Headlights pointed too high after baking/opening
Discussion in '2.5 Gen Tundras (2014-2021)' started by mav7021234, Sep 21, 2022.
  1. Sep 21, 2022 at 7:57 AM
    mav7021234
    mav7021234 [OP] New Member
    So….. I just finished baking/taking apart my headlights and painting the housing black.
    I put it back together and placed them back on and noticed the headlight beam is now pointed so high.
    I tried adjusting using the headlight adjuster in the cabin but didnt work. I may have left the half of the headlight adjustment rotor in while baking….
    How f***** am I? Is there still hope I can use the manual adjusted behind the headlight housing to get the beams pointed down? Anyone run into this issue and fix it?
  2. Sep 21, 2022 at 7:59 AM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    /DOH. Wish you luck on this one
    mav7021234[OP] likes this.
  3. Sep 21, 2022 at 8:00 AM
    Time to get some OEM leds.
  4. Sep 21, 2022 at 8:00 AM
    Taco-Spike
    Two Trucks
    Yes, you should to still be able to manually adjust them.
  5. Sep 21, 2022 at 8:01 AM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    You can purchase just the adjuster.
    Also, and no offense, but LOL.
  6. Sep 21, 2022 at 8:06 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
  7. Sep 21, 2022 at 8:12 AM
    :rofl::rofl::rofl:
  8. Sep 21, 2022 at 8:17 AM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    Manually adjust them with the adjusters on the back of the housings. If you didn't melt or brake anything, a #2 phillips will get you going.
  9. Sep 21, 2022 at 8:27 AM
    RobertD
    Robert
    DFW, Texas
    BlueRibbon4x4 likes this.
  10. Sep 21, 2022 at 8:47 AM
    Ha! I had an extra set that I did, cause I did a set way back and sold those, and the set I did i threw them away
  11. Sep 21, 2022 at 9:48 AM
    pursuit2550
    pursuit2550 New Member
    I could check, but I believe I have 2 OEM adjusters at home, maybe 4. I have done retro fits in the past and the adjusters are left out. Either way how hot did you get them? I don’t see why the adjuster motor would stop working.
  12. Sep 21, 2022 at 10:17 AM
    mav7021234
    I tried looking up the adjuster, where do you buy it? Idk, what even the exact part/part# is called. And indeed, LOL
  13. Sep 21, 2022 at 10:18 AM
    mav7021234
    240 for 20mins. I just followed the Lightwerkz video on YouTube.
  14. Sep 21, 2022 at 10:19 AM
    mav7021234
    Thanks fam. I couldn’t see shit on the way to work early in the morning.
    *well I could see the damn headlights were lighting up the freeway signs lmao
  15. Sep 21, 2022 at 10:19 AM
    Backslider
    Tooele, UT
  16. Sep 21, 2022 at 10:24 AM
    mav7021234
    I’ve been trying to look up more about it, but just see dead forum posts. This was pretty similar to what mine did
    https://www.tundratalk.net/threads/headlight-level-adjuster-motor.117619/
    when I first turned on the headlights I heard the driver side light make a humming noise and then stop.
    Ill check later if I hear the headlight motors hum when I adjust using the cabin headlight adjuster
  17. Sep 21, 2022 at 12:26 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Adjust them back down manually with a socket. Did you bake the lights with the motors still attached?
    mav7021234[OP] and RobertD like this.
  18. Sep 21, 2022 at 1:20 PM
    mav7021234
    I pretty much followed this vid.
    https://youtu.be/5VmQbl7Wqjc
    I saw he had half of the rotor on when he baked it. It was the half closest to the headlights which were the gears. The electronic half was disconnected and left with the truck before I baked.
  19. Oct 1, 2022 at 1:08 PM
    mav7021234
    Backslider[QUOTED] likes this.
  20. Oct 1, 2022 at 2:18 PM
    Backslider
    Tooele, UT
    Glad you got it sorted out!
