Heavy Duty Brakes
Discussion in 'Towing & Hauling' started by Leverguns, May 19, 2022.
  1. May 19, 2022 at 4:33 AM
    Leverguns
    Leverguns [OP] New Member
    Tommy
    2019 Platinum Crewmax
    Bilstein Sway bar and heavy duty rear springs
    Hello All,
    I tow heavy and for the most part I travel the extremities this countries byways has to offer.
    Now I know the Tundra has a massive brake system and by specs will hold its own up against most 1 ton systems.
    However that is an area that I personally would like to have some improvement.
    I am looking into the Z-36 Truck/Tow rotors/pads for front/rear.
    Has any one installed this system and if so, what were your results on steep long downgrades 6+
    Real world experience not thoughts please.
  2. May 19, 2022 at 6:13 AM
    Tiamat
    Tiamat New Member
    2015 tundra crewmax xp
    Well as far as the now 2.5 gen tundra goes, I have had a terrible time with brakes. OEM pad and rotors have been terrible. While i don't have the set up you mentioned i just got delivered the stoptech hd tow brake axe kit rotors and pads. When i called to order a set of cryo rotors the sales guy (i know i know) asked the reason. I explained the warping pulsation etc. He stated that after owning several tundras himself and experienced the same issues he told me about the kit. He stated that oem brakes are terrible and caused pad deposit on rotors under heavy use and that shimmy on the steering and pulsation on the pedal would continue as long as i used oem stuff and used heavily. The cryo rotors were 200 bucks more than the axle kit. I will let you know how it goes once i install them. The kit you asked about has received very positive reviews.
  3. May 19, 2022 at 6:24 AM
    I had the Z36 kit on my 2012 Tundra. Wet weather the brakes had more “bite” but that was the only differences I noticed. Stopping distance was similar to factory pads and rotors and were lasting longer.
    My factory pads and rotors went 60k miles. I towed heavy and often, but probably not like a full time RV’er. You are towing more than I would with a 1/2 ton truck so wear items will be needing to be serviced more often.
    The Tundra brakes are good in the 1/2 ton segment, but nowhere near what a HD truck has in comparison.:hattip:
  4. May 19, 2022 at 6:30 AM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    I have these installed right now, probably 40K on them.
    I'll say this, I can't wait to get them off.
    I have some pulsing in the front that started around 15K I think. Not bad, but it is noticeable to me. I am careful to not have the brakes clamped down hard when coming to complete stops after hard braking. I followed their (Z-36) break-in protocol exactly as stated, followed this 2K miles later with a brake fluid flush because the brakes were good, but felt pretty soft. Nope didn't help. Got in a friends Tundra and his brakes were a ton better.
    I tow often, 7x14 DA enclosed - 8.5x18 DA Enclosed (run them around MT/ID/WY 2-4 times/year), rent a 6K lb travel trailer occasionally. So I am most likely not as heavy as you. And I will not buy them again.
    ColoradoTJ likes this.
  5. May 19, 2022 at 6:33 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Look into DBA Rotors and your choice on pads...Powerstop isn't what they used to be for the last 10 years unfortunately...warped rotors and pulsing is a common feature with this "upgrade." Stoptech is also and other solid choice for rotors...I just threw the DBA T3s on my wife's 4th gen 4runner and they're incredible!
  6. May 19, 2022 at 7:59 AM
    16CMTXED
    16CMTXED New Member
    Gary
    Central Texas
    2016 Tundra CM
    Eibach Pro Sport Shocks (1.25in), RAS HD, Sumo Springs, HAWK Talon Rotors, OEM Tow Mirrows, Lund Hard Fold Tonneau, ESP Storage, Stampede Flares, Husky xAct Fit liners, General Grabber ATX 275/60R20
    @Leverguns You may want to also consider HAWK Talon Rotors and either LTS or HD Pads. I installed the HAWK Talon Drilled/Slotted rotors and LTS Pads on my '16 CM a few months ago. So far, only city/hwy driving...but they really do have good bite (much better than stock-IMO). I tow heavy in the summertime, pulling a 7k lb Travel Trailer. So far, I'm really satisfied, and expecting them to do well when towing this summer. Also available, are slotted only HAWK Talon rotors, which I wanted, but were out of stock at the time. Check TireRack.com, they usually have good deals on these kits. IMG_20220314_191847273_HDR.jpg IMG_20220319_143133307.jpg
  7. May 19, 2022 at 8:12 AM
    I will check those out for my Duramax at 120+ thousand miles. I’m still at 80% pad life with 75k miles. Thanks for the review.
    16CMTXED[QUOTED] likes this.
  8. May 19, 2022 at 8:14 AM
    Well that really sucks! I only had these rotors/pads on from 60 to 89k miles when my Tundra was sold. So not as long…
  9. May 19, 2022 at 10:15 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    You want cryo treated rotors, would skip the slots and drilled. Slots only if you must. Pair with some good pads like EBC, akebono.
    BecauseRacecar likes this.
  10. May 19, 2022 at 6:59 PM
    Buckaroo
    Buckaroo New Member
    Central Ohio
    2017 Tundra 5.7L 4WD DC TRD
    2020 GD 2670MK Travel Trailer
    Yes, installed the Z36 rotors and pads and put about 6.500 miles on them towing out west with an 8000 lb camper. Have 8,000 miles on them total. Lots of stopping power and have had them on some significant grades. No pedal pulsation aka "rotor warping" noted so far. I do downshift into lower gear when descending significant grades and focus on not laying on the brakes. Install notes in following thread....
    https://www.tundras.com/threads/power-stop-z36-install.103380/#post-2759282
    HulkSmurf14 likes this.
  11. May 21, 2022 at 4:35 PM
    Leverguns
    Tommy
    I believe most of the issue I’m having is torquing the lug nuts to proper specs.
    Dealer just installed the bilstein shocks/struts for me and I’m guessing only a well used torque stick was used if that.
    I’m easy on the truck even when towing, since this is the first time with this issue it may have been induced‍♂️
  12. May 21, 2022 at 4:38 PM
    Leverguns
    Tommy
    I appreciate you sharing your experience.
    Just the kind of advise I’m looking for.
  13. May 21, 2022 at 4:43 PM
    Leverguns
    Tommy
    Thank you for sharing your experience.
    I will certainly look into those.
  14. May 22, 2022 at 7:16 AM
    Leverguns
    Tommy
    Hello all,
    The weight of the trailer at 7,900 lbs is fully loaded.
    Which is actually 10% under and never had an issue with power, regardless of the mountains that I have come across. I have had some very long and steep grades. The Tundra has handled each one in stride.
    Now, I live on top of Carver mountain in Waynesville NC, gravel rd and 1/4 mile to my house is 13 degrees, I’m not going to sit here and say that she does it with ease, nope, I mean she really wakes up for that one,lol.
    Kind of cool to hear that TRD duals sing their song when under that kind of torque.
    Gotta be proud of your choice of truck when that happens.
    The brake issue just started, two things I believe are culprits.
    1- improper lug nut torque. (Induced)
    2- Tiamat/ mentioned brake deposits collecting on factory rotors, that creates hard and/or hotspots when rotors become hot. Thanks for that info Tiamat.
    With that being said, I don’t believe the rotors should be that temper mental, so I will be searching to eliminate that issue. First stop will be Toyota technical service. They may have something to offer, I mean we as daily drivers can not possibly push the limits of our trucks (while using common sense knowledge) as they do with the Baja truck racing. So what are those guys using?
    I want what they got lol.
  15. May 22, 2022 at 7:34 AM
    Power is usually never the issue. Handling and stopping is.:thumbsup:
    Like others have said, there are options out there to assist in your style/needs. EBC (pads/rotors) is what I have on my Lexus and have been very happy with the braking on that sports sedan. Corvette racing team uses EBC...good enough for me. The answer to your question on Baja trucks is:
    They change out brakes all the time....just like the Corvette racing team.
  16. May 22, 2022 at 7:47 AM
    Leverguns
    Tommy
    The handling aspect is well taken care of.
    As for the brakes: I want to be as safe as possible for the sake of others as well as my family.
    If tested I know my ignorance can in fact run very deep :)
    I have run ebc brakes as well on a few hot rods in the past. Served me well,
  17. May 22, 2022 at 7:47 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    @Leverguns forgive me if you stated it already but are you running stock size tires and wheels? Any lift?
  18. May 22, 2022 at 7:52 AM
    Leverguns
    Tommy
    no lift.
    Factory rims.
    Michelin Ltd a/t. Tires staying at good pressures and temperatures.
    Next set to tires I will going up in rating on tires and rims.
  19. May 22, 2022 at 7:59 AM
    Rubberdown
    Pardon my ignorance. I have literally never heard of lug nut torque affecting anything other than your wheel falling off. How does this affect brakes? I mean if they were loose I could maybe see it. But other than that?
    Retired...finally likes this.
  20. May 22, 2022 at 8:08 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    If your wheel isn't seated nice n tight up against the hub you're gonna feel vibration and there will be movement between the stud and the wheel which will damage threads and also cause the wheel to move during braking.
  21. May 22, 2022 at 8:18 AM
    Leverguns
    Tommy
    Lug torque places pressure values directly to the rotor.
    If the torque points are within specs then the rotor can and does warp once hot.
    It’s actually a pretty common problem.
  22. May 22, 2022 at 8:33 AM
    Rubberdown
    Not trying to be argumentative but no it doesn’t. That doesn’t make any sense. It’s not a direct force being applied to a single plane which would do what you’re talking about. That clamping force is:
    1 indirect. IE the wheel is spreading that clamping force over a large area.
    2. cumulative. IE the force applied to a point in the rotor is the sum of multiple clamping forces because there are multiple lug nuts
    3. That force is going around two corners in the rotor... hat. IE those forces are not in the same plane as the surface of the rotor, how could that be?
    I’m gonna do some sciencing and think about this. Better yet someone smarter than me help me.
  23. May 22, 2022 at 8:37 AM
    This is why I have a torque wrench in all my vehicles. The apes at the tire shop usually go way over.
  24. May 22, 2022 at 8:51 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I use a torque stick with my impact a max setting then I go over each one with a 4 way.
  25. May 22, 2022 at 9:16 AM
    Rubberdown
    this makes more sense to me but that is a function of a clean mating surface not torque values. Obviously I’m just talking how tight not that it’s tight in the first place.
  26. May 22, 2022 at 9:21 AM
    Rubberdown
    It could be that I’m underestimating the exponential increase in the force being applied by each ft/lbs. that’s what I’m trying to do the math on.
  27. May 22, 2022 at 9:51 AM
    Rubberdown
    And I’m failing. I give up and concede and will use a torque wrench from now on.
    I is dumb
    CaptRussia253 and hagrid like this.
  28. May 22, 2022 at 9:53 AM
    bensky
    bensky PlatinumPro
    Ben
    Utah
    2018 Red Platinum Tundra
    I put a set of these on my wife’s Lexus RX350 (the rotors were warping every few months) and I love them. I’ve had them on for a little over 40K miles and smooth as butter.
    When my pads are worn out I’m switching to the powerstop Z-36 rotors and pads.
  29. May 22, 2022 at 11:12 AM
    Leverguns
    Tommy
    lol,
    Not knowing and dumb are certainly two different things.
    Your far from dumb bo
    texasrho83 and ColoradoTJ like this.
  30. May 22, 2022 at 11:16 AM
    I may have to look into one of those torque sticks. I rotate my own tires on all my 8 lug stuff (3) since I run centramatics. This might help out a bit.
    I have a Ridgid Impact, and that SOB will flat out snap a stud if on the wrong set points. Glad it has 6 settings and other options.
