Help all 4 wheel sensors show a po200 and 205
Discussion in 'Electrical' started by batwrangler, Apr 20, 2022.
  1. Apr 20, 2022 at 6:37 AM
    batwrangler
    batwrangler [OP] New Member
    Bat
    na
    na
    is their a fuse any info on this
  2. Apr 20, 2022 at 6:51 AM
    Not enough info given to go on.....
  3. Apr 20, 2022 at 9:53 AM
    batwrangler
    Bat
    na
    na
    Ok here it is po200 right Front wheel sensor malfunction,,,, po205 Left Front wheel sensor malfunction,,,po 210right rear wheel sensor malfunction ,,,po 215 left rear wheel sensor malfunction ,,All 4 wheel sensors malfunction ,, break fluid ok no visable leaks
  4. Apr 20, 2022 at 10:15 AM
    Post pics of what you are looking at. Those codes are for the fuel system and fuel injector circuits, not wheel sensors.
  5. Apr 20, 2022 at 4:23 PM
    batwrangler
    Bat
    na
    na
    my Fault its Co not Po ,,,,co 200,,205,,,210,,,215 ,,,sorry about that
  6. Apr 20, 2022 at 4:32 PM
    Those are wheel speed sensor codes. That could be low voltage, broken wires, a short...etc. What year and has anything been done to it recently?
  7. Apr 20, 2022 at 5:39 PM
    batwrangler
    Bat
    na
    na
    2005 break fluid was low break light can on,, i added some lig went off thats it why would all 4 come on the same time?,,,is there one wire leading to all 4
  8. Apr 20, 2022 at 8:10 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    Ehhh 2005, I don’t know Gen 1 that well.
    I know on Gen 2 2007+ the Skid control ECU is the one that reads input from wheel speed sensors and will throw a code when it can’t see them.
    Does the Speedometer, Trip ODO still work? Are ABS lights on the dash? I would check to make sure Skid Control ECU fuses are good first. The ecu needs power to process data from wheel speed sensors.
  9. Apr 21, 2022 at 11:37 AM
    batwrangler
    Bat
    na
    na
    speed o works od works no abs light...would you know were the fuse for skid control would be i tried to find a fuse box diagram no luck ok ,,,,here's could this be the break actuator ill try posting a picture and how do i check if this one is working?
  10. Apr 22, 2022 at 5:33 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    Yes that is the skid control/abs ecu.
    As I mentioned I really don’t know the first generation 2000-2005 models that well.
    Interesting that the speedometer still works. I would check the engine fuse box as well as the interior fuse box for any blown fuses.
    When I get some free time I will try to dig up diagrams and see about power, wheel speed sensors connections.
  11. Apr 30, 2022 at 4:50 AM
    batwrangler
    Bat
    na
    na
    Is their any way to test this does it make any noise or anything??
  12. May 2, 2022 at 7:43 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    I would check these 4 fuses inside the red boxes. I also pointed out all 4 wheel speed sensors with a red arrow. The speedometer on these older trucks works on a seperate speed sensor. So I would assume maybe you do not have power to the ABS unit since you are getting errors on all 4 wheel sensors.
    Check these 4 fuses and make sure they are good
    50A ABS2
    30A ABS3
    5A ECU IG (This one power ABS ecu when key comes on, might check it first)
    10A GAUGE
    texasrho83 likes this.
  13. May 2, 2022 at 1:53 PM
    batwrangler
    Bat
    na
    na
    great work my friend im going to get to it now
  14. May 13, 2022 at 5:37 PM
    batwrangler
    Bat
    na
    na
    Found the problem What was triggering all 4 wheel censors was a leaking caliper in the front that was new 7 month ago and was hard to see the leak ,,,but all is well no check engine light too THANKS FOR ALL THE HELP I GOT FROM YOU GUYS ,,,,
    Jeff_5_7 likes this.
