headlights
Discussion in 'Lighting' started by turk, Jan 25, 2020.
  1. Jan 25, 2020 at 2:02 PM
    turk
    turk [OP] New Member
    greg
    millersville pa
    2011 platinum
    has anyone ever bought after market stock headlight lenses? and what company is worth while .i found some on ebay?
    TURK8875 likes this.
  2. Jan 25, 2020 at 8:11 PM
    CPdaddy
    CPdaddy Why am I so tired
    Tom
    Denver
    16 Tundra CrewMax Limited
    Boss 3" Lift, TRD Dual Exhaust, S&B Intake, TRD Rear Sway, 285/75r18 Nitto Ridge Grapplers on Fuel Beast Wheels, SPC upper control arm, Rough Country front bumper with LED bar and dual lights on each side, Rear bumper blackout covers, Go Rhino running boards, Morimoto XB Headlights, HIRev LED Tail Lights
    Hey there. I went high end and got the Morimoto xb with the fogs. Lots of peeps have the spyder ones as well. This is probably going to depend on how much you’re okay with spending. There are plenty of people who do retrofit with hid projection as well. I wouldn’t go too low end as you might run into condensation issues. Good luck on your quest.
    DRP82 likes this.
  3. Jan 26, 2020 at 5:40 AM
    turk
    greg
    millersville pa
    2011 platinum
    thanks cp.
  4. Jan 26, 2020 at 10:10 AM
    TURK8875
    TURK8875 New Member
    SKIPPER
    Following
  5. Jan 26, 2020 at 10:21 AM
    DRP82
    DRP82 New Member
    Austin, TX
    2015 MGM CrewMax
    @CPdaddy is right. Everyone’s budget is different, but buy cheap, you will most likely be replacing them because of quality issues.
  6. Jan 26, 2020 at 10:26 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    From what I have heard, unless upgrading, best to get OEM.
