HELP! 4HI light flashing
Discussion in '2nd Gen Tundras (2007-2013)' started by 2007ToyotaTundraOwner, Aug 4, 2025.
  1. Aug 4, 2025 at 4:22 PM
    2007ToyotaTundraOwner [OP] New Member
    2007 Tundra
    4HI light stuck flashing. When I start up the truck and it's in 4HI, I am able to switch between 4HI and 4LO. The problem however is I am unable to switch to 2WD. I checked all the fuses and they're good. I am a novice mechanic and need help
  2. Aug 7, 2025 at 2:36 PM
    Vince
    Vince New Member
    Vincent
    Terre du lac, Missouri
    2011 White DBL cab 5.7
    K&N intake, Air bags
    Does the light stop flashing or always flashes when in 4hi or 4lo
  3. Aug 7, 2025 at 2:41 PM
    2007 Tundra
    It flashes when its in 2WD/4HI/4LO. Constant
  4. Aug 7, 2025 at 2:45 PM
    Vince
    Vince New Member
    Vincent
    When the light flashed for me it was hung up between 4 hi and 4lo
    Wheels have to be stright and drive under 45 to 4 hi
    4 lo had to be put in neutral to engage was my experience if that didn't work check 4x4 actuator make sure you can hear it engage
  5. Aug 7, 2025 at 2:46 PM
    yakeng
    yakeng 3URFE Apologist
    2020 Tundra 4x4; 2014 Sequoia;
    ECGS Bushing; GCS Cooler RASHD; Fox 2.0
    Dumb question, but have you tried driving it forward and backward some? Sometimes throwing it in reverse will get it out of 4HI.
    Vince and JLS in WA like this.
  6. Aug 7, 2025 at 2:46 PM
    2007 Tundra
    Front right wheel sensor code popped up. Nothing regarding 4WD unless that affects it?
    Leo's first likes this.
  7. Aug 7, 2025 at 2:56 PM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    That will defiantly cause the 4wd light to flash but usually accompanied by many other lights vsc, trac, etc
  8. Aug 7, 2025 at 3:05 PM
    2007 Tundra
    Yes VSC and trac are on as well
    Leo's first[QUOTED] likes this.
  9. Aug 7, 2025 at 3:18 PM
    Leo's first
    Groton ma
  10. Aug 7, 2025 at 3:43 PM
    2007 Tundra
  11. Aug 7, 2025 at 4:03 PM
    Leo's first
    Groton ma
    The wire unplugs from the sensor I didn’t replace any wire
