Hello fellow Tundra owners, I am in need of some advise or expertise here.
Discussion in 'Wheels & Tires' started by Bassaholic1, Apr 17, 2019.
  1. Apr 17, 2019 at 12:00 AM
    Bassaholic1
    Bassaholic1 [OP] New Member
    tony
    2016 Tundra Crewmax 4x4
    Blacked out and 20" wheels
    I recently put new 20" wheels on my truck and have had nothing but problems with the vibration and steering wheel shaking. I decided to have the tires balanced to see if that was the issue but that did not help the situation. After rotating the tires I discovered that the drivers side front wheel does not seem to snug up flush with the hub after fully tightening it on. I put the truck on jack stands to see if I could shake the wheels at all and found that wheel to have play. I checked to see if it was the hub or wheel bearing and discovered that the whole wheel had play due to it not tightening up against the hub enough. Its like the studs are to long or the lugs are not deep enough. Has anyone seen this before and does anyone have any suggestions??
  2. Apr 17, 2019 at 12:46 AM
    mnm
    mnm Old Guy...
    Mark
    Smithfield, VA
    2008 Tundra Limited 4x4 DC
    Did you compare the driver's side lugs to the passenger's? Do they measure the same?
  3. Apr 17, 2019 at 1:03 AM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Sounds like the wheel has the incorrect size hole for the hub and you need hubcentic rings to make it fit properly.
  4. Apr 17, 2019 at 1:18 AM
    Bassaholic1
    tony
    hmm what are hubcentric rings
  5. Apr 17, 2019 at 1:26 AM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
