Headliner in SR5, actually getting it out of the cab?
Discussion in '2nd Gen Tundras (2007-2013)' started by Trademan8284, Jun 19, 2023.
  1. Jun 19, 2023 at 5:23 AM
    Trademan8284
    Trademan8284 [OP] New Member
    Greg
    2007 Tundra 2WD SR5 4.7
    I've found lots of posts regarding dropping the headliner in these trucks, but it seems like most are for running wires in the ceiling for radios, etc......if one wanted to actually take the thing out of the truck to recover it, are you able to do it without taking the rear window or a seat out to make it work? I've done headliners before, it doesn't scare me.....but getting the thing out without bending it up seems......daunting.
  2. Jun 19, 2023 at 10:44 AM
    KeepOnTruckin
    KeepOnTruckin New Member
    Randy
    2010 4.6 4x4 Bare Bones
    I can't help you. All I can say is I'm curious what your options are. If pulling the passenger seat is enough, that doesn't sound to bad.
    I did a head liner in my 79 F350 4x4 crew cab, that seat laid down flat but I took the passenger door off.
    GL
  3. Jun 19, 2023 at 10:50 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    This could be trouble for a DC but if you have a CM then you should be able to roll that back glass down and bend it a little to ease it out. It won't hurt to bend it a bit but a taco bend will definitely crease it.
    2mchfun likes this.
  4. Jun 19, 2023 at 11:19 AM
    2mchfun
    Somehow the factory gets them in, so there must be a fairly easy way to get them out. My guess is rear window.
  5. Jun 19, 2023 at 11:38 AM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    In double cabs without the rolldown rear window, maybe they put it in before the rear glass goes in. Or the windshield. If so, fun times getting that out!
  6. Jun 19, 2023 at 11:45 AM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    You might check with a shop that does windshields about having your windshield removed, doing the job on the headliner, and then reinstalling the windshield. Probably be affordable as you're just covering labor and sealant/RTV materials.
  7. Jul 7, 2023 at 9:04 PM
    texmln
    texmln New Member
    I took a tour of the Tundra factory in San Antonio years ago. If I recall correctly they were sliding them in the back window opening before the glass went on. I highly recommend the tour if you are ever in the area.
    Terndrerrr likes this.
