headlight protective covering
Discussion in 'Lighting' started by fjk6807, May 11, 2020.
  1. May 11, 2020 at 1:52 PM
    fjk6807
    fjk6807 [OP] New Member
    15 tundra limited
    Hi all, I have a 2015 tundra limited. Starting to see some discoloration mainly on the top surface of the headlamps clear covers. I am wondering if anyone has used any type of protection for this to prevent this from occurring. If so what and how well has it worked.
    Thank you in advance.
  2. May 11, 2020 at 1:54 PM
    Medic343
    Medic343 5+4+3=2
    Kenny
    New Mexico
    '22 SR5 TRD off-road
    This seems like a real common issue on our headlight lenses. I remember seeing a post where someone added some vinyl "eyelids" for lack of a better term. I'll see if I can dig it up.
    yoshi82 likes this.
  3. May 11, 2020 at 1:56 PM
    Medic343
    Medic343 5+4+3=2
    Kenny
    New Mexico
    yoshi82 likes this.
  4. May 11, 2020 at 2:00 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Lamin-x
  5. May 11, 2020 at 2:15 PM
    fjk6807
    15 tundra limited
    lamin-x does not offer a covering for the top portion which is what gets messed up on these headlights. I have looked at these before. but thanks
    Tundyfundy likes this.
  6. May 11, 2020 at 11:01 PM
    Tundyfundy
    Bay Area, CA
    You could buy 3M rolls relatively cheap in varying width but as soon as you start going wide the cost jumps significantly. Verified what you said about laminex. Crazy they leave the top exposed.
    On another note I had good luck refurbishing my 1995 Camry headlights with some wet sanding, UV clear coat and some buffing. Still looks like the day I did it about 6 years ago.
    NewImprovedRon likes this.
  7. May 12, 2020 at 6:18 AM
    fjk6807
    15 tundra limited
    Hey Tundy, thank you. I actually have some narrow clear covering i may try. I am mostly concerned with the top as it seems to get like this on about every tundra i see. It is good to know you had 6 years success on sanding and clear coat. I tried one of the restoration kits a while back on a tacoma with not much success.
  8. May 12, 2020 at 10:22 AM
    Tundyfundy
    Bay Area, CA
    Yeah they are generally junk. I got the types of sand paper, I think 600,2000, and 3000 and wet sanded down with each and then 3 coats of clear with a wet sand. Let me check exactly what I used and I’ll get back to you.
  9. May 12, 2020 at 10:38 AM
    Ryuu
    Ryuu Hwat!?
    Oz
    SouthEast, TX
    2017 TRD PRO Barcelona Red
    a few
    Xpel pre cut kit film covers the top of the headlight
    porkitt, rons23 and Tundyfundy like this.
  10. Jun 10, 2020 at 10:39 AM
    mart1nezdaniel
    mart1nezdaniel AZ
    Arizona
    Tundra TRD PRO 2017
    Where'd you get this pic? is this from a video?
  11. Jun 10, 2020 at 11:22 AM
    MJoeP
    MJoeP New Member
    Joe
    2016 Tundra 1794
    2016 Tundra 1794 DiamondBack ATV Tonneau Cover 7" BDS Lift 20" Fuel Krank Wheels 37X13.50X20 Toyo Open Country M/T
    +1 on the XPel. I have had it on my motorcycle since 2015 and it still works great. Also, it is self-healing. Add warm air (heat gun/hair dryer) or warm water and viola, healed.
    https://www.youtube.com/watch?v=T6oEgfdwUU0
    rons23 likes this.
  12. Jun 10, 2020 at 11:30 AM
    Ryuu
    Ryuu Hwat!?
    Oz
    SouthEast, TX
    a few
  13. Jun 10, 2020 at 11:42 AM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    I will be getting Xpel installed on my Nova's and fogs. :thumbsup:
    Ryuu[QUOTED] likes this.
  14. Jun 10, 2020 at 1:19 PM
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    DAP Tune ESP Storage RCI Skids Icon Rebound ABS Guards AVS Vent Visor FRAC Harness 50 Cal/Antenna X BFG KO2 HID Extra Light Bar White Knuckle Off Road Sliders BAK Industries Revolver X2 Oh Shit Handles Pop and Lock LED Internal and Reverse Lights LED Footwell lights Tuffy Storage Console organizers Viper Alarm and Remote Start
    Link?
  15. Jun 10, 2020 at 1:54 PM
    Ryuu
    Ryuu Hwat!?
    Oz
    SouthEast, TX
    a few
    porkitt[QUOTED] likes this.
  16. Jun 10, 2020 at 2:19 PM
    mart1nezdaniel
    mart1nezdaniel AZ
    Arizona
    Tundra TRD PRO 2017
  17. Jun 10, 2020 at 3:29 PM
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
  18. Jun 12, 2020 at 9:29 PM
    SoCalTecHead
    SoCalTecHead New Member
    Tony
    Orange County California
    2020 Cement CM Limited
  19. Jun 13, 2020 at 8:46 AM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    I wonder what the longevity of these thin plastic sheets is in high sun areas.
  20. Jun 13, 2020 at 9:56 AM
    ZeRussian
    ZeRussian New Member
    ‘11 CrewMax
    Use a restoration kit to get rid of the oxidation and then apply UV protecting clear coat. Either take it to a body shop for them to spray the headlights or do it yourself. I used this SprayMax kit with amazing results.
  21. Jun 28, 2020 at 11:51 AM
    mart1nezdaniel
    mart1nezdaniel AZ
    Arizona
    Tundra TRD PRO 2017
    Just installed XPEL headlight film this weekend. Pain in the ass
    JPritch likes this.
  22. Apr 7, 2025 at 7:35 PM
    Mfanatic22
    Mfanatic22 New Member
    2019 CM White SR5 Sport 4x4
    It’s been some time. Any reviews on how Xpel lasted? Thank you.
  23. Apr 7, 2025 at 9:37 PM
    mart1nezdaniel
    mart1nezdaniel AZ
    Arizona
    Tundra TRD PRO 2017
    Well worth it. They still look new
    Mfanatic22[QUOTED] likes this.
