Help 4wd not working
Discussion in '1st Gen Tundras (2000-2006)' started by Kcmaub, Dec 11, 2016.
  1. Dec 11, 2016 at 10:41 PM
    Kcmaub
    Kcmaub [OP] New Member
    Kenny
    2001 toyota tundra sr5 4.7 v8
    Nothing yet but came with rough country shocks and 33' mud tires just got to replace first car in october and also replaced battery with interstate and new alternator oh ya the truck has been rolled and fixed back up newer 4.7 od says 130,000 but engine was replaced when flipped at 100,000 so 30,000 on motor and 130,000 on everything else
    Hi the title says it im having trouble with my 4wd I press the button and nothing happens i tryed seeing if its a fuse and it was poping the 4wd fuse i tryed looking up what might be wrong and found the actuators on the transfercase and front diff go bad if anyone can help me please i hate having 2wd in snow oh ya i unplugged the plug near the driveline and it didnt pop the fuse andy 4hi and 4low on the gauge cluster were flashing then i plugged the plug back in and it blew the fuse again again any help would be great and how to test before i go and buy an actuator
  2. Dec 12, 2016 at 6:14 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
  3. Dec 12, 2016 at 7:07 AM
  4. Dec 12, 2016 at 9:02 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    That sure makes it sound like a short or ground within the transfer case actuator, or it's seized up . I haven't had reason to mess with one, but some of the Tacoma guys on TW had success disassembling and cleaning them out and cleaning the contacts. Might be worth a shot.
  5. Dec 12, 2016 at 10:03 AM
    Nor7
    Nor7 Chilton Manual Guy
    2007 Tundra Limited CM, 5.7L
    Do you have any error codes?
  6. Dec 14, 2016 at 2:38 PM
    mtntop
    mtntop New Member
    2004 4x4 Access Cab SR5
    I too have heard of this happening. It gets water and dirt in there and corrodes the connections.
  7. Dec 25, 2016 at 2:40 PM
    Kcmaub
    Kenny
    Its all good for now had an electrician buddy look at it and he put a breaker in my truck between the fuse now it works guess something is drawing to much power once in awhile
  8. Dec 25, 2016 at 7:20 PM
    Kcmaub
    Kenny
    Ya hopefully it stays working now to figure out y my fog lights dont work and when i press the button it turns on my high beams and not my fog lights the lights in the bumper
  9. Dec 31, 2016 at 8:07 PM
    Kobysmith99
    Kobysmith99 New Member
    03 4.7 white sr5
    I have the same problem if anyone knows the solution I would greatly appreciate it.
  10. Apr 25, 2017 at 8:44 PM
    Adams2002tundra
    Adams2002tundra New Member
    2002 Toyota Tundra 4X4 limited access cab
    none
    you probably all figured this out already but the same thing happened to my 2002 tundra. The 4wd button would just flash. I took it to my Toyota dealer and they told me that the it was the transfer case actuator switch that had corroded. My two older sisters drove my truck for 4 years and were scared to drive in snow or anything other than regular pavement so the actuator switch got corroded from not moving in many years. I had to take it in and get the actuator switch replaced which is a switch that engages the transfer case. since my tundra just has a button and not a physical lever to put it in 4wd. It ended up being around $2500 and took about 3 days. It works now and the told me that I need to put it into 4wd at least once a month for just a little bit to keep that actuator switch active and avoid corrosion.
  11. Apr 25, 2017 at 8:52 PM
    Kcmaub
    Kenny
    Ya it just pops the fuse once in awhile i just said screw it and bout a crap ton of 20 amp fuses and replace it when the fuse pops
  12. Apr 25, 2017 at 9:33 PM
    Joeshaker
    Joeshaker New Member
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Bilstein 6112/5160 trd sway bar and ride rite bags. Black and burnt orange wet okole seat covers.
    My 2000 had the actuator go out. Tranny shop said $3500 to tear it down and replace it. There's a retainer on the inside of the t case. You have to take it all apart. Toyota changed the design like eight times in the first two years. I got a used one out of an 03 for $300.00 from Yota Jim's in Denver with a 90 Day warranty. It worked flawlessly until I sold the truck last year.
