Headlights are very dim
Discussion in '1st Gen Tundras (2000-2006)' started by Davehal, Apr 20, 2024.
  1. Apr 20, 2024 at 11:26 AM
    Davehal
    Davehal [OP] New Member
    david
    2003 toyota tundra
    Headlights on my 03 Tundra switch on but are very dim. If I go to highbeam only passenger side works. driverside goes out. Does anyone have an idea of whats going on? My headlight lenses are new the bulbs are new my battery is good. I checked all my connections and cleaned them.
  2. Apr 20, 2024 at 1:03 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Need more info, are headlights hazed? If so that will dim performance. And you probably just have bulb burnt out if highbeam does not work on one side.
  3. Apr 20, 2024 at 7:23 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Weagle likes this.
  4. Apr 20, 2024 at 7:46 PM
    Welcome from NY.
  5. Apr 20, 2024 at 8:00 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Check the connector to the back of the bulbs, they’re probably corroded increasing the resistance and burning the connector which will need to be replaced. Had it happen to me.
  6. Apr 20, 2024 at 8:02 PM
    Are they halogens, or did you install LEDs without realizing there’s special shit you need to do when using LEDs on these trucks?
    Did you have the battery tested?
    Are you a lazy sod, with dirty terminals? Have you checked your terminals lately?
    1lowlife likes this.
  7. Apr 20, 2024 at 9:22 PM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    TX
    2001 4x4 4.7L AC Limited 55k mi
  8. Apr 20, 2024 at 9:25 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Welcome to the forum..
    The first thing I would check is for corrosion on the battery clamps..
    Tundras are notorious for thin layers of corrosion fucking everything up..
    Good luck..
  9. Apr 21, 2024 at 5:07 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Yes but unique situation for me. Mine are a custom hack job.
    shifty` likes this.
  10. Apr 24, 2024 at 8:37 PM
    Davehal
    david
    2003 toyota tundra
    My headlight lenses are new the bulbs are new my battery is good and I checked all the connections and cleaned them
    Weagle likes this.
  11. Apr 24, 2024 at 10:21 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Check fuses. Check relays. Check wiring for loose/broken connections. If the bulbs are new, sounds like a loose connection where the wiring connects to the bulb. What bulbs are you running? Are they seated correctly in the housing? Have you tried adjusting the headlights? Maybe they are out of whack, thus lighting the roadway poorly.
    You mention the driver side goes out with the high beams. At each headlight bulb connection, there are 3 wires. A common ground, a positive for the low beam, and a positive for the high beam. The low beam is not powered while the high beam is on, the bulbs wouldn't last for long with both elements burning during high beam operation. Check to make sure one of these connections isn't loose in the bulb socket.
  12. Apr 25, 2024 at 2:01 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
  13. Apr 25, 2024 at 6:15 AM
    You skipped over possibly the most important question I asked above: Are the new bulbs halogen or LED?
    If LED, specifically what brand and model? And what steps did you take when installing them? Did you cut any wires?
