Hellwig or TRD Sway Bar
Discussion in '2.5 Gen Tundras (2014-2021)' started by asimeone18, Nov 26, 2019.
  1. Nov 26, 2019 at 11:34 AM
    asimeone18
    asimeone18 [OP] New Member
    I have a 2019 SR5. Thinking about getting a Sway bar, but looking for some more info.
    Reading the forums, a lot of people are saying the Hellwig is the way to go if you carrying weight or towing. I tow a 5500lbs camper once in awhile. Although, I have a WDH on it, so I'm not sure having a beefed up sway bar makes a big difference with the WDH. Am I wrong?
    Also, does putting a sway bar on the truck change the way it drives other than cornering? Currently IMO the cornering is terrible. So hopefully that'll be improved. Although, I am hoping that after putting a sway bar on I won't feel every little road irregularity. Currently IMO the truck does great eating up shitty road.
    Thanks
    yoshi82 likes this.
  2. Nov 26, 2019 at 11:43 AM
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    I put a TRD RSB on my 19 Pro. I know, some people scoff at that, whatever. I drive 99.99999 percent of the time on pavement so I wanted to make that experience more enjoyable. It makes a huge difference in handling and cornering. Night and day, no question.
    People say it comes at the sacrifice of ride quality on rough terrain. I've had mine out tearing up some logging and forest roads in the Cascade mountains and I've yet to notice enough ride quality loss that I've regretted putting it on there. So other than the cornering, I haven't really noticed a change.
    ragtopman, Elduder, Durania and 4 others like this.
  3. Nov 26, 2019 at 12:08 PM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I would have preferred the heavier Hellwig, but the thinner TRW works pretty well on my little sub 5000 pound Tundra. If I had a full size Tundra or planned to tow much, I would use the Hellwig.
  4. Nov 26, 2019 at 12:11 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    I don’t think it matters which one you go with. Pick the cheaper one and push the buy button.:thumbsup: Cornering is significantly improved. I have the TRD.
  5. Nov 26, 2019 at 12:31 PM
    I have the Hellwig and would buy it again without a second thought.
    Rica25, CMB and Rex Kramer like this.
  6. Nov 26, 2019 at 12:40 PM
    NCTundra18
    NCTundra18 New Member
    Jeff
    Candler, NC
    2018 White Limited Crewmax
    TRD dual exhaust, Rough Country lift kit and too much money spent.
    I got the TRD rear sway bar and love it. Check out Bam whole sale. Got mine for $204 shipped. I think i used a promo code save5. I looked it up on line.
    TNTundra7 likes this.
  7. Nov 26, 2019 at 12:41 PM
    asimeone18
    Why is that? Does it make cornering even better. It's hard to imagine double the price gives double the performance.
  8. Nov 26, 2019 at 1:19 PM
    Rex Kramer
    Georgia
    Beefy 1 1/8" diameter, and it's adjustable via link location.
    HulkSmurf14, Rica25 and Prostar 190 like this.
  9. Nov 26, 2019 at 1:22 PM
    Metro14536
    Metro14536 New Member
    Brandon
    Las Vegas, NV
    2025 Ice Cap SR5 TRD Rally
    TRD
    Rica25 likes this.
  10. Nov 26, 2019 at 2:19 PM
    This^^^^
    Rica25 likes this.
  11. Nov 26, 2019 at 2:20 PM
    You can adjust the links and the placement on the sway bar which you cannot do on a TRD. Buy once cry once.
    Rica25 likes this.
  12. Nov 26, 2019 at 2:40 PM
    Ajkkane
    Ajkkane Old fart.
    Nj
    2014 CM SR5
    I’d go TRD. Cause you know you are going to want a TRD front sway bar in the same pretty red color to match the rear!!!
    Rica25 and TNTundra7 like this.
  13. Nov 26, 2019 at 2:45 PM
    Rex Kramer
    Georgia
    I have had this Hellwig on the back of my '02 for 16 years, it's a awesome upgrade.
    Rica25, Prostar 190 and BTBAKER like this.
  14. Nov 26, 2019 at 4:30 PM
    Leetomnsx
    Leetomnsx New Member
    2016 Toyota Tundra Platinum
    Air lift, black out emblems, wheels, tonneau cover, tires, led lighting, hidden step rail, remote start.
    If you drive pavement a lot and semi aggressive a sway bar will be the best money you can spend on your truck. I've got 700 lb Toytec coils so I didn't need to change the front, it's planted.
    BravoDeltaRomeo likes this.
  15. Nov 27, 2019 at 1:38 AM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    1005151144.jpg I bought the Hellwig because given the choice, I believe it's better suited for a full sized truck and it ain't red.
  16. Nov 27, 2019 at 2:24 AM
    Rex Kramer
    Georgia
    I can live with the Red bar on my 2007, because the rear is lowered and the bar is elevated making it hard for people to see.
    TundraXPLover likes this.
  17. Nov 27, 2019 at 2:32 AM
    TNTundra7
    TNTundra7 New Member
    TN
    2016 SR5 4WD 5.7L
    Bilstein 5100s, TRD RSB, TRD Wheels
    I put the TRD on a few weeks ago. In addition to cornering, I think one of the biggest benefits is when driving on the interstate at high speeds. Whenever there is a strong side wind, the truck doesn't "sway" any more. You'll be fine with either brand in my opinion. Just pick whichever one you can get a better deal on or decide if having red under your truck bothers you. I personally like it.
  18. Nov 27, 2019 at 4:48 AM
    patek
    patek New Member
    2019 trd sport
    get the trd enginered for the tundra the other is aftermarket overkill thicker isn't better but they had to make it different to market it
  19. Nov 27, 2019 at 4:57 AM
    Rex Kramer
    Georgia
    The Hellwig made for the Tundra is engineered for the Tundra.
    Prostar 190 likes this.
  20. Nov 27, 2019 at 4:58 AM
    CMB
    CMB New Member
    Cecil County MD.
    Somebody stole your Caps Key!:eek:
  21. Nov 27, 2019 at 5:02 AM
    People probably shouldn't buy kings or any other coilovers because they're not as good as the thinner factory ones.
    AggiePhil, Inquiringone and patek like this.
  22. Nov 27, 2019 at 5:03 AM
    TundraXPLover
    TundraXPLover New Member
    Clif
    NC
    2018 CM 4x4 XP
    Went with the TRD. I like the red also. Easy install and it will change your truck for the better! High winds, curvy roads, left or right turns with little to no sway or roll!
    Get it!
  23. Nov 27, 2019 at 5:04 AM
    So do you guys know is ours just made for an F-150 and we're using it on a Tundra?:rofl:
  24. Nov 27, 2019 at 5:06 AM
    Rex Kramer
    Georgia
    Overkill is highly underrated.
  25. Nov 27, 2019 at 5:09 AM
    patek
    patek New Member
    2019 trd sport
    ok bigger is ALWAYS BETTER
  26. Nov 27, 2019 at 5:17 AM
    Rex Kramer
    Georgia
    Hellwig has been producing high quality rear sway bars for Toyota trucks for a very long time, I had one on my old T100... I believe the 'factory' OEM rear sway bar first appeared on the Tundra as part of the 2WD TRD Sport Package in 2003.
  27. Nov 27, 2019 at 5:19 AM
    That's what she said. :D
    Inquiringone and Rex Kramer like this.
  28. Nov 27, 2019 at 5:41 AM
    CMB
    CMB New Member
    Cecil County MD.
    Absolutely right! Like the "factory" nerf bars, bed steps and tires/wheels!:tinfoilhat:
  29. Nov 27, 2019 at 5:57 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    The correct terminology is anti-roll bar, although the term "sway bar" has been an interchangeable term used for decades. It gets a little more complicated when you tow, because "sway bar" is also used for that part on the tongue/hitch that reduces trailer sway.
    An anti-roll bar works by transmitting force from the wheel that is on the outside of a cornering radius, to the inside wheel that is trying to lift up during the turn. The bigger and stiffer the anti-roll bar, the flatter the rear suspension will stay under hard cornering maneuvers. An anti-roll bar should not affect ride quality if properly engineered, but at some point, I have no doubt a heavy duty anti-roll bar will affect ride quality on uneven or irregular road surface.
    My thoughts are if the truck is primarily used for a daily driver, then get the TRD. Toyota designed the bar to improve handling of the truck without changing the ride. It comes in Pretentious Red so everyone that looks under will know you are on the racing development edge. :D
    If you tow heavy with your truck, then get the Hellwig. When towing, a rear anti-roll bar will help the truck damp and absorb the forces being input into the rear suspension through the trailer hitch. The Hellwig is 1 1/8" in diameter where the TRD is 7/8"(?) diameter. A larger diameter anti-roll bar is going to be stronger in torsion and "give" less. Based on the diameters, it probably will stiffen the ride compared to the TRD, especially in the second or third adjustment holes. If you only tow occasionally, install it in the first hole until you figure out how stiff you want it. The Hellwig only comes in Anonymous Gray; those looking under will only be impressed by the size of it...if they see it at all. :D
  30. Nov 27, 2019 at 6:09 AM
    Rica25
    Ricardo
    Tulare
    20190831_130855.jpg that red does look nice but I bought the front TRD and I personally did not like the ride yes it does keep the truck more stable on corners but the ride is more harsh in the front feels to solid. So I had the stock sway bar powder coated when they powder coated the coils I do have the rear TRD as well and that one I do like . Hellwig was little to pricey for me. And they are made down the street from where I live maybe I could have drove there and asked for better deal but I wanted that pretty RED
    AggiePhil and Rex Kramer like this.
