Headlight Scratch Repair
Discussion in '2.5 Gen Tundras (2014-2021)' started by Cdorman, Oct 8, 2019.
  1. Oct 8, 2019 at 4:25 PM
    Cdorman
    Cdorman [OP] New Member
    Oklahoma
    2015 - SR5 - CM - MGM
    Color match MGM Bulge/Grille Trim Pro Grille TRD Pro Headlights(black) OEM led fog lights upgrade Headlight Revolution HID upgrade TVD vinyl decals Fog lights Always MOD Bilstein 5100’s 12Volts remote start kit PowerBass plug/play speaker upgrade
    Had a fender bender, minimal damage but my, less than 6 months old, headlight got lightly scratched. Is there any way to buff out the plastic housing? Does anyone have any first hand experience with it?
  2. Oct 8, 2019 at 4:51 PM
    FUBAR
    FUBAR New Member
    2019 Tundra TRD crewmax
    I had a scuff on my tail light and used some rubbing compound. Worked well. If deeper try one of those headlight restorers. The 3M brand with the different grits of paper works well too.
  3. Oct 8, 2019 at 4:55 PM
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
    You will probably have to spray it with a clear coat afterwards
  4. Oct 8, 2019 at 7:49 PM
    mambo143
    mambo143 New Member
    Phil
    Maine
    2016 Tundra TRD Crewmax
    Bilstein 6112, 5160, Coachbuilder 1” shackle lift, Wildpeak A3’s, LED backup, Maxiplus mats, Bak Rollover Mx4, BedRug, Westin HD Headache Rack. Westin HD Brush Guard, Spidertrax 1.5 spacers. TRD Brakes. Headlight Revolution LED. TRD rear Torsion Bar. Dirty Deeds 10 inch Stainless. TRD Pro Grill. Bushwhacker Pocket Flares. Baja Designs Combo Driving/Fog lights.
    What he said...
    Had scuffing on my instrument cluster lens from prior owner and used this and it’s like new. Just start up easy and check your results. Have used this on several cars with good results as well.
  5. Oct 8, 2019 at 8:23 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    I would wetsand with 3000 grit.
    Work down if that doesn’t work.
  6. Oct 8, 2019 at 9:09 PM
    Cdorman
    Oklahoma
    Thanks for the tips! I’ll give it go, worst case I’ll just buy a new one
    :spending:
