Headlight suggestions
Discussion in '2.5 Gen Tundras (2014-2021)' started by dru741, Dec 11, 2022.
  1. Dec 11, 2022 at 7:18 PM
    dru741
    dru741 [OP] New Member
    2014 Silver Tundra SR5 TRD CM
    Greetings! I’m looking to find a good replacement for my headlights. I did a simple LED bulb swap a couple years ago and they aren’t as bright as they used to be. I’d like to upgrade assembly and all. I do have the headlight adjuster in the cab.
  2. Dec 11, 2022 at 8:09 PM
    AZBoatHauler
    So.Arizona
    Toyota LEDs with an @iHacker harness. Nothing else comes close for the $.
  3. Dec 12, 2022 at 5:22 AM
    dru741
    Where would I go to acquire said items? Sorry I’m newish to the forum.
  4. Dec 12, 2022 at 5:30 AM
    RobertD
    Robert
    DFW, Texas
  5. Dec 12, 2022 at 6:06 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Seriously, one of the best upgrades I've done to the truck...
  6. Dec 12, 2022 at 6:33 AM
    WFD473
    WFD473 Long Live The V8
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    GODZILLA likes this.
  7. Dec 14, 2022 at 1:07 AM
    Zoso
    Zoso New Member
    SE Georgia
    2021 Cement DC LTD
  8. Dec 14, 2022 at 2:14 AM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    Great upgrade, I love mine as I drive in the dark a lot. Easy to install with hacker harnesses.
    Luckydog likes this.
  9. Dec 14, 2022 at 8:20 PM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    This…I love this setup
    WILLINH and AZBoatHauler[QUOTED] like this.
  10. Dec 15, 2022 at 1:24 AM
    PermaFrostTRD
    Northern NY
    Another vote for OEM LEDs w/ @iHacker harness. Best upgrade for your truck.
    WILLINH and GODZILLA like this.
  11. Dec 15, 2022 at 4:35 AM
    dherring256
    dherring256 New(ish) Member
    2018 MGM SR5
    Fuzzy Dice
    Cool. I’ll be doing this upgrade as well
    PermaFrostTRD likes this.
  12. Dec 15, 2022 at 5:04 AM
    WaterTrash
    WaterTrash New Member
    Watching.
    dherring256 likes this.
  13. Dec 15, 2022 at 5:56 AM
    GWill
    GWill gods gift to the internet
    Willis
    Don’t know what you’re talking about
    2020 MGM TRD Pro
    I did this. Got the headlights on sale through a dealership last year for 25 percent off and no taxes during one of Toyotas big sales. Add the iHacker harness, I think it was under $500 total. Best upgrade I’ve done so far
    dherring256, WILLINH and WFD473 like this.
  14. Dec 15, 2022 at 8:30 AM
    Clemsonman14
    Clemsonman14 New Member
    2020 SR5 Crewmax 4x2
    Are there any issues using the ihacker harness to upgrade to LED if you’ve already had the halogen headlight recall performed?
  15. Dec 15, 2022 at 8:46 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    WFD473 and dherring256 like this.
  16. Dec 15, 2022 at 8:49 AM
    RocknRoll
    RocknRoll I’ll make you famous
    DFW, TX
    2019 MGM TRD Sport 4x4
    5” lift, 37” Toyo R/T’s 20” Fuel AMP steps, Ceramic 20% Tint
    What was the halogen headlight recall?
    I’d imagine it wouldn’t make a difference since you’d presume recalls generally fix issues they didn’t intend on having(ie now your headlights function properly), but don’t take my word for it…
  17. Dec 15, 2022 at 8:52 AM
    dherring256
    2018 MGM SR5
    Fuzzy Dice
  18. Dec 15, 2022 at 8:56 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I don't have them but I might soon. @memario1214 might be able to answer questions on the fit/install/wiring. From the description, it sounds like they're more or less plug and play and come with everything you need, whether you're factory halogen or LED.
  19. Dec 15, 2022 at 9:11 AM
    Clemsonman14
    Not sure exactly what was done but supposedly there was an issue where the headlight could cause a potential fire if you idled with them on for a long time. Someone else here probably has a better idea of what the actual remedy was
  20. Dec 15, 2022 at 9:16 AM
    PermaFrostTRD
    Northern NY
    No. My understanding is the recall fixes an wiring overheating concern on newer models (2018+ I believe) that Toyota switched to making the LED lights available. The OEM LED headlights keep the lows on when the brights/hi-beams are engaged. This is fine for the LED assemblies as the current draw is significantly less. It's a problem when the Halogens are used as the current draw is too much for the new "wiring" thingamajig they they did to do the hi/low simultaneously running. Regardless, the risk for damage was only if the the halogen hi beams (and thus the lows too) were on/used for a significant period of time at a standstill. Theoretically things would be cooled off from the wind from driving. :notsure:
    Anyone with more than my kindergarten level understanding of electrical systems is free to chime in and/or correct my post. :help:
  21. Dec 15, 2022 at 10:21 AM
    dherring256
    2018 MGM SR5
    Fuzzy Dice
    Cool. I might have them soon too, depending on what @memario1214 says. Looks nearly identical to OEM, but also has a few cool extra features.
  22. Dec 15, 2022 at 10:28 AM
    The remedy is Toyota cuts into the harness and installs relays.
    Clemsonman14[QUOTED] likes this.
  23. Dec 15, 2022 at 10:29 AM
    WaterTrash
    I just ordered these Headlights and have reached out to @iHacker for the harness thanks to this thread.
  24. Dec 15, 2022 at 10:30 AM
    I have the document from Toyota on my laptop. I would have to look at it again but it was a manufacturing defect in the harness assembly process in one of the facilities in Thailand.
    PermaFrostTRD[QUOTED] likes this.
  25. Dec 15, 2022 at 10:33 AM
  26. Dec 15, 2022 at 10:37 AM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    In the box is the pnp adapters whether you're OEM halogen or OEM LED so you should be gtg either way!
  27. Dec 15, 2022 at 10:39 AM
    AZBoatHauler
    So.Arizona
    I haven’t regretted any of the lighting upgrades. It can get addicting - you’ve been warned.
    :fistbump:
    F50B977F-FD42-4765-8AAB-B1269D781F1F.jpg 272B2864-CE3F-404E-AD3B-7A972967991A.jpg
  28. Dec 15, 2022 at 11:01 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    You got them HotTails yet? :boink:
    WILLINH likes this.
  29. Dec 15, 2022 at 11:15 AM
    AZBoatHauler
    So.Arizona
    Not yet, is the tramp stamp plate required to run those?
    Neo258 and TRDFerguson[QUOTED] like this.
  30. Dec 15, 2022 at 11:16 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Yes
    Neo258 and AZBoatHauler[QUOTED] like this.
