Headlight switch slid out. cant turn on my headlights
Discussion in 'Lighting' started by blackwell817, Sep 10, 2019.
  1. Sep 10, 2019 at 1:53 PM
    blackwell817
    blackwell817 [OP] New Member
    David
    2007 tundra limited 5.7 V8
    i have an 07 tundra. the stalk of my headlight switch slid out of the turn signal bar. now the only thing I can do is signal and pull back for my brights. until I can pay 226.50 for new assembly, im trying to figure out how to get my headlights to the auto position. any ideas? suggestions?
  2. Sep 12, 2019 at 4:17 PM
    Batel
    Batel New Member
    2019 Tundra SR5 TRD Offroad
    I have been into many automotive switches over the years and some can be repaired, some not. I have not been into a Toyota multifunction and don't know if they are riveted together. That being said that multifunction switch you're working with is definitely high liability and also has a lot of complexity of function so you run the risk of not being able to even get it back together much less fix it. Hopefully you can find the best price and/or a salvage unit that fits your needs so you don't have to risk fixing that one.
  3. Sep 12, 2019 at 4:22 PM
    Vince
    Vince New Member
    Vincent
    Terre du lac, Missouri
    2011 White DBL cab 5.7
    K&N intake, Air bags
    Was that a rockauto part you priced.
    A lot of times Advance Auto parts.com
    You can find discount codes and pick it up in the store or shipped to home for free
    Batel likes this.
  4. Sep 12, 2019 at 4:29 PM
    Batel
    Batel New Member
    I don't know what auto parts stores the OP has in his area but a friend of mine that works at O'Reilly's told me that they will price match Rockauto now.
  5. Sep 12, 2019 at 5:23 PM
    Vince
    Vince New Member
    Vincent
    That's good to know.
  6. Sep 13, 2019 at 9:13 AM
    blackwell817
    David
    Thanks a bunch for the input. I think your right about trying to fix it. I’m gonna go start searching pick n pulls
    Batel likes this.
  7. Oct 18, 2019 at 4:36 PM
    bordercop7b
    bordercop7b New Member
    2007 Tundra TRD
    I have 2007 Tundra as well and the same thing happened. Seems there has got to be someway to reseat the stalk but I haven't found it yet.
