Help 07 tundra starts then dies
Discussion in '2nd Gen Builds (2007-2013)' started by NotjoTunrda, Oct 1, 2022.
  1. Oct 1, 2022 at 8:15 PM
    NotjoTunrda
    NotjoTunrda [OP] New Member
    2007 Single cab 5.7L
    Leveling kit cold air box 20'' wheels
    So I have an issue someone can help with.
    My truck was not starting I dropped fuel tank after checking fuses relays and still wasn't getting any fuel to rail I checked pump by running hot and ground directly to pump.
    Pump ran fine.
    So I figured fuel pump control module after checking with voltmeter red and blue wire wasn't getting anything from moduel to pump with or without key cycled and blue wire should be a 12v constantly..
    But nothing
    Replaced module and truck started after replacing pump fuse but would only start then instead of idling it would just die . Did this constantly. Got frustrated then thought I wonder if me not tightening ground post but just putting it on post would cause this . Have yet to try but what else could it be
  2. Nov 11, 2022 at 8:18 AM
    careyrob
    careyrob In the field
    Carey
    Massachusetts
    2008 Crewmax TRD 4x4 Silver
    LRO 3/1 leveling lift 35x12.50's on 20x9's Hellwig rear sway bar B&M 70264 SuperCooler Transmission Cooler Firestone airbags Daystar cradles Air Lift WirelessONE Compressor System
    Are there any trouble codes in the ECU?
