Hello really need some help with the brakes on my 2000 tundra.
Discussion in '1st Gen Tundras (2000-2006)' started by Peekay55, Dec 9, 2020.
  1. Dec 9, 2020 at 9:57 AM
    Peekay55
    Peekay55 [OP] New Member
    hugh
    just had the frame replaced, new calipers and pads on front .Bled all the lines pedal goes to the floor. then replaced the master, still goes to the floor. have'nt been able to get anymore air through lines, bled them four times. what next?
    YardBird likes this.
  2. Dec 9, 2020 at 10:12 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Calipers on the correct sides? Bleeder needs to be on top or you'll never get all the air out. Burned myself there a time or two.
  3. Dec 9, 2020 at 10:21 AM
    koditten
    Kirk
    Midland of the Mitten
    I got that t-shirt, only it was a Chevy.
    Regardless, I can't remember, does the Tundra have load sensing proportioning valve? I know the Tacoma's do and your symptom sounds exactly like you haven't bled that valve.
  4. Dec 9, 2020 at 10:26 AM
    Peekay55
    hugh
    Everything on correctly, Just goes to the floor. Did'nt know if i was missing something out of the ordinary
  5. Dec 9, 2020 at 10:47 AM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  6. Dec 9, 2020 at 11:05 AM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    Bad Master Cylinder? It's possible, unfortunately...
  7. Dec 9, 2020 at 3:25 PM
    Professional Hand Model
    Hand Protectors
    Bleed in order:
    1) Pass rear (20-25 pumps)
    2) LSPB Valve (15-20 pumps)
    3) Driver rear (15-20 pumps)
    4) Pass front (10-15 pumps)
    5) Driver front (10 pumps)
    N84434 likes this.
  8. Dec 9, 2020 at 3:30 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Did you also put a speedy bleeder on the LSPV?
  9. Dec 9, 2020 at 3:35 PM
    Hand Protectors
    Yes. They are NAPA Speed Bleeders. They have a one way check valve where you can bleed the system by turning the bleeder a 1/2ish turn which opens the valve for a push only. These allow one person to bleed the system without another person and without the use of pressurized pumps etc. High success rate with these. $20 a pair iirc.
    N84434 likes this.
  10. Dec 9, 2020 at 3:41 PM
    FrenchToasty
    Mo
    Bone stock
    I could be wrong but I thought I read my 4runner came with them. But I’m definitely going to outfit the truck when it’s BREAK time!
    N84434 and Lil Steve like this.
  11. Dec 9, 2020 at 3:44 PM
    Hand Protectors
    Nice. It was a pain in the arse figuring out the proper Bleeder Sizes. Ended up buying two sets for the front with the WL13 upgrade, but iirc was able to reuse one from the WE13 on the LSBP Valve. Win win! :yes:
  12. Dec 10, 2020 at 5:01 AM
    N84434
    Milwaukee WI.
    2001 Limited TRD
    He sent me a message last night.. Found some brake fluid/seepage around the ABS pump and lines... I assume he'll report back with the findings.
