Help bad fuel mileage
Discussion in '2nd Gen Tundras (2007-2013)' started by Cobi 2010, May 8, 2025 at 2:03 PM.
  1. May 8, 2025 at 2:03 PM
    Cobi 2010
    Cobi 2010 [OP] New Member
    Yesterday
    2011 Tundra limited 4x4
    My mileage around town is 10 to 11 mpg. The truck is running perfect. I drive mellow and the mpg use to be 14 to 16. I took it to toyota and they checked the computer and everything was ok. The truck has 62k miles and is like new. Could winterized fuel be the culprit. Any ideas out there
  2. May 8, 2025 at 2:23 PM
    You on a lift and 35s?
  3. May 8, 2025 at 2:35 PM
    Cobi 2010
    Yesterday
    Nope stock tires and wheels
  4. May 8, 2025 at 3:41 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Well, good news, bad news. Burn the remaining fuel and refill with premium. Check your brakes to ensure nothing is dragging. Check vacuum lines and intske filter, just in case a rodent has stuffed your airbox with stuff.
  5. May 8, 2025 at 9:33 PM
    Rathesun
    Rathesun New Member
    Alaska
    2013 Tundra Double-cab 5.7L engine
    Nothing to lose if you add a fuel stabilizer and cleaner to remove moisture in the tank. I use Seafoan, and it does a good job. Just make sure that you use the right kind of Seafoam (read the label). I use it on my chainsaws, lawn tractor, and so on- when storing them for the winter. Now, where I live at (Alaska) alcohol-based fuels aren't sold at the pumps.
