Headlights Replacement
Discussion in '1st Gen Tundras (2000-2006)' started by NavelGazer, Mar 8, 2023.
  1. Mar 8, 2023 at 10:34 AM
    NavelGazer
    NavelGazer [OP] New Member
    2001 White Tundra
    Well, it's time to replace my 2001 Tundra headlights. I tried a restoration kit with minimal results. I also tried purchasing new lights online, but that was a disaster. They were broken when I opened the package. Has anybody had a good experience with a 3rd party headlight supplier, or should I just bite the bullet and go OEM?
  2. Mar 8, 2023 at 10:36 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    I think you had bad luck. A lot of members here bought aftermarket and they were fine. Search around and you might find where they got them if they don’t answer your post.
  3. Mar 8, 2023 at 10:43 AM
    Elevatorguy
    Elevatorguy Yotas and JD Green!
    James
    05 DC, 4.7, 4wd, LSD.
    Tyc from rock auto.
    tvpierce and w666 like this.
  4. Mar 8, 2023 at 11:27 AM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
  5. Mar 8, 2023 at 11:41 AM
    I just went with OEM. I waited for a major national holiday so there'd be a 15-20% off coupon at Parts.Toyota.com and used the FREESHIP coupon ordering from one of the dealerships in Alabama who also doesn't charge tax. Look, it wasn't pretty, but I'll get another 15-20 years out of these again, but they came with all bulbs, seals, and everything else you need. Granted, DEPO and TYC do make pretty decent headlights I could've gotten for maybe half this. I just didn't want to get screwed like others have buying non-OEM.
    w666 likes this.
  6. Mar 8, 2023 at 5:42 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    I just bought a set of TYC CAPA certified from the Rock and they fit just fine.
  7. Mar 9, 2023 at 6:43 AM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    This interests me.
    He's pretty straight forward in his assessment of this set up.
    Also, there is 6 month follow up video on his channel as well.
    https://youtu.be/vDi-fIp0jkw
    Slidetbone and jerryallday like this.
  8. Mar 9, 2023 at 6:50 AM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    I've used both in 1st gen tundras - TYC and OE Toyota.
    The TYC are very good for the money, and fit fine. The OE Toyota lenses have a better beam. But there is a big cost difference.
    Bought the TYC from rockauto.com and the OE Toyota came from an online Toyota dealer.
  9. Mar 9, 2023 at 7:07 AM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    reach out to @Headlight Revolution - they are a vendor here on the forum. sure they can help.
    I purchased just bulbs from them and have been happy. They are pretty responsive to inquiries as well.
  10. Mar 9, 2023 at 8:06 AM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    I saw that and tried it, broke the clips just like he did. Wasn’t able to repair. I dropped so much stuff into the housing also trying get the pc you need to remove out. Ended up buying new headlights.
    Was only able to get one done 100% and just ended up buying bulbs (down below), I believe the bulbs I got are better than the projectors. No mods needed.
    HBTundra[QUOTED] likes this.
  11. Mar 9, 2023 at 8:58 AM
    bfunke
    South Carolina
    @jerryallday - I used these CO projectors in TYC housings. The reflector you have to remove is larger than the opening. I used a set of tin snips to cut the reflector in several places and then folded the cut strips in which allowed me to pull them out with a long nose pliers.
    jerryallday likes this.
  12. Mar 9, 2023 at 10:43 AM
  13. Mar 9, 2023 at 10:47 AM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Yeah, I tried it and failed, did all that also.
    I have a good Passenger side if anyone wants to buy it and a bad driver side with the broken tab that keep the hinge down hahahahaha
    I also have a set of clear corners, about 1-year-old.
  14. Mar 9, 2023 at 12:00 PM
    robabeatle
    robabeatle New Member
    AZ
    2002 Tundra 4x4 LTD AC
    Bilstein 6112 & 5160, Katskinz, audio upgrades
    These look great for the $.
  15. Mar 9, 2023 at 12:20 PM
    Almost good enough to go grab some DEPO, TYC or Eagle Eyes on the cheap, then mod them. :D
    It'd be interesting to see if there's a better version of those H4 mini projectors around, too. But even if there is, it's probably made in the same factory :D
    I think if someone made these with a slightly better lens which created a crisp cutoff, it'd be worthwhile.
    robabeatle[QUOTED] likes this.
