Help: BSM and RCTA malfunction
Discussion in '2.5 Gen Tundras (2014-2021)' started by Stocky Balboa, Mar 29, 2021.
  1. Mar 29, 2021 at 4:17 PM
    Stocky Balboa
    Stocky Balboa [OP] New Member
    OC , CA
    2018 Limited TRD 4x4 CM - Cement
    Minor stuff- Tint, rear sway bar , pedal commander, TRD drop in filter DD Exhaust, Bilstein 6112/5160, stealth 32” lightbar, Cali Raised Offroad fog light replacements.
    Hello,
    Ref: ‘18 Limited
    Recently changed my stock mirrors to some aftermarket tow mirrors. Immediately the tow mirrors threw a bsm and rcta malfunction lights. Went back to stock and the same malfunction lights are on.
    Driver side bsm light does not illuminate on start up.
    What I’ve done:
    Disconnected the battery- no change
    Cleared the codes but they come back after a restart or cycle the on off functions.
    Rechecked the mirror harness connection. No change
    Any ideas?
    Is there a sensor in the mirror to replace?
    Doomed to visit the dealer?
    Thank you,
    James
  2. Mar 29, 2021 at 4:22 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Only indicators in the mirrors. Sensors are in the rear bumper, one in each corner.
  3. Mar 29, 2021 at 4:30 PM
    Check the pins on the connection, maybe they bent or not sitting right.
  4. Jun 16, 2021 at 9:06 AM
    Fatboy841420
    Fatboy841420 New Member
    Michael
    2018 Tundra SR5 crewmax
    Fab4 front bumper premium/BDS 7” adjustable coil over lift/ rear tail light/ tow mirrors/ 13.5 JL Audio stealth sub and JL C5 component speakers
    So have you found a solution to the problem. I’m having the exact same issue. Was getting ready to throw stock mirrors back on to see if it would reset the malfunction lights for theRTCA and BSM but after reading your thread I don’t know what to do next!!!
  5. Nov 15, 2022 at 4:52 PM
    GlockPHX
    GlockPHX New Member
    Tundra SR5 2018
    Hi
    Did anyone found a solution to this?
    2018 tundra sr5
    After install aftermarket mirrors everything worked good for couple weeks but then I get the same issue as Stocky Balboa.
    And now the led on the driver side illuminates when the ligths are on
  6. Jan 16, 2023 at 8:34 PM
    Grizzly660
    Grizzly660 21 Army Green Sport
    North Dakota
    2021 Army Green Sport
    20 inch XD Hoss wheels with Nitto EXO Grappler Wetokole seat covers
    Bringing this thread back. I just installed some aftermarket tow mirrors and got the BSM and rear cross traffic malfunction. See dealer. On 21 sport
  7. Jan 18, 2023 at 10:25 AM
    youcandoit
    youcandoit New Member
    2020 Black Tundra Limited Double Cab
    Update **** Did not fix it, I just turned on my headlights and my little yellow indicator came on, but not the running lights. Not sure what the next step will be, I just spent the afternoon running the white and grey wires for the spotlights so I can hook them to the cargo light.****
    Previous Message
    Nice looking mirrors. I just finished writing my review on Amazon. I had the same exact problem. I have a 2020 Limited, Double Cab and I installed Akkon Tow Mirrors. I received the same message. I found the fix of swapping the pins 9 & 18 (Toyota's) / 1 & 10 (Akkon's) made a quick repair. It fixed the issue and the message went away when I restarted the truck. I made the repair with the Akkon wire's because there was more wire than what was prior to the Toyota pin. Good luck and I hope this helps.
  8. Jan 20, 2023 at 12:22 PM
    youcandoit
    Final update. I rewired my pins back to the way they came from Akkon, and made sure I turned off my BSM and Cross Traffic before I turned the key and now they are working correctly, except of course the BSM, but I can live without that. Everything else works correctly and I'm still pleased with the way they look. Hope it turns out good for you as well.
  9. Jan 20, 2023 at 12:46 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Check your wiring configuration going into the terminals.
    Driver:
    Passenger:
    Thanks to @RainMan_PNW for these.
    bulldog93 and youcandoit like this.
  10. Jan 20, 2023 at 1:00 PM
    youcandoit
    I used the same diagram when wiring and the pins actually match up, I wonder if there is a different in what Toyota is looking for and the mirror has as resistance for the BSM because it wouldn't accept it when and I received the error to contact the dealer when I first hooked it up. I'm just gonna ride without using the sensors.
  11. Jan 20, 2023 at 2:20 PM
    Grizzly660
    North Dakota
    I have the sanooer tow mirrors from Amazon. I have been in contact with company and they are working on a solution for the BSM rear cross traffic malfunction and trying to get them to send me their wiring configuration diagram so I can cross reference with toyota. Currently I have the sensors off.
    davids_1718 and youcandoit like this.
  12. Feb 27, 2023 at 9:25 AM
    GfisherOofDmen
    GfisherOofDmen New Member
    2018 Tundra CrewMax
    Tow Mirrors, Tonneau Cover, Bed Rack
    My buddy and I just installed the Auto Boost Tow Mirrors on my 2018 crew max this past weekend. Same errors as y'all. We found that the BSM on OEM pulls .234 amps while the aftermarket tow mirrors only pulls .027 amps. When we switched the pins to make the running lights into BSM and the BSM into running lights the issues cleared. Now of course this doesn't help with using the BSM. But what we have figured to this point is we need to add more load or resistance to the BSM line for the trucks computer to register they are actually there in their pre check modes. Any ideas on how to add load?
    JDR76 likes this.
  13. Feb 27, 2023 at 10:03 AM
    JDR76
    JDR76 New Member
    WA
    2021 1794 TRD OFF ROAD
    Interesting. I installed the Boost Auto mirrors last spring. Worked well most of the time, but by fall I was getting intermittent BSM errors - about once every 2-3 weeks. The error would clear when I restarted the truck. I pulled them off and put the OEM ones back on in November and haven't had any errors since. I will reinstall them this spring, and assuming that I still get the errors I'll engage with the folks at Boost Auto Parts and see if they have any suggestions.
  14. Apr 3, 2023 at 9:51 AM
    21TRDLTD
    21TRDLTD New Member
    2021 White Tundra TRD Off Road
    S&B Intake Method 316's ARE Shell OEM Tow Mirrors Firestone Airbags ReadyONE wireless compressor
    Same issue here. Just got done installing the Tow mirrors and I wired LEDs into the tweeter panel. The lights work perfectly after tapping the wires. From the dash when I turn on BSM, they do their initiating illumination and then turn off like normal but then the malfunction and warning turns on. Was anyone able to figure out if an inline resistor works?
  15. Apr 17, 2023 at 8:20 AM
    GfisherOofDmen
    2018 Tundra CrewMax
    21TRDLTD, No, I never did get around to figuring out if a resistor would work or not. Please let me know if you get a chance to try some things. Would love to know how to fix.
