Hello! New to trucks and my first Tundra!
Discussion in '1st Gen Tundras (2000-2006)' started by Takeshi, Sep 6, 2020.
  1. Sep 6, 2020 at 8:14 PM
    Takeshi
    Takeshi [OP] New Member
    Hello everyone! I've always been a car guy and I'm new to trucks but I've been looking at Tundra's and Tacoma's for a few months now and I just purchased my first Tundra yesterday! It's a 2003 Limited Access Cab 4.7 V8. My friend told me to look out for the infamous frame rust so I always asked for photos of the frame first before even attempting to look at any of the trucks.
    She's got 272k miles on her which is the highest mileage vehicle I've ever bought but the history looked pretty good, one owner, maintenance done and they had the timing belt replaced twice, the first one at 90k and the next at 190k back in 2016. The first thing I did to her when I brought her home was change the oil. I ordered a timing belt/water pump component kit and plan replace that also.
    The frame has some surface rust on there but it doesn't seem too bad. I'd like to take the bed off and start some repairs, weld some frame caps, clean up the rust and prep the frame so it doesn't continue to rot away. I think this would be a good Winter project to do.
    118957705_10103752904403282_5139139749574324761_o.jpg 118968505_10103752906344392_32980167414946868_o.jpg
  2. Sep 6, 2020 at 8:17 PM
    NCTundra18
    NCTundra18 New Member
    Jeff
    Candler, NC
    2018 White Limited Crewmax
    TRD dual exhaust, Rough Country lift kit and too much money spent.
    Welcome from Western NC.
    Takeshi[OP] likes this.
  3. Sep 6, 2020 at 8:18 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada
  4. Sep 6, 2020 at 8:27 PM
    Welcome from NY.
  5. Sep 6, 2020 at 8:28 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    Welcome aboard from The Pacific South West.
    Pucks18 and Takeshi[OP] like this.
  6. Sep 6, 2020 at 8:41 PM
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    Welcome from Ontario Canada
  7. Sep 6, 2020 at 8:51 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Very clean,..Welcome.
  8. Sep 7, 2020 at 5:07 AM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    That looks great for 272,000 miles. You sure it's not 272,000 Kilometers??
    Make sure to heat the bed bolts With a propane torch from underneath before attempting to remove them. Also, use a liberal amount of a good quality penetrating oil before and after heating each bolt. You'll thank me later....
    ktundra, bmf4069, flyfisher and 3 others like this.
  9. Sep 7, 2020 at 5:25 AM
    Welcome from Ohio
  10. Sep 7, 2020 at 6:02 AM
    ToyAddict802
    ToyAddict802 #ShallowPockets w/BigDreams
    GreenMt. State
    2023 SR5 DC,2023 Tacoma Sr5
    3.5 TRD Lift, TRD 20” wheels with 295/60/20 Falken Wildpeaks
    Welcome from Vermont
  11. Sep 7, 2020 at 7:20 AM
    Schcoman
    Schcoman From behind the Redwood Curtain
    Humboldt Co. CA
    2000 Access Cab 4.7L V8 4x4 SR5
    None
    Welcome from True NorCal. Nice truck!
  12. Sep 7, 2020 at 7:45 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Welcome from So Cal
  13. Sep 7, 2020 at 8:34 AM
    Stuck in the '00s
    Stuck in the '00s Experienced member
    Mikey
    SE Wisconsin
    2004 Phantom Gray DC 4X4 Limited Tundra
    Western plow, custom bed
    Another welcome from WI.
  14. Sep 7, 2020 at 2:46 PM
    Takeshi
    I wish it was 272k in kilometers haha. I'll definitely make sure to heat and use a ton of WD-40. I want to replace the rear bumper too since the paint is rusting through and there's a hole on the bottom of the bumper too and I'll to make sure to use heat and WD-40 on those too.
  15. Sep 7, 2020 at 8:17 PM
    bassman417
    bassman417 "Tundra Time". My favorite time of day...
    Paul
    Las Vegas
    2004 DC 2wd Imperial Jade
    Welcome from Vegas. Very Nice looking Truck.
  16. Sep 8, 2020 at 9:35 PM
    Takeshi
    So I brought my truck into work today and put her up in the air and the bed bolts do not look like they will come out without breaking so one of my coworkers who specializes in trucks suggested just cleaning up the rust from under the truck then using some rust preventative paint and just brush it all over the frame. I'm looking at possibly using POR-15? Has anyone had any experience using that on the frame?
  17. Sep 8, 2020 at 9:51 PM
    TILLY
    Massachusetts
    Just my 2 cents, but i had bad results with the one time i used POR-15. They require you to buy and use their 3 step process and products, and after one year mine was peeling and bubbling off. never again.
  18. Sep 8, 2020 at 9:52 PM
    Takeshi
    Good to know, thank you! I'll keep looking around to see what the best option is. Winter season will be here in the next month or 2 so I want to prep up my frame before then.
  19. Sep 8, 2020 at 10:01 PM
    TILLY
    Massachusetts
    Takeshi[QUOTED][OP] likes this.
  20. Sep 8, 2020 at 10:04 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I don't live in a heavy winter state I don't think. Usually we only get a light dusting, but salt is a heavy factor here. Local gubbernments go stupid with the salt and even the first syllable of the word "snow"
    I pulled the bed, and ground as much of the rust off the frame as I could. Then I "painted" it with ospho metal treatment, then painted with primer, and paint. Rustoleum.
  21. Sep 9, 2020 at 4:31 AM
    Professional Hand Model
    Hand Protectors
    Squirt everything down with 2 cans PB Blaster Penetrant including frame, frame box, axles, and the under bed rails. Then rub it all down with grease using a sponge. Total cost less than $20.
    PB Blaster takes 10 minutes by just firing away at long distance. The grease rub a full day. Or you could break it into 2 partial days. Permanent. Recco the PB Penetrant refresh at least once a year to get the folds and nooks.
    ktundra and Tundra2 like this.
  22. Sep 9, 2020 at 4:38 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! Luckily we don't have to deal with the salt, or winterizing, or really even the rust issues y'all have up there!
  23. Sep 9, 2020 at 5:17 AM
    ktundra
    ktundra rust be damned
    Lex
    NJ
    06 Tundra DC Limited 4WD
    Bilstein 5100
    Welcome from the Garden State.
