Headlights
Discussion in '2nd Gen Tundras (2007-2013)' started by Albinator, Feb 26, 2020.
  1. Feb 26, 2020 at 6:15 PM
    Albinator
    Albinator [OP] SAINTRIOT
    Utah
    2008 Tundra Crew Cab 5.7 4x4
    RC 3.5” M1 Lift 18X9 5-150.00 12 Offset Vision Turbine
    Just realized that my front driver side headlight is out. Any you recommend? Do you like or not like led blue lights? I’m just planning to get a pair from autozone I think.
  2. Feb 26, 2020 at 7:37 PM
    Headlight or side marker light? And blue is illegal....unless you are talking about 6000k color which has a slight blue tint. I would not go with cheap Autozone LEDs though.
    TheBeast and Tundyfundy like this.
  3. Feb 27, 2020 at 6:23 AM
    Albinator
    Utah
    Headlight.
    this is what is currently in my truck and I’d like to keep them the same. Germany?
  4. Feb 27, 2020 at 6:31 AM
    Albinator
    Utah
    Found this one on Amazon. Everything matches except for the very bottom that starts with a w. Is that a problem?
  5. Feb 27, 2020 at 6:33 AM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    If you want to keep them the same then just get a replacement H11 bulb for your truck. If you want LED you need to find one with an H11 connector. @Headlight Revolution
    I also have a pair of Phillips led bulbs with the ballasts and resistors for sale. I have a 2016 though so not sure if they’d fit.
    Headlight Revolution likes this.
  6. Feb 27, 2020 at 6:37 AM
    Headlight Revolution New Member Vendor
    Atlanta, GA
    Hey OP!
    That would be your H11 Halogen Low beam bulb! We offer a few rock solid kits for the 2nd Gen. Tundras! Here's a Link: https://headlightrevolution.com/vehicles/toyota-tundra/toyota-tundra-2007-2013/
    If you are thinking LEDs, please don't go to Autozone, you'll thank me later I promise! If you are looking for another Halogen bulb replacement, then they have you covered! You can pick that bulb up at any auto parts store, those are the most common bulb styles out there!
  7. Feb 27, 2020 at 6:38 AM
    Tundyfundy
    Bay Area, CA
  8. Feb 27, 2020 at 7:19 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    I'm still old school. Leds/hids in reflectors are a no no. Too many folks using chinesium Amazon grade stuff. Think they see better but are blinding more folks on the road. Do a proper retrofit or jump aboard the Alpharex train for budget projectors that look decent.
    You can get hotter/brighter halogen bulbs at the expense of shorter life spans too. I ran ultra stars and race vision bulbs for awhile. Lasted about a year each. Dead bulbs suck on our rigs. PIA to swap them out.
  9. Feb 27, 2020 at 10:27 AM
    Albinator
    Utah
    Which ones would you recommend to keep the same light output and color as my current dead bulb is?
  10. Feb 27, 2020 at 10:28 AM
    Albinator
    Utah
    I just want to keep them the same with the same color and output.
  11. Feb 27, 2020 at 10:42 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    Any base/cheap H11 bulb should work, but replace bulbs in sets. OEM bulbs are long life, sacrificing performance for longevity. The increasing "trim levels" as you look at each brand's H11 bulb will start to swing the longevity/performance pendulum.
    Albinator[QUOTED][OP] likes this.
  12. Feb 27, 2020 at 10:44 AM
    Albinator
    Utah
    I’m not able to find Toyotas OEM bulbs that come in a set. Is that what you’re referring to?
    Tundyfundy likes this.
  13. Feb 27, 2020 at 10:46 AM
    DRP82
    DRP82 New Member
    Austin, TX
    2015 MGM CrewMax
    Please do not put cheap LED bulbs in factory housing.
    Hoff, Tundyfundy and Albinator[OP] like this.
  14. Feb 27, 2020 at 10:50 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    Sorry, OEM supplier used bulbs. Toyota doesn't make their own bulbs. You'll find Sylvania or Phillips bulbs at most parts stores.
  15. Feb 27, 2020 at 3:41 PM
    Tundyfundy
    Bay Area, CA
    They will be seperate.
  16. Feb 27, 2020 at 6:42 PM
    Albinator
    Utah
    Got a set of bulbs and all is well. Thanks!
