help...4wd Hi and Lo flashing
Discussion in '2nd Gen Tundras (2007-2013)' started by shannon, Oct 12, 2022.
  1. Oct 12, 2022 at 7:19 PM
    shannon
    shannon [OP] New Member
    shannon
    Asheville, NC
    2010 DC
    Hey all, I searched but could not find the same problem anywhere. My truck has the 4hi and lo lights flashing. It happened about 3-4 weeks ago well after I had taken it out of 4 high on some gravel roads. It went off when the truck was off and back on. It seemed to go on randomly without messing with the switch for about a week after. Then it stayed off. Came back on today after a fast downhill left turn (in hindsight, the random times before seemed to be downhill lefts.) No codes. Just got in from hunting and have a day before I head back out. What do you guys think? Will I f%^k anything up if I go back out? Thanks in advance!
  2. Oct 12, 2022 at 7:22 PM
    Check your speed sensors.......wires, connector for damage.
    shannon[OP] likes this.
  3. Oct 12, 2022 at 7:30 PM
    shannon
    shannon
    Asheville, NC
    2010 DC
    Will do! Thanks! If they end up being damaged, will it hurt anything to drive it for 5 days on an elk hunt? Don't worry, I won't hold you liable...
  4. Oct 13, 2022 at 4:59 AM
    PhotoNerd
    PhotoNerd New Member
    Tony
    Waterford, CT
    2008 Salsa Red Tundra DC SR5 4x4
    Chrome delete, Sequioa grill, bed lights, LED + head, fog & tail lights, Dynamat throughout, front & rear cameras, Pheonix PX6 13" head unit, 8" subwoofer, JBL speaker upgrades, tonneau cover, custom shifter, steering wheel cover
    I had the same problem after breaking a wheel speed sensor and drove it a couple of weeks and it was fine. I think your traction control and ABS won't work. Check if 4WD works.
    Replacing the sensor is pretty easy though.
  5. Oct 13, 2022 at 6:05 AM
    shannon
    shannon
    Asheville, NC
    2010 DC
    Good to know. I guess that solves the "turning off the nannies" problem. My issue is time, sounds like i'll be good til I get back. Thanks!!
    PhotoNerd[QUOTED] likes this.
