Headlight Restore Kit
Discussion in 'Detailing' started by rons23, Feb 18, 2016.
  1. Feb 18, 2016 at 4:24 PM
    rons23
    rons23 [OP] Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Did some searching through detailing and other areas with no luck. Can anyone recommended a good kit for headlight restoration. I have read so e reviews and seems 3m and sylvania had the best, but would like to here some suggestion's from our detailing experts. Salute
  2. Feb 18, 2016 at 4:28 PM
    Virgils12
    Virgils12 New Member
    Camburg Fox factory 2.5" lift Xd monsters with 295/70/18 nitto terra graplerrs Corsa cat back Weather tech liners Wet okole covers
    Thing I have found with them is they will wear off and yellow again. My suggestion would be to consider new housings even if aftermarket. If you do go the restore route just make sure you keep them waxed.
  3. Feb 18, 2016 at 4:38 PM
    rons23
    Ron
    Kill Devil Hills
    Wha do you mean housing? I wanna do a retrofit, but dont want to buy headlights whether oem oaftermarket.My lenses are just a little scratched, but no yellowing going on.
  4. Feb 18, 2016 at 4:49 PM
    Virgils12
    The headlight housing. I don't think the restore kits help with scratches do they? Thought they were for the yellowing? :notsure: Not a headlight guru but maybe a high 3-10k wet sandpaper then some polishing? Not sure that would work may be a question for @eledobleu.
    rons23[OP] likes this.
  5. Feb 18, 2016 at 4:53 PM
    rons23
    Ron
    Kill Devil Hills
    Yeah there are some kits that you use a buffer and a wet sand to get scratches out. Yeah maybe he will chime in. Thanks for the help
  6. Feb 18, 2016 at 5:10 PM
    eledobleu
    eledobleu retrofitwholesale.com
    Orlando, FL
    Koito Bi-LED Retrofit
    Wet sand with 800 grit, then 1500, then 2000 then buff and polish. Very time consuming but if done right your headlights will look brand new with no scratches! Headlight restore kits are for yellowing. Some includes a buffer if the headlight is extremely yellow and oxidized. I use Plastic X and a buffer for restoring yellowed headlights.
  7. Feb 18, 2016 at 5:16 PM
    rons23
    Ron
    Kill Devil Hills
    Thanks Eledobleu, mcguires makes a heavy duty kit that comes with that same list you just mentioned, also has the plastic x and uv protection. I''ll give it a shot. Appreciate it
  8. Feb 18, 2016 at 5:18 PM
    FirstGenTundra
    FirstGenTundra R2R
    Daniel
    Wyoming
    2014 Toyota Tundra TRD
    I heard a rumor that Jiffy lube will clear up you headlights for $70 or so, and they are under warenty. So you can go back if they fog over again for free.
  9. Feb 18, 2016 at 5:18 PM
    eledobleu
    Orlando, FL
    Yes Ive used that kit before. How bad are your lights? In in the process of restoring some 08's for a retrofit.
  10. Feb 18, 2016 at 5:24 PM
    rons23
    Ron
    Kill Devil Hills
    Not real bad, few scratches, but no yellowing. Some cloudiness. Yeah I have a buddy that did his taco and said he would help me do mine. I like to take on projects and hopefully it's not to apita. Any suggestions would be appreciated. Thanks
  11. Feb 18, 2016 at 5:45 PM
    eledobleu
    Orlando, FL
    If its no yellowing, then just wet sanding, buffing and polishing will get it new again!
  12. Feb 18, 2016 at 5:48 PM
    rons23
    Ron
    Kill Devil Hills
    Appreciate that.
  13. Nov 21, 2016 at 2:57 PM
    TRD Pro Rookie
    TRD Pro Rookie New Member
    Rick
    D/FW
    2016 TRD Pro
    Nothing major
    I use the 3m kit. It uses 3 different sandpaper grits to Polish off scratches, haze, yellow, whatever. Works great.
    NewImprovedRon likes this.
  14. Nov 21, 2016 at 9:12 PM
    thumper7799
    thumper7799 Bad Girls Drive Bad Toys!
    Erika
    2007 Nautical blue Tundra SR5 duel exhaust
    I used macguires twice and it lasted about 5 to 6 months each time. Then I took it to a shop to do and that lasted about the same amount of time. So...now I'm just going to change my headlight housing.
  15. Nov 24, 2016 at 5:35 AM
    briarpatch
    briarpatch New Member
    Take a look at McKees headlight restoration kits...easy to use...they have 2 levels to choose from:
  16. Nov 24, 2016 at 10:10 AM
    rons23
    Ron
    Kill Devil Hills
  17. Nov 24, 2016 at 10:11 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I heard toothpaste works!!
  18. Nov 24, 2016 at 11:01 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    I used the Meg's kit on my mom's 07 Camry, it came out nice. She traded it in shortly after so I can't report on longevity.
  19. Dec 4, 2016 at 7:11 AM
    shaw0531
    shaw0531 New Member
    Jake
    2006 Spectra Blue Mica Tundra SR5 2WD DC
    I just used blue magic on my tundra last night. They weren't bad but a little cloudy. I meant to do before ans after shots but forgot. It was also raining out so not sure how they turned out
  20. Dec 4, 2016 at 7:26 AM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    I used Mother's NuLens Powerball kit on my 99 Suburban and the headlights looked like new after. The kit comes with a compound, ascending grit rating sandpapers, and a buffer.
    I wish I had pictures, the results were amazing and the kit was like $25. I recommend Mother's anything, they make great stuff.
