation since his truck is about the same age.
    The clamps actually held up okay, the boots split when I articulated the suspension. They both split at the same time, or about, and tossed grease everywhere underneath.
    I *might* have a picture, I'll post it.
  16. Apr 24, 2023 at 8:40 PM
    Mr Badwrench
    No slip yoke, I was talking about the cv's up front.
