Heating/cooling, sticky blend doors
Discussion in '2nd Gen Tundras (2007-2013)' started by Rob371, Dec 29, 2018.
  1. Dec 29, 2018 at 5:52 AM
    Rob371
    Rob371 [OP] New Member
    Rob
    Charlevoix, Michigan
    2007 Tundra Crewmax
    Steel bumpers front and rear,1.4" bilstien, KatSkinz Leather, rear airbags, halos.
    Occasionally the zone door doesn't switch from defrost to any other position. With engine running, if I switch from defrost I can hear sounds in the ventilation system as if it is trying to move the door, but the airflow continues to come from defrost only at a reduce rate. If I turn the truck off, rotate to floor, or dash, or a blend and start back up then most of the time (9 out of 10 maybe) it switches over to the desired zone. Has anyone experienced this?
  2. Dec 29, 2018 at 5:59 AM
    I haven't on my 07. You issue does seem a bit odd. Maybe someone has had the same issue and will chime in.
