headlights condensation
Discussion in '2nd Gen Tundras (2007-2013)' started by turk, Jul 23, 2022.
  1. Jul 23, 2022 at 10:34 AM
    turk
    turk [OP] New Member
    greg
    millersville pa
    2011 platinum
    i replace my head lights 2 yrs. ago stock lenses and have been perfect for a recondition part from headlights America.
  2. Jul 26, 2022 at 5:15 AM
    FWD Tundra
    FWD Tundra New Member
    Washington
    2013 Tundra 4WD Double Cab
    ??? Is there a question here?
  3. Jul 27, 2022 at 5:06 AM
    turk
    greg
    millersville pa
    2011 platinum
    sorry i forgot why i posted this i have water vapor mostly in the drivers side light the cornner.also some in the center i only was my turck by hand no pressure. i think i will drill a pilot hole or 2 about 1/8 or smaller?
  4. Jul 27, 2022 at 5:11 AM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    I would not drill a hole into your headlights. That will only cause more condensation. You need to let the water dry out naturally and try to seal whatever leak you can find on the housing.
  5. Jul 27, 2022 at 5:31 AM
    tunpunch
    tunpunch New Member
    Cord
    2007 TRD DC 4X4
    I agree. Do not drill pilot holes. I recently had to remove a head light which was 1 year old. It was filling up with condensation and looked terrible. I removed, found hole and dumped water out. Then use hair dryer to get the rest of the moisture out. Once it is bone dry, you need to patch the hole to prevent more water from getting in.
  6. Jul 27, 2022 at 5:57 AM
    turk
    greg
    millersville pa
    2011 platinum
    The headlights appear to be sealed from the factory. How all of a sudden do they start leaking no damage what so ever .I'll get some pics soon.
  7. Jul 27, 2022 at 11:49 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    Could be as easy as a bulb seal/o-ring, or the sealant was a bit thin in an area and is nolonger sealing.
    I've has to patch a hole in the seal between the lens and body of a headlamp that did not start out leaking. Was pretty apparent when I checked out the seam between the 2 pieces.
