Hello I'm a disabled veteran trying to repair a 2006 Toyota tundra with a 4.0 engine
Discussion in '1st Gen Tundras (2000-2006)' started by Ramspt, Jun 28, 2025 at 8:21 AM.
  1. Jun 28, 2025 at 8:21 AM
    Ramspt
    Ramspt [OP] New Member
    Yesterday
    2006 tundra V6 4.0
    Trying to replace ground wire from battery to motor. Can I just add a cable instead of tracking cable mess
  2. Jun 28, 2025 at 8:31 AM
    Ramspt
    Yesterday
    2006 tundra V6 4.0
    Trying to replace ground wire from battery to motor. Can I just add a cable instead of tracking cable mess. Looks like it connects to motor below sta
    rter
  3. Jun 28, 2025 at 8:47 AM
    You can run a new cable from the battery to the motor and zip tie it along the harness. It should be fine as long as it is secured and away from the fan, belts, etc.
  4. Jun 28, 2025 at 9:03 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    I would wrap it around the existing ground wire to minimize any ground loop effects.
  5. Jun 28, 2025 at 9:20 AM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    2003 V8 SR5, Access Cab, 4x4, White
    Hello, and thank you for your service. I'm genuinely interested in why you would lead with being a disabled veteran instead of just asking about the repair? Are you looking for someone to help you? If so, then maybe a general location would be warranted.
    Sirfive and FrenchToasty like this.
