Headlight Revolution Interior Light Issue
Discussion in 'Lighting' started by BrennanC0212, Dec 25, 2019.
  1. Dec 25, 2019 at 4:13 PM
    BrennanC0212
    BrennanC0212 [OP] New Member
    Brennan
    Atlanta, GA
    2014 Toyota Tundra Platinum - White
    Hi everyone, hope everyone had a very Merry Christmas! I got the Headlight Revolution kit for the interior of my ‘14 Crewmax. When I installed them, the interior lights are no longer working. I believe I blew a fuse, but these lights were designed to not blow fuses so I’m not exactly sure of what the issue is. Any ideas on a possible solution? Thanks everyone! @Headlight Revolution
  2. Dec 25, 2019 at 4:43 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    You blew the fuse from installer error. Not the lights fault.
    BravoDeltaRomeo likes this.
  3. Dec 25, 2019 at 4:43 PM
    BrennanC0212
    Brennan
    Atlanta, GA
    I’ve read many people have this issue, not sure how to avoid blowing the fuse. I followed instructions just like HR shows in the videos.
  4. Dec 25, 2019 at 4:46 PM
    Danman34
    Danman34 New Member
    Danny
    it’s very easy to bend the contacts the wrong way and have them make contact when you think you’re putting the bulbs exactly between the slots. Just have to be careful and be sure the base is between the contacts before you push the bulb in
  5. Dec 25, 2019 at 4:47 PM
    BrennanC0212
    Brennan
    Atlanta, GA
    I see, well, how should I fix the issue? Do you know which fuse it is?
  6. Dec 25, 2019 at 5:09 PM
    bsavoir
    bsavoir New Member
    Killeen, TX
    2016 Tundra Limited CM 4x4
    Gibson Metal Mulisha Exhaust, Replaced bulbs w/ LED's, AFe intake, Bullydog Tuner, Aftermarket Audio system, Rhino Bed Light sports bar, Tonneau Cover, Spyder Auto Headlights and Taillights, Recon 3rd Brake Light, Kensun HID's, Fender Flares, Custom Leather Interior, Heated Seats, 5% Tint on the Rear Windows, Pod light Foglights, 31" light bar behind the grille, linex spray bedliner, linex sprayed grille, ditch lights w/ dual 3in LED pods, 60" Tailgate LED strip.
    I had a similar issue, left side map light didn't work I changed the fuse and still nothing later found out it was the on - off - on push switch which apparently is sensitive to electrical mishaps. I pushed to hard trying get it in. Hopefully in your case it is just the fuse.
  7. Dec 25, 2019 at 5:11 PM
    BrennanC0212
    Brennan
    Atlanta, GA
    Uh oh, that’s scary. So I replaced the 7.5 amp with a 15 amp and they worked, so tomorrow I’ll run by the autozone and replace the 7.5 amp fuse.
  8. Dec 25, 2019 at 5:18 PM
    bsavoir
    bsavoir New Member
    Killeen, TX
    I didn't know anything about that switch until someone mentioned it, I was about to buy a new map light assembly that costed about $300.
  9. Dec 25, 2019 at 5:27 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
  10. Dec 25, 2019 at 6:47 PM
    Did you disconnect the battery before install ??
  11. Dec 25, 2019 at 7:26 PM
    BrennanC0212
    Brennan
    Atlanta, GA
    No, they didn’t in the video so I didn’t think about it.
  12. Dec 30, 2019 at 8:24 AM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    I thought I messed up a switch and only bent a pin in the overhead.
    Pain in the ass but easy to fix
    BravoDeltaRomeo and Pinay like this.
