Help - Alpine ILX207/Maestro RR/Backup Camera
Discussion in 'Audio & Video' started by grayscale, Nov 19, 2024.
  1. Nov 19, 2024 at 1:40 PM
    grayscale
    grayscale [OP] New Member
    DFW
    2013 Tundra CM TSS 4X4 5.7FFV
    I recently installed an Alpine ILX-207 along with a Maestro RR into my 2013. According to all the instructions I was to simply plug the camera rca from the hu into the Maestro one, but I have no image. Is this setup supposed to be plug and play with our factory back up cameras or did I miss something? Note: Reverse camera is in the mirror, not a factory hu
  2. Nov 19, 2024 at 1:48 PM
    Black screen when you put it in reverse? It sounds like the RCA is plugged into the wrong one. I can't remember what colors they were.
  3. Nov 19, 2024 at 2:14 PM
    grayscale
    DFW
    Yes, black screen. I only have one for video (yellow) on the Maestro and I'm using the camera input one on the hu
  4. Nov 19, 2024 at 2:57 PM
    Snert
    Snert New Member
    2021 SR5
    I'd be willing echo what @Tundra234 said in that somethings plugged into the wrong spot. Other possibility is that the Maestro needs to be re-flashed and make sure the backup cam option is clicked on.
  5. Nov 19, 2024 at 3:08 PM
    grayscale
    DFW
    Not sure where else anything would plug in, the Maestro is fairly dummy proof as far as connectors go. The only other option on the hu is additional video inputs. The camera input on the hu only attaches to the
    Speed Sensor/Camera/iDatalink/Aux harness
    I flashed it last week but don't recall an option for backup cam, but I'll double check that first thing.
  6. Nov 19, 2024 at 3:25 PM
    SD Surfer
    Bruce
    So Cal
    Does that Alpine have multiple camera inputs? I know my Kenwood has 4.
    I'd assume #1 would be for BU Cam, but ya' never know.
  7. Nov 19, 2024 at 7:05 PM
    grayscale
    DFW
    It does
  8. Nov 20, 2024 at 6:35 AM
    Snert
    Snert New Member
    2021 SR5
    Yeah my bad I should have been more clear, by "something" I meant to say my first guess would be an RCA plugged into the wrong connector. On a similar note, I had issues installing my head unit and Maestro but realized that there were two male connectors behind the head unit that both fit into the same female connector on the new head unit/maestro harnesses.
    That said, if you've got the RCA plugged in the camera should come on if you switch to one of the other input sources but if all are showing black screen, my next guess would again either be a setting in the Maestro or possible a wire needs to be jumped/moved in the harness.
    From the iLX-207 manual, it looks like the cam should be #4 and the the reverse trigger wire is the orange/white:
    This thread has full wide pics of the audio/nav system wiring (zoom in for details): All Years Complete Audio System Wiring Diagrams | Toyota Tundra Forum (tundras.com)
    On the very far right of your diagram (2013 with separate amplifier I'm guessing) it looks like the backup lamp wire is green:
    Could try and locate that wire and test with a multi-meter when you switch into reverse, and then make sure that wires connected to the orange/white on your iLX-207 harness.
  9. Nov 20, 2024 at 6:50 AM
    grayscale
    DFW
    No luck. I pulled the maestro and reflashed it, made sure OEM Camera option was switched on, didn't see any other camera options to fiddle with. Double checked everything in the dash and it's all in the right places, but still a black screen. The maestro and hu both detect that its being put into reverse fine, and camera still displays on rearview mirror. Might have to check the rca connector itself on the hu. It's a separate pigtail on the harness it connects to, maybe a dud. Other than that I have no ideas.
    Snert likes this.
  10. Nov 20, 2024 at 6:55 AM
    Snert
    Snert New Member
    2021 SR5
    Ahhhhhh I didn't realize your factory camera was in the mirror, I was thinking it was displaying on the factory head unit. In that case, check out this video from Dean/Fernando at Five Star Car Stereo. Dean is a car audio guru and while this video is for a Tacoma, the process is the same. I'm guessing if you follow this video and do some rewiring you'll be able to get the signal down to the head unit:
    How to move your factory Toyota Mirror Camera to your new radio (youtube.com)
  11. Nov 20, 2024 at 7:00 AM
    grayscale
    DFW
    Hm, I was thinking the maestro was the solution to this problem since it all runs through the canbus anyway.
  12. Nov 20, 2024 at 7:09 AM
    Snert
    Snert New Member
    2021 SR5
    It very well could but I'm not sure. iDatalink has good customer support over the phone, I called and chatted with a guy during my install, might be worth a shot before digging into things too far. Could also get a replacement cam and run it directly to the new head unit but that's just more $$$ although you'd probably end up with a better cam/picture than factory.
  13. Nov 20, 2024 at 7:51 AM
    SD Surfer
    Bruce
    So Cal
    Whoa, kinky. :rolleyes:
    Yes, iDatalink guys are SUPER helpful, they went above and beyond when I was having problems getting the gauge pack to display trans temp on my Kenwood.
    And if you do run another cam to the HU, you might as well take the opportunity to add a front cam too... love mine.
    With front & rear cams makes it pretty easy to fit this pig into spots that astonish my wife.
    Snert[QUOTED] likes this.
  14. Nov 20, 2024 at 8:17 AM
    Snert
    Snert New Member
    2021 SR5
    Well when you put it like that...:rofl:
  15. Jan 21, 2025 at 4:08 PM
    Thomastreats
    Thomastreats New Member
    Tom
    17 Tundra Crewmax Platinum
    Did you ever solve this issue? I have the same thing going on in my tundra with a Pioneer 3800NEX- triggers into black cam in reverse. Spent 2 hours with tech support. All the wiring is correct, signals meter out fine, head unit was proven to work in all RCA jacks with another cam, Spliced past all the harness, check for continuity and everything checks. I have a new RR coming in to test maybe its just a dud.
  16. Jan 21, 2025 at 4:56 PM
    Snert
    Snert New Member
    2021 SR5
    Check out the video I linked from 5 Star Car Stereo in post #10, regardless of Maestro/head unit brand etc. I think the only way to reroute signal from mirror to new head unit is the method Dean shows in the video, which should work for any head unit.
  17. Jan 23, 2025 at 5:09 PM
    Thomastreats
    Tom
    Mine ended up needing another ground from the shield of the RCA back into the harness, I bypassed the 24 pin straight to the OEM wiring.
