Headunit dimming (night mode) when pressing brakes.
Discussion in 'Audio & Video' started by drpheta, Aug 6, 2023.
  1. Aug 6, 2023 at 3:28 PM
    drpheta
    drpheta [OP] New Member
    Super White 2014 TRD Off-Road DC
    Any idea why my headunit dims briefly when stepping on the brakes? It'll flicker into night mode on broad daylight when doing so.
    It only happens with the brake lights activating or active.
  2. Aug 6, 2023 at 4:07 PM
    chrisf111
    chrisf111 New Member
    Aftermarket or stock?
  3. Aug 6, 2023 at 4:12 PM
    drpheta
    Both.
    If I'm in Android auto it'll briefly go into and out of dark mode when I press the brakes. If I'm not in Android auto, the LED capacitive buttons will dim and lighten repeatedly.
    Put in my stock one and the same happens with it triggering as if the headlights were activated, but I know the headlights are off as they don't flicker on when this happens.
  4. Aug 6, 2023 at 4:41 PM
    Retired...finally
    How old is your battery?
  5. Aug 6, 2023 at 4:53 PM
    drpheta
    Came with the truck. Probably 2 years?
  6. Aug 6, 2023 at 4:56 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Who installed the aftermarket HU?
    Does it still dim down when you turn the parking/headlights on?
  7. Aug 6, 2023 at 5:01 PM
    drpheta
    I did. No splicing wires, just tundra specific harnesses. It properly switches to night mode with the parking lights or headlights on.
  8. Aug 6, 2023 at 5:28 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    I’m thinking a poor ground connection to one of the tail light assemblies, or corrosion inside the trailer socket.
    Stock tail lights? Any LED bulbs?
    KNABORES likes this.
  9. Aug 6, 2023 at 5:43 PM
    drpheta
    Stock. I'm going to look into the tail light harnesses then.
    landphil[QUOTED] likes this.
  10. Aug 9, 2023 at 5:25 PM
    drpheta
    Went through all the brake light bulbs and connections, and nothing seems out of place. Reseated the bulbs, made sure all connections were solid, but nothing seems to change the flickering back and forth on night mode on my head unit when I press that brakes. It's also random, but happens most of the time I'm braking.
  11. Aug 10, 2023 at 8:55 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    I'm not super good with electronics so maybe someone smarter than me can comment but is it possible that when applying the brakes, it's causing a larger load on the electronics which causes them to dim?
    Do a full load test on the battery to rule that out.
  12. Aug 10, 2023 at 8:57 AM
    drpheta
    You know, I had considered that, and now that you mention it I can't remember if it happened when I installed the amp or not. I'm going to look into that.
    Jaypown[QUOTED] likes this.
  13. Aug 12, 2023 at 6:37 AM
    drpheta
    Well, it's not the amp. I disconnected the amps, and the flickering still occurs most times I press the brakes. This is a real head scratcher.
    I even tried to turn off HVAC, anything not needed to drive really.
    Here's a video of the issue. It'll also flicker back and forth intermittently at stop lights while the brake is depressed. AC is on in this video.
    https://imgur.com/Xr4iPyx
  14. Aug 12, 2023 at 7:23 AM
    Musicmasterd12
    Musicmasterd12 New Member
    Southern Louisiana
    2011 4.6 Silver Sky Metallic DC
    Do you have any kind of resistors wired in for any reason? Did you wire up any sort of bypass to be able to use functions while driving?
  15. Aug 12, 2023 at 8:09 AM
    drpheta
    Bought the car used, but I don't see any resistors on the tail lights.
    No bypass for functions to use with car off.
  16. Aug 12, 2023 at 9:22 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    How do things look inside the trailer electrical socket? No corrosion or nastiness there?
  17. Aug 12, 2023 at 9:37 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    Not to use with the car off, but to use all functions of the HU even if the parking brake isn't set.
    I can't tell what brand your HU is.
    Is there a parking brake bypass or something like this on the radio?
  18. Aug 12, 2023 at 9:40 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    Also, read thru this thread.
    He ended up having some crushed wires that were shorting out and blowing the fuse when he turned his lights on.
    Blown tail light fuse | Toyota Tundra Forum (tundras.com)
    Not sure what connection your brake circuit and your HU would have in common unless its a ground somewhere..
  19. Aug 12, 2023 at 10:53 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    Something is wired wrong.
    There is no connection to the HU and stop circuit, unless it is deep in the ground connections...
    Couldn't find a connection in the ECU-IG No.1 or stop fuse to the radio either.
    7.5A ECU-IG No.1
    ABS
    Auto LSD
    Blind Spot Monitor System
    Multiplex Communication System (CAN)
    Parking Assist (Intuitive Parking Assist)
    Power Tilt and Power Telescopic
    Rear Window Defogger
    Shift Lock (Column Shift)
    Shift Lock (Floor Shift)
    Stop Light
    Theft Deterrent
    Tire Pressure Warning System
    TRAC
    Trailer Towing
    VSC
    15A STOP
    ABS
    Auto LSD
    Cruise Control (1GR-FE)
    Cruise Control (1UR-FE)
    Cruise Control (3UR-FE, 3UR-FBE)
    Electronically Controlled Transmission and A/T Indicator (1GR-FE)
    Electronically Controlled Transmission and A/T Indicator (1UR-FE)
    Electronically Controlled Transmission and A/T Indicator (3UR-FE,
    3UR-FBE)
    Engine Control (1GR-FE)
    Engine Control (1UR-FE)
    Engine Control (3UR-FE, 3UR-FBE)
    Stop Light
    TRAC
    Trailer Towing
    VSC
  20. Aug 12, 2023 at 11:27 AM
    TXTundra2722
    2015 Black Tundra
    This same thing happened to me when I pulled power from the trailer plug wiring to run extra lights in the back. When I disconnected it. Everything went back to normal
  21. Aug 12, 2023 at 6:29 PM
    drpheta
    The thing is this is just plugged into the factory harness with a supplied harness. Nothing was spliced.
  22. Aug 12, 2023 at 6:30 PM
    drpheta
    So your head unit would dim randomly from this until you disconnected the wiring you tapped?
  23. Aug 13, 2023 at 8:41 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    Something is triggering the darker illumination of the HU when you hit the brakes.
    Is it the same action that takes place when you turn the parking/headlights on?
    Does the screen turn dark, like the flash in the video, when you turn on the parking/headlights?
    Did it ever work correctly without the dark flash when you hit the brakes?
    Or did that start you installed the after-market HU?
    Does it only do it when you are driving, or will the HU flash with the key on, the engine off, and you hit the brake pedal while parked?
    The odd thing is in the 9 pages of the illumination circuit, the circuit makes all switches and stuff light up in the dash and triggers the HU darkening, there is no connection to the brake/stop light circuit.
  24. Aug 13, 2023 at 10:36 AM
    TXTundra2722
    2015 Black Tundra
    Yes
  25. Aug 13, 2023 at 3:34 PM
    drpheta
    Turning on the headlights or parking lights will set the screen to constant dark mode without flickering. In other words, proper dark mode stays in dark mode. It did work properly before as far as I know, but it's done this with the aftermarket HU it came with, the new one, and the stock one that was provided with the truck (prev owner installed the first aftermarket HU and gave me the stock one with the truck purchase).
    I tried to get it to flicker when in park, but couldn't get it to happen. When I'm in neutral I can get it to flicker with the brakes.
    I can get the HU to dark mode flicker with the headlight stalk set to either off or auto.
    1lowlife[QUOTED] likes this.
  26. Aug 13, 2023 at 3:41 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    It seems like when you step on the brake, that circuit is shorting to the illumination circuit and triggering the HU as if the lights were on.
    But it is odd that it only flickers.
    It seems if that was the case, that the HU would STAY on dark mode as long as the brake light was on.
    Sorry so many posts, it is bugging me we can't figure out what the issue is..:eek2::cool:
    drpheta[OP] likes this.
  27. Aug 13, 2023 at 4:53 PM
    drpheta
    I actually appreciate your help on this. My thoughts initially were also a short, but it's really peculiar how it's only a flicker.
    Battery load also makes sense, but again where and why is that an issue as well?
  28. Aug 13, 2023 at 5:07 PM
    SNO BUS
    SNO BUS Professional Moneywaster
    Nick
    Washington
    White '18 CM 4x4 Limited+
    LEER Canopy, Line-X, Bed mat, Wireless charging
    Battery issues can cause all sort of stuff you don't expect. Same with alternator. I had some corrosion on the wires going to my alternator on my land cruiser and it caused the door locks to constantly keep unlocking when i had my foot on the brake. And a bunch of my lights didn't work + HVAC was going haywire. Interesting that it happens in neutral but not in park as well. And interesting that it happens with stock head unit which (in theory) weeds out an issue with the aftermarket wiring. It seems like there is a ground issue that affects the parking light circuit when the brakes are depressed, that then affects the head unit illumination circuit. I think the head unit illumination circuit is the same as the dash lights, do any of your buttons on the dash or hvac or gauge flicker with brake light? I could be wrong on that though. Maybe it's a CANBUS issue... i have no idea how that stuff works but maybe it can get someone else thinking.
  29. Aug 13, 2023 at 6:25 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    My thought is that stop light power is feeding back to the park / tail light circuit at less than 12V due to a loss of a good ground on one of the tail light assemblies, or a bridge of corrosion in a connector, such as the trailer socket. Either would certainly cause these symptoms, that’s why I suggested the things I did.
    One more thing @drpheta could try, is to temporarily unplug the connector to both tail light assemblies and see if the dimming issue goes away. If it does, plug them back in, one at a time, to see when it comes back.
    1lowlife[QUOTED] and drpheta[OP] like this.
  30. Aug 13, 2023 at 6:32 PM
    drpheta
    I'm going to try that this week when I get a chance. That's a great idea
    landphil and 1lowlife like this.
